Old 05-05-2015, 01:34 PM   #1
Frishkorn
Hi everybody!
Frishkorn's Avatar
Drives: 14 Whiteout FRS 6M. 16 Abyss iA 6A.
Hood travel at high rates of speed.
Does anyone else notice their hood travels up and doesn't sit flush when moving at high rates of speed? I didn't really drive the car spirited before I installed my intake. I'm worried that with all the new room the engine bay has, that airflow is coming in from the front and pushing upwards.
If you do have this problem, were you able to fix it? I was wondering if struts might help hold it down. Last thing I need to worry about traveling 130+ MPH is my hood flying into the windshield when I'm on the track.
Frishkorn is offline   Reply With Quote
Old 05-05-2015, 01:39 PM   #2
gramicci101
Off Topic
This happens with the OEM intake too; I think the culprit was determined to be the seal at the leading edge of the hood was too soft. For me, crosswinds make it worse. Your hood isn't going to come off though.
The Following User Says Thank You to gramicci101 For This Useful Post:
Frishkorn (05-05-2015)
Old 05-05-2015, 01:39 PM   #3
adamg
Drives: brz
lol
adamg is offline   Reply With Quote
Old 05-05-2015, 01:46 PM   #4
Frishkorn
Hi everybody!
Frishkorn's Avatar
I was worried that the back-up latch might give out eventually and the hood would fly back into the windshield since it will freely travel all the way up.
That being said, I'd still like it to sit flush at high rates of speed. Guess it's time to do more research and figure out how to keep it from doing it.
I guess I could always do what I did with my 1970 Chevelle. Just install hood pins.
Old 05-05-2015, 01:50 PM   #5
gramicci101
Off Topic
It's not popping up to the backup latch; there's just a little play in the primary latch. I think I read that you can adjust the primary latch downwards to compensate, but you should do some research into that before assuming that I know what I'm talking about.
Old 05-05-2015, 01:57 PM   #6
Scott@HKSUSA
Scott@HKSUSA's Avatar
Drives: 2013 FR-S, HKS V2 S/C
If you're planning on driving like that, may I suggest a pair of hood pins?
A little play in the hood latch is normal and nothing to worry about at legal speeds.
Scott@HKSUSA is offline   Reply With Quote
The Following User Says Thank You to Scott@HKSUSA For This Useful Post:
Frishkorn (05-07-2015)
Old 05-05-2015, 02:22 PM   #7
vroom4
The car has a ton of play in the hood, it constantly worries me
vroom4 is offline   Reply With Quote
Old 05-05-2015, 03:06 PM   #8
Digitalanalog
Drives: '13 BRZ Limited, '95 BMW M3
Manufacturers are required to have the hoods to be double locked to prevent it from accidentally popping up. With how light the OEM hood is and the effect of high and low pressure zones will cause it to move.
Digitalanalog is offline   Reply With Quote
Old 05-05-2015, 03:13 PM   #9
GotBRZ1691
GotBRZ1691's Avatar
Drives: 2014 Subaru BRZ Limited 6smt
I just noticed this too, about a month ago. There is a lot of play and travel but it has yet to break off. I hit 100+mph 3 or 4 times a week
GotBRZ1691 is offline   Reply With Quote
The Following User Says Thank You to GotBRZ1691 For This Useful Post:
Old 05-05-2015, 03:40 PM   #10
cycleboy
Drives: 2013 Scion FR-S - Argento
I drive in high winds frequently and see it bouncing against the latches and that's at normal highway speeds.
cycleboy is offline   Reply With Quote
Old 05-05-2015, 07:30 PM   #11
stevesnj
stevesnj's Avatar
It's an aluminum hood
My 2016 Build thread
Old 05-05-2015, 08:04 PM   #12
I haven't noticed the hood rising at 130 mph, ...... but, the next time I take off ...... I'll check it out .......
Frishkorn (05-07-2015), Ultramaroon (05-09-2015)
Old 05-09-2015, 12:56 AM   #13
zman
zman's Avatar
Drives: scion frs
Mine is the same way and when I washed my car today I noticed water getting inside the hood and made on of my hids burn out
zman is offline   Reply With Quote
Old 05-10-2015, 01:38 PM   #14
SpidyJ
Drives: 2013 FRS
Mine flutters near the hinges over 100 mph. A little nervewracking..
SpidyJ is offline   Reply With Quote
High RPM for current speed HachiRo Engine, Exhaust, Transmission 14 04-02-2015 03:59 PM
FL = no insurance with no car + high rates?!! VeezyF Southeast 50 07-20-2014 02:11 AM
Hood flutter at high speed TheseColorsDontRun Suspension | Chassis | Brakes -- Sponsored by 949 Racing 20 09-10-2013 11:39 AM
Brakes unless at high speed - what to tackle? empower-auto Suspension | Chassis | Brakes -- Sponsored by 949 Racing 44 10-12-2012 06:06 PM
Video: BRZ / FR-S High Speed Run to 124 MPH (200 km/h) Levi BRZ Photos, Videos, Wallpapers, Gallery Forum 43 05-16-2012 01:37 AM
