The Mechanic
Drives: Civic Turbo,FR-S
Heat reflecting oil pan idea
We all know of the oil temp issue, so i came up with an idea. Since the headers run so closer to the pan they have to radiate some heat. Yes they are already heat wrapped but maybe adding some sticky heat reflective tape to the front and sides of the pan might help bounce some heat off?
Well it seems to have raised my temps from an average 208ish to 221 calmly driving down the highway on a 88 degree day, idk if its insulating the oil that bad or if the sensor is being affected. I dont recall if i saw the temp sensor on the pan or not but has anyone else tryed this??
#2 |
Drives: white out project fr-s
sounds like a double edged sword to me....sure you would be able to reflect some of the radiant heat from the header away from the pan but then you would take away the heat transfer from the oil pan to the natual air surrounding the pan....
maybe the better option would be to get an oil pan that has slightly larger capacity so that there would be more oil to cool down in the pan...i remember seeing a company that offered one. |
| The Following User Says Thank You to carlitosway6891 For This Useful Post: | humfrz (06-10-2015) |
#3 | |
The Mechanic
| The Following User Says Thank You to Grip Ronin For This Useful Post: | carlitosway6891 (06-10-2015) |
#4 |
We run thermal tape on our oil pan.
| The Following 2 Users Say Thank You to CSG Mike For This Useful Post: | celek (06-10-2015), RobertPaulson (06-12-2015) |
#5 |
Some say.....
Drives: 2007 Subaru Impreza 2.5i
#6 |
Junior
Drives: a car
What about heat fins? Helps the ambient air wisk away the heat faster?
#7 |
Hotlink Terrorist
Drives: 2015 WRB BRZ Spec S
A plate between the pan and the exhaust would be better with a bit of an air gap between it an the pan. If you wanted to take it a step further, now that you have a sort of duct, run a scoop to the front to force air through it and over the pan.
#9 |
Just get an oil cooler.
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
#10 | |
Resident Gear Head
Subaru BRZ/FRS Facebook News and Tech Page
My FB Build page CLICK AND LIKE! Twitter and Instagram @misairubrz |
| The Following 2 Users Say Thank You to celek For This Useful Post: | carlitosway6891 (06-12-2015), CSG Mike (06-11-2015) |
#11 |
The Mechanic
thats what i did just the front and sides. less then 50%, you had good results with it?
#12 |
#13 |
Drives: 2014 GT86
If track cars usually have oil coolers installed anyway, isn't it simpler to not bother with oil pan heat shielding? On daily driven ones oil temps are lower, so less of a reason there too, no?
#14 |
The Mechanic
I have an oem oil cooler which helps but on track it still gets hot, those external oil coolers are terrible idea for this engine because oil pressure is already low. So finding an alternative solution that doesnt cost me engine bearings in 15k is the idea
| Heat Shields | X Factor | Engine, Exhaust, Transmission | 4 | 09-05-2014 03:47 PM |
| Heat cycled. | forwallblakmail | Tracking / Autocross / HPDE / Drifting | 23 | 06-25-2014 10:45 PM |
| Idea for 10 Series Owner, but have no idea how to accomplish. | IgnitionGundam | Cosmetic Modification (Interior/Exterior/Lighting) | 9 | 10-01-2013 12:29 AM |
| Misfire with heat? | bigjake | Issues | Warranty | Recalls / TSB | 2 | 04-28-2013 09:02 PM |
| Do I Need a Heat Shield? | arleewa | Engine, Exhaust, Transmission | 1 | 01-08-2013 06:37 AM |
