Old 05-28-2015, 01:52 PM   #295
FISHBURGLAR
Drives: whiteout fr-s
P0462 is a hardware issue nothing to do with tune
P050B you will need to disable else it will keep coming back its cold start ignition performance due to quiet start mods, disable it and flash new tune that will also reset ecu and clear the other code, if the P0462 keeps coming back then it likely their is a problem with fuel tank sender unit.
awesome thanks will flash the new tune. P0462 hasent come back ever since yesterday so im thinking it was a batch of bad gas or just a fluke. =] thanks steve!
FISHBURGLAR is offline   Reply With Quote
Old 05-28-2015, 01:56 PM   #296
steve99
Drives: FT86
Its usually due to fuel sender/float in tank sticking or bad connection or just stuffed.
Old 05-31-2015, 03:45 PM   #297
Kelbyat07
Poor College Kid
Kelbyat07's Avatar
Drives: ~.~
Just got my OFT can't wait to use it
Kelbyat07 is offline   Reply With Quote
Old 05-31-2015, 05:42 PM   #298
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
Good afternoon
Now that the daughter has returned from college, I modified the Radiator Fan temp settings in RomRaider and flashed the car with the custom V2.063 A01D Stage 2 EL93.
Thank you all for the excellent support and those amazing OFT Tune Tweaks and Information. Steve99 Thank you!
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
The Following User Says Thank You to tonystewart For This Useful Post:
steve99 (05-31-2015)
Old 06-04-2015, 06:25 PM   #299
calic
calic's Avatar
Drives: Subaru Brz
Does the new oft manager automatically pull the latest tunes? Or do i still need to manually update the tune file in my tablet?
calic is offline   Reply With Quote
Old 06-04-2015, 06:37 PM   #300
Weapon86
Weapon86's Avatar
Drives: 2014 Scion FRS monogram series
You have to download the latest tune files on their website and load it on your tablet.
Weapon86 is offline   Reply With Quote
Old 06-11-2015, 09:00 AM   #301
JDsThatGuy
Drives: Subaru BRZ Limited
While trying to flash an update today I got an error when the write was almost done and it completely disabled my start button, I've been trying to re flash the stage 1 I was running but my tablet keeps giving me an error saying to turn the ignition on (it is). Anyone run into this trouble before? My car won't start and I'm sitting here stuck
The reason I was trying to re flash stage 1 is I wanted the updated maps
JDsThatGuy is offline   Reply With Quote
Old 06-11-2015, 01:01 PM   #302
Kelbyat07
Poor College Kid
Kelbyat07's Avatar
Drives: ~.~
Do you guys flash back to stock when you are about to get an oil change? I'm thinking not, but want to make sure.
Old 06-11-2015, 01:41 PM   #303
D_Thissen
D_Thissen's Avatar
@steve99
Old 06-11-2015, 02:59 PM   #304
phrosty
I've gone in several times without flashing back to stock. I don't think they'd know how to tell even if there was a way for them to do so, and there's no evidence that there is.
When I went in a long time ago to get B01D, it took them several hours over two days and multiple calls to corporate to figure out how to flash it. It takes me ~5 minutes with OFT.
phrosty is offline   Reply With Quote
Old 06-11-2015, 04:00 PM   #305
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
It's funny how enthusiasts often know more about certain things than the people who do it for a living.
smg1138 is offline   Reply With Quote
Old 06-11-2015, 05:26 PM   #306
phrosty
The scary thing is this means the dealership wasn't aware of B01's safety improvements, and are not recommending this to any people as they come in for oil changes, etc. -- so all those original cars are running around waiting for a hot day of spirited driving to blow their injectors!
Old 06-11-2015, 06:17 PM   #307
steve99
Drives: FT86
Is you car battry good and well charged, low battry will cause flash problems.
Os cable connection between oft and car good
Did you make any alterations to tune with romraider ?
if so did you use v2defs with V2 tunes and not the old v1 defs?
Old 06-11-2015, 06:24 PM   #308
steve99
Drives: FT86
They can check the CVN (checksum) against a standard rom and work oit its different, but very unlikely at standard service , if you have engine issues flash to stock just to be safe
WTB: Open Flash Tablet TOZER Canada Classifieds 3 07-05-2015 07:13 PM
Open Flash Header & Open Flash Tablet Calavera Engine, Exhaust, Bolt-Ons 9 05-11-2015 08:27 PM
FS: open flash headers / open flash tablet - SOLD alanhung85 Canada Classifieds 12 02-10-2015 02:08 PM
FS: Open Flash Tablet (OFT) mex2309 Engine, Exhaust, Bolt-Ons 1 10-29-2014 02:49 PM
Open flash tablet. cooldandani Scion FR-S / Toyota 86 GT86 General Forum 1 02-22-2014 07:14 PM
