Old 05-31-2015, 07:32 AM   #1
Stone Cold
Drives: 94.Prelude BB3 - 99.Civic Ek9
How to use JBL Sound system with Aftermarket Radio
Hi, so like on the top i want to install a new radio in to my GT86,
but still using the Jbl system.
Problem is, i dont get this amp running.
I bouth a interface from Axxess, the TYTO-01, but this one isnt for the gt86.
I write a mail to axxess and the said they dont have an interface for that car.
So, the two oem plugs are in. and the radio is working, without Sound.
the problem is that i cant find any Wiring diagramm from those JBL system.
To see what i have to bridge, that the amp works.
Does any body have some more info about it. Wiring, Diagramm, anything.
I tryd any possible words in to the search area, but cant find anything.
HHHHEEEEEELLLLLLLPPPPPPPPP.
Stone Cold is offline   Reply With Quote
Old 05-31-2015, 08:12 AM   #2
Chimera
Drives: FRS
I didn't know there was a jbl option even on the gt86
Old 05-31-2015, 09:01 PM   #3
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Cuz living in USA = u will always get the shorter end of stick on Japan/european cars.
Don't be surprised to find out their 86 have better sound insulation too.
JBL audio system is a dealer option in europe/japan... been on the option sheet there since 2012.
http://ch.shop.harman.com/jbl-automo...a-gt86-eu.html
Ya blame Scion.
Ps: You can find the system on ebay
Old 05-31-2015, 09:14 PM   #4
Chimera
Drives: FRS
Curious.. Had I known this I probably would have done this vs what I have now
Old 05-31-2015, 09:26 PM   #5
projek_01
projek_01's Avatar
Drives: 1996 ST204, Series 10 FR-S
I can't imagine they would change the pinouts just for the JBL system since the base model in EU shares the same head unit as the American ones. Have you googled the BRZ electical manual? I'm sure that would have what you need.
Maybe you hooked up the power antennae amplifier but not the sound amplifier? Also, Toyota typically uses the same connector at the amplifier. There is a thread that shows the pin outs. You can metre there and check that it is getting 12v trigger there
http://www.ft86club.com/forums/showthread.php?t=42239
projek_01 is offline   Reply With Quote
Old 06-01-2015, 03:40 PM   #6
Stone Cold
Ok im gonna try this out. Thanks
Using OEM Mic for Aftermarket Radio AND/OR Replacing OEM Mic with Aftermarket Mic ecko04 Electronics | Audio | NAV | Infotainment 10 05-05-2018 03:47 PM
Using XM Radio Antenna On Aftermarket HU demariners Electronics | Audio | NAV | Infotainment 2 01-20-2015 10:17 AM
Aftermarket radio with no sound. Stone Cold Electronics | Audio | NAV | Infotainment 4 12-30-2013 10:22 PM
Help:new aftermarket radio and question regarding speakers FR-Shadow Electronics | Audio | NAV | Infotainment 2 11-04-2012 07:58 PM
Aftermarket 2DIN Radio Install DetroitJake Electronics | Audio | NAV | Infotainment 4 07-08-2012 11:17 AM
