Old 06-15-2015, 02:47 PM   #43
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
These entry level penskes would be as expensive as top of the line Tein SRC's. Atleast.
Old 06-15-2015, 02:48 PM   #44
CSG Mike
CSG Mike's Avatar
Originally Posted by wparsons View Post
The entry level here, and most people's definition of entry level will probably be a bit different.
I would expect single adjustable Penskes to come in at a price point slightly higher than the Ohlins R&T (also single adjustable).
I wish they were that cheap...
The Following 3 Users Say Thank You to CSG Mike For This Useful Post:
cdrazic93 (06-15-2015), DustinS (06-23-2015), wparsons (06-15-2015)
Old 06-15-2015, 03:43 PM   #45
Canehda
poverty cause racecar
Canehda's Avatar
Drives: Subaru BRZ JRSC'd
I don't want to sound like a **** but if you are asking about price for these then I would look elsewhere, even the entry level version of these will cost in the "money is not a problem" range... I'm willing to bet that the entry level isn't about making a more affordable option, rather more about satisfying different series regulations :P
Canehda is offline   Reply With Quote
The Following 3 Users Say Thank You to Canehda For This Useful Post:
RBbugBITme (06-20-2015), wparsons (06-15-2015), xwd (06-16-2015)
Old 06-15-2015, 04:01 PM   #46
wparsons
wparsons's Avatar
Or the set it and forget it crowd that doesn't want more adjustments.
flickr
The Following 4 Users Say Thank You to wparsons For This Useful Post:
Calum (06-16-2015), cdrazic93 (06-15-2015), CSG Mike (06-15-2015), DocWalt (06-16-2015)
Old 06-15-2015, 04:41 PM   #47
jvincent
jvincent's Avatar
So many negative vibes. I'm expecting these bad boys to come in at under $2k!
Yes, I realize I am probably dreaming.
The Following 2 Users Say Thank You to jvincent For This Useful Post:
Calum (06-16-2015), wparsons (06-15-2015)
Old 06-15-2015, 06:18 PM   #48
Canehda
Canehda's Avatar
Although I'm assuming Penske would be overkill, I wonder if a road option like the bilstein B6 + B8 would ever come to light. Just a really nicely valved shock for someone who wants THE BEST for their otherwise road car...
The Following User Says Thank You to Canehda For This Useful Post:
wparsons (06-16-2015)
Old 06-15-2015, 06:25 PM   #49
redlined600
redlined600's Avatar
Drives: Fr-s
Consider their camber plates are $500. That said, I bet these will be worth it. If only I could afford them...
redlined600 is offline   Reply With Quote
Old 06-16-2015, 12:23 AM   #50
xwd
You'll likely need to be somewhere between triple and quadruple of that.
Old 06-16-2015, 11:02 AM   #51
OkieSnuffBox
Drives: '23 BRZ Limited
I'll throw my speculation into the ring.
I'll say $900 per corner + mounts.
Old 06-16-2015, 11:42 AM   #52
jvincent
jvincent's Avatar
But the camber plates will now have reduced pricing because they are now bundled with dampers!
Old 06-16-2015, 11:54 AM   #53
wparsons
wparsons's Avatar
I was guessing $800-$900 per corner plus upper mounts as well.
flickr
Old 06-16-2015, 07:26 PM   #54
Calum
That Guy
Drives: 2013 asphalt FRS MT
Did you see the price for the raceseng and KW setup? It was dollar for dollar the same as you could get from ft86SF, which had me scratching my head. Why not just say that raceseng is now an authorized dealer of KW and that their mounts can be order together to ensure proper fitment or something along those lines.
Old 06-16-2015, 07:59 PM   #55
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
Random speculation?!? I'll play.
Cost will be $4,XXX-$1X,XXX depending on configuration.
Decay107 is offline   Reply With Quote
Old 06-17-2015, 03:48 AM   #56
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Safe to say that few people will buy these.
Ultimate Racing Turbo Kit sweetfrs Forced Induction 34 12-17-2015 12:25 PM
More info on Penske shocks ayau Suspension | Chassis | Brakes -- Sponsored by 949 Racing 156 04-28-2015 11:22 AM
Ultimate Racing Turbo Kit ganz954 Forced Induction 19 11-13-2014 11:34 PM
Ultimate Racing Exhaust help psyclone07 Engine, Exhaust, Transmission 0 07-07-2014 12:05 AM
Ultimate Racing, quality? rhythmM Engine, Exhaust, Transmission 5 11-30-2013 06:46 PM
