Old 06-26-2015, 01:15 AM   #15
Tromatic
An FR-S with a three-on-the-tree would interesting.
Old 06-26-2015, 01:51 AM   #16
Well now, since we are going retro...... how about an electric hand shifter, like was on the old 1936 Hudson Terraplane .....
Yep, my buddy had one back in HS ...... which allowed him to remove the floorboard shifter, so his GF could sit closer .....
WOW - talk about a "short shifter" ......
Sorry about the
Old 06-26-2015, 03:08 AM   #17
Originally Posted by GreenMonster View Post
Even w/ a 6 speed, I still find myself occasionally trying to shift into seventh
Old 06-26-2015, 03:12 AM   #18
lukey86
Built Not Bought
lukey86's Avatar
Drives: 2012 Toyota 86 ZN6
If said 5 speed was behind a 2JZ then yes! But, then again, you could direct drive a 2J and it would scream!
lukey86 is offline   Reply With Quote
Old 06-26-2015, 04:28 AM   #19
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
Petition for 7 speed FR-S 2017.
Old 06-26-2015, 05:00 AM   #20
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
With a turbo! And 21 gears. And a unicorn with a rainbow.
Old 06-26-2015, 08:11 AM   #21
Cartman
Cartman's Avatar
Drives: GT86
Originally Posted by MikeyBatz View Post
I was thinking would the frs/brz be better with a one less gear? I remember back in the day before the CVTs most subaru were 5 speed.
5 speed gear pros:
-better power band?
-quicker acceleration
-easier in traffic (manual)
cons
-less mpg
what do you guys think?
What??
if you have a 5 speed you'd have a worse power band and less accel as the gearing would be longer to compensate for the missing gear and having a 5th gear OD.
Example... my of 5speed mustang hit 101 MPH on 3rd... and redline was 6K RPM. Where you need 4th in the FR-S to even reach 100.
Cartman is offline   Reply With Quote
Old 06-26-2015, 08:35 AM   #22
Teseo
Drives: frs
I would like 4th gear and 12k rpm limit
Old 06-26-2015, 09:43 AM   #23
Braces
Braces's Avatar
Drives: 17 Alfa Romeo 4C
Seriously ... The car would be simply amazing with a twin clutch transmission. Shifts in the high rpm range where the car likes to live.
Braces is offline   Reply With Quote
Old 06-26-2015, 09:52 AM   #24
akyp
Drives: 2012 86
How about this:
Or this:
akyp is offline   Reply With Quote
Old 06-26-2015, 10:30 AM   #25
NOHOME
Drives: RAVEN
5 speed gear pros:
-better power band?
cons
-less mpg
I use third maybe once out of 20 times as I go up the gears. Normal pattern for me is 1-2-4-6 shift points around 5500
If you like to accelerate briskly during normal driving, and the speed-limit is like 45-50 mph, then a hard pull through 1st and 2nd up to 5500 or so drops you around 3000 rpm when you are in 4th. About where I cruise surface streets.
Truth be told, I would be just as happy if the box were 5 gears.
To those that stand-up for the 6, why not go further and have 12 if you believe that pulling the lever is some kind of a good thing?
NOHOME is offline   Reply With Quote
Old 06-26-2015, 11:06 AM   #26
3nl
Drives: 2015 FR-S 6MT
Something like a GTI would be just fine with 5 gears since it has near full torque all the way down at 2200rpm and keep it almost up to redline - we don't even get into the powerband until we are over 4000rpm. We don't have a lot of area under our torque curve so we need a transmission that is capable of keeping the car in the pretty narrow powerband. If you wanted a grocery getter that was easy, why did you buy an FR-S? The reason we have a 6 speed is so you can keep the car in the powerband and still have a decent overdrive.
The transmission should be matched to the engine - the transmission should make the car as quick and economical as possible given the powerband with as few gears as possible. In our FR-S, that number is 6.
3nl is offline   Reply With Quote
Old 06-26-2015, 11:21 AM   #27
Originally Posted by akyp View Post
How about this:
Or this:
Oh god, I can just picture the threads now:
"New to MT and I get a weird noise and the car bounces when shifting from 4th to 15th. Any ideas?"
Old 06-26-2015, 01:22 PM   #28
MJones_RB
MJones_RB's Avatar
Drives: Scion FR-S Series 10 #2462
My '66 Nova has a 2-speed Turbo-Thrift tranny. 0-35 in first, 35-infinity in second. For an inline-6 it was real quick off the line. Around 50mph it felt like it was about to blow apart. Not a good freeway car.
MJones_RB is offline   Reply With Quote
Other twins gravitylover Other Vehicles & General Automotive Discussions 53 03-02-2015 11:38 AM
top speed axleback....or top speed dual catback? pepe Engine, Exhaust, Transmission 10 11-07-2014 07:12 PM
Is this one of the twins? Krazy Off-Topic Lounge [WARNING: NO POLITICS] 4 07-22-2014 09:33 PM
Is it just me or Twins are everywhere now? DrawingWaves Scion FR-S / Toyota 86 GT86 General Forum 93 03-20-2014 09:31 PM
Engine Speed vs Vehicle Speed for 6MT DetroitJake Engine, Exhaust, Transmission 22 04-27-2013 06:56 PM
