Old 09-11-2014, 02:48 PM   #43
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by JoonPrime View Post
last longer as in the miles and years, since i drive so much i want to make sure that any form of FI i do, is at least the one thats best suited for long term.
is 93 that big of a deal when running boost?? unfortunately i have used 92 gas for the 2400 mile duration of my life so far, the 93 is a bit difficult to find. possible, but difficult while the 92 is normal.
can you clarify what you mean when they eventually require a rebuild? is this based on miles or years, or based on maintenance of how hard i drive the car??
thanks for answering btw, i understand noobs such as i can be annoying on forums.
92 is fine, remember that it is essentially an anti-knock rating, so the less octane, the less timing/boost you can run and keep the motor from knocking. The Subaru ECU has some fairly modern anti-knock mitigation code in it that helps keep your car safe. Turbo rebuild intervals can have a lot of factors such as the manufacturer of the turbo, design of the turbo kit and what oil you use, what psi the oil flows through the turbo, how well the drain line is setup, what temps the oil is run at, and how well you are filtering the air entering the turbo. Superchargers are generally just oil filled, so there is less too worry about other than doing the scheduled oil changes on them although the Rotrex kits do cool the supercharger oil. The seals and bearings still wear in them though, so they also will require maintenance/rebuilds. I haven't researched what Vortech or Rotrex's expected intervals are for that.
JoonPrime (09-11-2014)
Old 09-11-2014, 04:20 PM   #44
JoonPrime
Drives: 2015 Limited series all white brz
thank you, very informative and i didnt think about pipe lines and oils, i was just assuming running a turbo or super would kill my engine, period.
ill ask the local (the only) car shop near me to see what they think as well. I also asked because they are listed as a certified dealer for greddy so i figured i may as well look into their product :P
but thanks again, very helpful my friend :]
JoonPrime is offline   Reply With Quote
Old 11-19-2014, 05:17 AM   #45
rocketbunny86
rocketbunny86's Avatar
Drives: gt86 and Supra Mkiv
There seems to be an upgrade to GREDDY T620Z for the T518Z users in japan....
http://www.trust-power.com/86_brz/in...urbo_kit_t620z
rocketbunny86 is offline   Reply With Quote
Old 11-19-2014, 05:40 AM   #46
midnight23
dying bird under the hood
Drives: 2013 SWP Limited BRZ
odd they announce it now when they are teamed with Garrett.
Build Thread
Instagram
Old 11-19-2014, 11:24 AM   #47
shiro
shiro's Avatar
Drives: 2013 Scion FR-S, 2014 Lexus IS350
It's kind of nice that Greddy teamed up with Garrett. I think they make some good turbos. I'm currently using the GTX2867R and she purrs
The T518z is capable of 14PSI with the current actuator installed. If you have the time to upgrade the actuator on the T518z it should be capable of around 18PSI. This was information I received from Andrew at Greddy USA.
The link below is the actuator someone can use on the T518z. However, some modification will be required.
http://www.shopgreddy.com/turbocharg...17z-turbo.html
shiro is offline   Reply With Quote
Old 11-19-2014, 02:57 PM   #48
rocketbunny86
Greddy Japan and Greddy USA has different ideas...now a wider variety of options to upgrade...
Old 03-25-2015, 03:34 PM   #49
tubsaub
tubsaub's Avatar
Just a question, where did everyone get their tune for this kit?
tubsaub is offline   Reply With Quote
Old 03-25-2015, 06:13 PM   #50
shiro
shiro's Avatar
When I got my tune it was from Full Blown Motorsports. Had an E85 and 91pump tunes done there.
Old 03-25-2015, 07:54 PM   #51
ztan
Drives: Toyota 86
Road tuning with Tactrix, dialling in around 9psi at the moment. Happy to share my (incomplete) ROM with anyone. I used Shiv's SBD ROM as a base guide to timing, fuelling, AVCS. Have found a couple of areas (3200-3600, 4800-5600) where the T518Z system needs less cam overlap than SBD system.
Would be interested to see what others are running on their cams.
ztan is offline   Reply With Quote
Old 04-21-2015, 08:37 AM   #52
boostedbrz
boostedbrz's Avatar
Drives: 2013 BRZ Limited Turbo E85
My current results. Better numbers on the way soon.
I'm still having issues with my grimmspeed MBC. Boost peaked at 13.8psi and quickly started falling from as low at 9.5psi by redline. I am tuned for 15, so I will be going with a ebc solenoid, and having delicious tuning rework my tune to let the ecu control boost. Also, the wastegate actuator when preloaded correctly allows for about 10psi stock. It comes with a very loose preload. I should make a good bit more with boost hitting and holding 15psi to redline. I am using delicious tuning's flash & go e-tune.
400rwhp 349rwtq
[ame="https://www.youtube.com/watch?v=mHHq_1a2gQE"]GREDDY TURBOCHARGED BRZ 400rwhp 349rwtq - YouTube[/ame]
boostedbrz is offline   Reply With Quote
The Following 5 Users Say Thank You to boostedbrz For This Useful Post:
Cessblood (04-21-2015), GhostOp86 (05-08-2015), NyC Zn6 (05-08-2015), raven1231 (11-13-2015)
Old 05-08-2015, 08:52 AM   #53
Jacques Blom
Turbo 86
Jacques Blom's Avatar
Drives: Toyota 86 Turbo
Originally Posted by midnight23 View Post
yes injectors and pump, however you can still make those numbers without them. I upgraded them because I plan to go E85 later.
Hi Midnight,,pls share what injectors you use and pump detials pls .. I am thinking to upgrade mine ..running G ready with FF kit ...
Jacques Blom is offline   Reply With Quote
Old 05-08-2015, 04:36 PM   #54
boostedbrz
boostedbrz's Avatar
I had trouble keeping mine under 18psi with an ebcs! With the ebcs installed we had to tune it down 3-4 times to get to a steady 15psi. The actuators come with a very loose preload from greddy. Preload them properly and your making a good 9.5-10psi on the actuator alone.
The Following User Says Thank You to boostedbrz For This Useful Post:
Cessblood (07-09-2015)
Old 05-08-2015, 05:29 PM   #55
midnight23
Deatschwerks 700cc injectors and 65c fuel pump
Build Thread
Instagram
Old 05-09-2015, 02:29 AM   #56
shiro
shiro's Avatar
Interesting. Well, that's good to hear you were able to make those numbers without any major modifications. Thanks for sharing!
The Following User Says Thank You to shiro For This Useful Post:
boostedbrz (05-09-2015)
Greddy / Trust Turbo Kit (Video and Pictures) BPAuto Forced Induction 62 03-18-2016 07:04 AM
BRZ GReddy t518z NOTORIOUS.BRZ BRZ Photos, Videos, Wallpapers, Gallery Forum 26 04-15-2014 03:15 PM
GReddy T518z+Greddy CS GTS Ver 2. Video + pics (not tuned) NOTORIOUS.BRZ Engine, Exhaust, Transmission 21 09-24-2013 07:09 PM
GReddy Tuner T518Z Turbo Kit Fitted / Photos/ DYNO/ Video ! NOTORIOUS.BRZ Forced Induction 17 07-29-2013 05:42 PM
