#15 | |
I am in the same boat as you- I am worried that it's a shit time of year to do tuning; Washington has a ton of variance in weather so I'm thinking of creating two tunes, one for summer, one for rest of the year. When things clear up, hit me up and I'll lend any support I can. I use @vgi's Java plugin and Steve as my advisor for when I don't understand something, haha. I am also playing around with zeroing out the IAT comp table and tuning from there, but I don't understand that approach yet so I'll let you know if I make any breakthrus on that front |
#16 |
Drives: 2014 FR-S 6MT Whiteout
Well, I advocate a lot for OFT but it's true that an OTS tune can only go so far. They tuned at some shop in Southern California at say 1,000' altitude on a 70+F degree day and I'm sitting here at sea level at below 30F. It does make a difference. More air so there's more fuel needed to get to the commanded AFR (which it's always easily in reach of).
| The Following User Says Thank You to phobos512 For This Useful Post: | Koa (02-27-2015) |
#17 |
Drives: '23 BRZ Limited
Bumping this, has anyone used the AFe Takada intake with an oil cooler?
#18 |
Drives: Silver 2013 BRZ Ltd Auto 45,000 mi
What about the Skunk2 airbox?
What about the Skunk2 airbox? It clears the Skunk2 oil cooler lines. Though I don't have an oil cooler yet, here's a picture of it installed. I'm using it without the restrictor, so it's a little over 3" wide through the MAF adapter, and it has air straighteners inside to restrict turbulence. It's made of heat resistant plastic material to resist heat-soak better than metal intakes. It makes enough power with my long-tube header to squeal the tires from a standing stop in an automatic, and that's more than my stock intake could do. It also has a rubber ring where the tube passes through, which ingeniously absorbs the engines' torque thrust against the body-mounted airbox. Other setups can work their way loose while this won't.
#19 |
Drives: Fast
FYI, Grimmspeed is working on a solution for the airbox to work with oil cooler lines, and plan on letting the initial crowd of buyers looking to use an oil cooler swap out with the revised box when it's ready.
There's no ETA on this yet though. Grimmspeed takes good care of their customers. |
| The Following User Says Thank You to 2016 Camaro SS For This Useful Post: | golfyankee2121 (05-14-2015) |
#20 |
Drives: 2017 BRZ
GS, don't look back. Wait for the update re: oil coolers if its that much to you, shouldn't be to long.
| The Following User Says Thank You to cjd For This Useful Post: | 2016 Camaro SS (05-14-2015) |
#21 |
Always Moving Forward
Drives: 2013 Argento Scion FR-S
Grimmspeed Intake all the way.
| The Following User Says Thank You to golfyankee2121 For This Useful Post: | 2016 Camaro SS (05-14-2015) |
#22 | |
Drives: FT86
altitude temperature fuel formulation fuel ethanol content ie 0 to 10 or so % in petrol and variations in the actual maf sensor itself due manufacturing tollerance or revisions, their apears to be at least 2 variations. mine always ran rich and i see it in other guys logs as well, some run rearly good and some like mine run about 7 to 10% rich on stock intake. even on stock tune and intake. |
#23 |
#24 |
Drives: Fast
The Perrin is pretty solid if you don't mind fiddling with the front bumper. Can be done without removing it but it's a little trickier.
#25 | |
Drives: 2017 BRZ
While you likely want to fine tune, MAF scaling doesn't seem the mess it is with so many, and that's a safety issue too. Is the basis of my recommendation, at any rate. |
#26 | |
^Yeah, I'm just curious how long that will take. I suspect it will be months down the road.
I wouldn't mind pulling the bumper to install it, since I'll have to pull the bumper to install the oil cooler. But having to regularly pull it to clean the filter, that's not so appealing. |
#27 | |
Drives: Subaru BRZ Limited
#28 |
Just NA. No desire to drop $7k on FI......even if I had that laying around!
| Eibach Sportlines requirements | Hawk77FT | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 19 | 11-11-2013 11:02 PM |
| Virginia Emissions Requirements? | cmarks20 | Mid-Atlantic | 19 | 04-25-2013 08:08 PM |
| Engine Pulley Torque Requirements | JDKane527 | Engine, Exhaust, Transmission | 6 | 03-22-2013 07:24 PM |
| 250 ~ 300 hp - Cost, Requirements, Effects | Froylavin | Engine, Exhaust, Transmission | 14 | 07-19-2012 12:55 AM |
| Minimum requirements... | Blokatos | Scion FR-S / Toyota 86 GT86 General Forum | 528 | 11-15-2011 04:04 PM |
