#43 | |
Drives: Scion FR-S A/T, Whiteout
As it stands, I don't know of any carrier that has a 4.56 pre-installed that will just drop into an 86. |
| The Following User Says Thank You to PantsDants For This Useful Post: | jcw99 (03-06-2016) |
#44 | |
Drives: 04 Toyota Tacoma Prerunner Reg Cab
But there gots to be a 4.56 Torsen LSD pumpkin out there somewhere, that will directly bolt/swap into the 86 (axle/driveshaft flange bolt patterns and all) . And once that secret is out, the junkyards are gonna be getting a lot of phone calls hehe ![]() More research on the usdm IS300 (and/or old Supras or other Toyota cars?) might be of use: - Which are 4.56 - Which have Torsen LSD - Carrier bolt/hole-mount placement - Driveshaft flange bolt pattern, size and type (holes or studs) - Axle flange bolt pattern, size and type (holes or studs) |
#45 |
Drives: Brz
Do you have any noise after swap from the FD?
#46 |
#47 |
I don't think I do, no.
That said, the diff shop guy did tell me I could expect some, based on how these cars are shaped and how short the FD ratio is. His advice to me was if you have some whine right after install, it's probably fine. If that noise changes though, then you should be concerned. |
#48 |
Drives: Scion FR-S
Thanks for the tips! Picked up my diff today for $250 to start the project:
#49 |
3.73 ratio works great with boost. Highway cruise is way quieter as well
#50 |
Drift King
Drives: '13 Firestorm FR-S 6MT
Would anyone be interested in buying a brand ring and pinion set for an M85 differential? I was going to swap the stock differential ring and pinion but found a good deal on an M85 diff.
'13 6MT Firestorm FR-S
#51 |
Drives: 86
Any recommendations for good dedicated differential shops in socal?
#53 | |
Drives: Scion FR-S
Unless you have any of the following, I wouldn't recommend doing it yourself: 1) Good public transportation 2) Walking distance to work/grocery store 3) Access to carpool 4) Spare pumpkin to work on Either buy a pumpkin and prepare for the agony of doing it yourself, or take it to a shop. |
#54 | |
Drives: FRS monogram
#55 |
Buying new gears, bearings, seals, and having a shop install them would be probably twice what you'd pay for a whole is300 pumpkin. So I fail to see the benefit unless you want a 100% new rear end
| Final Drive Discussion | JimmyMac | Engine, Exhaust, Transmission | 118 | 08-07-2017 11:18 PM |
| Change gear ratio? | Afdad120108 | Engine, Exhaust, Transmission | 61 | 08-17-2016 11:44 AM |
| Final Drive Calculations | wootwoot | Engine, Exhaust, Transmission | 34 | 12-19-2014 05:06 AM |
| Change FD ratio to 4.56 by changing only pinion | peachch | Engine, Exhaust, Transmission | 1 | 08-31-2013 02:25 PM |
| Correcting drive ratio for accurate speed | AlexTheGreek | Engine, Exhaust, Transmission | 25 | 12-05-2012 02:13 AM |
