Old 06-05-2015, 11:16 PM   #1
ksconekiller
Drives: Subaru BRZ
Stuck Koni adjuster
On one of my rear Koni sports, I can't turn the adjuster. I installed them 2 months ago and haven't touched the rears since, but today I was messing with the fronts and decided to verify that the rears were still set the way I wanted them. The most common cause of this is bottoming out the shock, but my car is at stock height on stock springs and bumpstops. Koni is sending me another shock so I can replace this one, but I don't think bottoming will be covered under warranty in any way if that's what caused it. My concern is that this could happen again.
Anyone had an issue with this on these cars?
Thanks,
Mike
ksconekiller is offline   Reply With Quote
Old 06-06-2015, 01:31 PM   #2
simpleisbest
Senior Citizen
Drives: Scion FR-S
If it was working after initial install, it can happen if you run full hard or full soft. Common preventive practice is to back off a hair (1/32", 1/16") from both full hard or full soft.
simpleisbest is offline   Reply With Quote
Old 06-06-2015, 05:13 PM   #3
ksconekiller
Drives: Subaru BRZ
Yep. I've run Konis for many years, and I've always practiced that method, so it's not that. The Koni tech confirmed that bottoming tends to be the leading cause, but I hope that wasn't the case here with stock springs.
Old 06-06-2015, 05:51 PM   #4
Briankbot
Briankbot's Avatar
Drives: 2013 FRS
http://www.roadraceautox.com/showthr...nob-won-t-turn
Briankbot is offline   Reply With Quote
Old 06-07-2015, 12:19 AM   #5
ksconekiller
Drives: Subaru BRZ
Thanks for the link. I had actually read through that, and I contacted Lee to find out what can be done. I guess we'll see.
Old 06-07-2015, 04:56 PM   #6
renfield90
The Stig's German cousin
Originally Posted by Briankbot View Post
snip
No public linking to the sandbox...
Stuck - Koni Shocks & TRD Spring install issue ButteR Scion FR-S / Toyota 86 GT86 General Forum 9 05-05-2015 01:09 AM
FS: RCE Yellow, Koni struts and pre cut housing for Koni's. Dinko Brakes, Suspension, Chassis 21 12-16-2013 11:32 AM
KONI SHOCK VALUE SALE limited time only @ Circuit Motorsports! Lower prices all Koni Circuit Motorsports Brakes, Suspension, Chassis 115 08-30-2013 11:29 AM
Koni inserts or wait for full Koni replacements Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 05-18-2013 06:48 PM
Need for Roll Centre Adjuster pdreams Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 12-09-2012 12:51 AM
