Old 06-25-2015, 11:16 PM   #29
anishb
Drives: '13 Firestorm Scion FR-S
I made a video for the viper remote start I have on my FRS.
[ame="https://www.youtube.com/watch?v=GwyGxtswQlo"]Viper 5706v - Alarm/Remote Start - YouTube[/ame]
Project Red - '13 Firestorm FR-S
anishb is offline   Reply With Quote
Old 06-26-2015, 12:04 PM   #30
jonzhuxD
Drives: Ultramarine FR-S
Our cars have a neutral safety switch that is a ground when the car is in neutral, and not when it's in gear. If your remote start has a ground while running wire, hook that up to wire for the neutral safety switch (I forget which one it is but I'll look it up if someone is interested) and when the car is in gear, the remote start will not start the car.
I have the AdvancedKeys system set up this way and if I put it in any gear, the car won't start. In neutral, and it remote starts.
jonzhuxD is offline   Reply With Quote
Old 06-26-2015, 12:30 PM   #31
stevesnj
stevesnj's Avatar
Can you post a link to your system
My 2016 Build thread
Old 06-26-2015, 12:46 PM   #32
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
Does your gear indicator still work after bypassing the neutral safety switch?
Old 06-26-2015, 04:12 PM   #33
jonzhuxD
I think you misunderstand, you don't bypass it. It effectively is a ground when your car is in neutral. You connect it to your ground while running wire (or similar) on your remote starter. When you attempt to initiate the remote start, your remote starter turns on the ignition, checks to see if the ground while running wire is grounded. If your car is in neutral, the neutral safety switch grounds the ground while running wire and when the remote start sees that, it will start the car. If the car is in gear, the remote start will not see the ground and will not start the car. Of course, you need a remote start that has this function but I think most do. If not, you could always setup a relay that disconnects the remote starter from your starter wire when not receiving a ground from the neutral safety switch.
The Following User Says Thank You to jonzhuxD For This Useful Post:
venturaII (06-26-2015)
Old 06-26-2015, 04:13 PM   #34
jonzhuxD
AdvancedKeys.com, I have the AK-105B installed in my car.
stevesnj (06-26-2015)
Old 06-26-2015, 04:17 PM   #35
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
Drives: '13 Whiteout FR-S A/T
Originally Posted by iStanley View Post
Anything below 60 is cold here haha. My southern skin can't handle it. We had 2 days off of school this week due to <1 inch of snow and also a 2 hour delay due to 25 degree weather. We can't handle it down here lol.
Don't worry about it man....my FR-S lives outside all year long. And it snows up here
If you're looking to warm the car, no point......if you're looking to warm the cabin for yourself, well
drewbot is offline   Reply With Quote
Old 06-26-2015, 04:28 PM   #36
venturaII
venturaII's Avatar
Ahh - gotcha. Thanks for the explanation.
Warm air from vents blunova Issues | Warranty | Recalls / TSB 131 10-06-2020 02:27 PM
Warm Up? gt865 Scion FR-S / Toyota 86 GT86 General Forum 71 09-17-2014 12:28 PM
When do you consider the oil warm sluflyer06 Engine, Exhaust, Transmission 14 06-26-2014 03:21 PM
Ignition for Cat warm up Toyota John Software Tuning 8 04-16-2014 01:14 PM
Warm up time white_knight Scion FR-S / Toyota 86 GT86 General Forum 47 03-14-2013 04:55 PM
