Old 06-26-2015, 02:20 PM   #15
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
It is not. The system uses ignition timing to reduce torque from the engine when the TCS system detects wheel slippage.
If there are any faults in the ignition system, TCS will NOT be operational.
and the dots are connected, thanks stu
The Following User Says Thank You to cdrazic93 For This Useful Post:
stugray (06-26-2015)
Old 06-26-2015, 09:53 PM   #16
wizzo
Drives: 2014 Toyota 86
I think one parameter TCS uses is ignition timing, but its not the only one, another obvious one is the throttle itself
wizzo is offline   Reply With Quote
Old 06-27-2015, 02:10 PM   #17
stugray
Drives: 2013 GBS BRZ Limited
TCS uses rear wheel speed sensors to detect slippage (difference between wheel sensor pulse frequency > some threshold) and then it will retard timing to reduce engine torque. It might also reduce throttle plate position, but that response would be much slower than timing.
For Vehicle Stability Control it uses a lot more inputs such as Steering wheel position, yaw rate, lateral acceleration, throttle input (intent), AND wheel speed sensors.
It will intervene in a VSC situation buy applying brakes to the appropriate wheel using the ABS system.
Old 06-27-2015, 06:18 PM   #18
wizzo
Cool, thanks for the explanation Wasnt trying to act like a smart ass..
Im happy the car is running strong again, changing the coilpack wasnt too bad for anyone reading, was quite straight forward. Didnt have to lift the engine or anything, just move the ecu.
Traction Control Light Constantly On Cal3000 Issues | Warranty | Recalls / TSB 26 12-25-2016 06:20 PM
ABS, Traction control and brake light??? JMoore412 Issues | Warranty | Recalls / TSB 18 08-20-2014 06:09 PM
Traction control, abs and brake light all on? JMoore412 Issues | Warranty | Recalls / TSB 0 08-12-2014 08:27 PM
Traction control light comes even when not hard cornering? Yamajee Issues | Warranty | Recalls / TSB 26 04-10-2014 02:04 PM
lowered car and traction control light came on Shipwreck Issues | Warranty | Recalls / TSB 2 11-05-2013 06:18 AM
