Old 05-03-2015, 07:12 AM   #15
ajc209
Drives: GT86 Cosworth
TMG list the oil cooler as optional. I this running a thicker oil is the way forward. TRD japan also recommend a heavier oil.
Cirtainly a 10W60 will keep pressures up!! It might be okay for me to use a 10W40 as my car is garaged and generally comes out with oil temps greater than 0C.
The oil pump is fixed flow (except when pressure relief is open). Pressure is determined by resistance in the system. More resistant (for example smaller bearing clearances) with give more pressure but the pump will guarantee flow unless the relief valve is active.
ajc209 is offline   Reply With Quote
Old 05-04-2015, 01:54 AM   #16
churchx
churchx's Avatar
Drives: 2014 GT86
offtopic
@bur****jp: thanks for linked doc. I noticed many interesting bits in that document. Like race ecu update, Thermostat opening temps, diff final gear ratios, diff oil cooler, custom headers & twin pipe catalysator exhaust system which is homologized (wonder if it's street legal on stock twins?), lightweight windows, billstein shocks, specific rollbars/struts and so on .. wondering if something from that can be ordered/fitted on our cars especially exhaust system/ecu..
Old 05-04-2015, 03:53 AM   #17
steve99
Drives: FT86
Originally Posted by churchx View Post
offtopic
I dont think the ecu would be physically different, it will just have different rom to suit exhaust maybe some other tweaks, just need somone to pull rom from one of those with tactrix or similar device.
Old 05-04-2015, 04:53 AM   #18
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Originally Posted by rice_classic View Post
The solution brings me back to the shim in the PRV
Is there a trade off with doing this? Too high a pressure when cold?
Old 05-04-2015, 05:05 AM   #19
ajc209
Yes!
Pressures are quite high cold as it is really. At 100C on 0w20 it gives a perfect 10psi/1k so thicker oil is too a compromise....
The Following User Says Thank You to ajc209 For This Useful Post:
rice_classic (05-04-2015)
Old 05-04-2015, 12:24 PM   #20
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
Originally Posted by ajc209 View Post
Yes!
You're right, however he was asking about pressure at cold. I can't answer this definitively. The reason is that on the cars where I've shimmed the pump, I've only witnessed a small increase in pressure at start up @ idle when cold.
A small shim (small pressure bump) and a 0w-30 may be an excellent compromise for double duty (track/DD) car. But shim or no shim, it's always, ALWAYS, best to let your car warm up before you rev it high or drive it hard.
SCCA T4 - FRS
The Following User Says Thank You to rice_classic For This Useful Post:
DustinS (05-04-2015)
Old 05-04-2015, 12:57 PM   #21
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
Things just keep getting interesting in the oil department.
I am interested how everyone is getting the oil so hot. I can drive around spirited in 80F and only hit 180F oil temp. I am seeing people hit 220F on their drive to work.
What I am reading is to bump to 0w-30, shim the pump, and watch temps/psi. Sound correct?
Old 05-04-2015, 01:28 PM   #22
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
Are you tracking your car? If not you don't need to do anything at all, stick with the factory recommended 0w-20 and enjoy years of trouble free reliability. Under track conditions it's pretty easy to push a stock car into the 280* range.
Decay107 is offline   Reply With Quote
The Following User Says Thank You to Decay107 For This Useful Post:
rice_classic (05-05-2015)
Old 05-04-2015, 01:43 PM   #23
subielife
Subaru Ambassador
subielife's Avatar
Drives: 13 BRZ 18 Silverado
My car is a track car only. No oil cooler and it has been on track since it was 70 miles old. Currently has header, no cats and a Borla exhaust, intake, tune, suspension, all the usual sutff. Running 0-40 Castrol Edge I can guarantee that the oil will be between 248-257º, depending on ambient temp. Other BRZ/FRS guys see higher temps than I do, I have been doing this for a long time, I am not kind to my car. Oil pressure never drops below 50 psi. Will I spin a bearing eventually? Probably, but the car has 14,xxx miles so far and I just doesn't seem to care what I do to it. I might go up a grade on the next oil change to see what happens. I personally don't think doing 20 minute DE sessions under these conditions is doing much harm. Racing would be a different story.
subielife is offline   Reply With Quote
Old 05-04-2015, 01:55 PM   #24
DustinS
DustinS's Avatar
I plan on 2-3 track days this year, Auto-X (once I get weekends off), and many spirited "Canyon" Runs.
Old 05-19-2015, 03:30 PM   #25
sickmint79
Drives: bmw
interested in thoughts and comments on my post in the forester oil cooler thread - http://www.ft86club.com/forums/showp...&postcount=474
the data is from multiple track events, i will note the above cruising on the highway i can get there, even with this oil cooler (vid in link)
PointMeBy - auto enthusiast / 86 / car blog - https://www.pointmeby.com
IGoByPlane - travel/credit/auto experience blog - https://www.igobyplane.com
sickmint79 is offline   Reply With Quote
Old 05-19-2015, 03:51 PM   #26
DustinS
DustinS's Avatar
I actually found that my oil temp gauge(tapped into the galley plug) read anywhere from 20°-48°F cooler than my OFT reports. I cruise at 210°
The Following User Says Thank You to DustinS For This Useful Post:
flippy (05-15-2022)
VIDEO - Install guide for OEM style coolant loop Oil cooler. The Sentinel DIY (Do-It-Yourself) Guides 44 10-15-2018 09:42 AM
DIY Cusco Spin Turn Knob Installation - Video Guide Alex DIY (Do-It-Yourself) Guides 25 08-02-2015 04:03 PM
Video guide - Installing BlackVue DR550GW-2CH and T-Power C UPS The Sentinel DIY (Do-It-Yourself) Guides 8 02-12-2015 12:09 AM
Plot your oil pressure vs temperature Gords_zenith Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 04-22-2014 07:09 PM
DIY 6000K HID Kit Installation(Scion FR-S ONLY) - Video Guide Alex DIY (Do-It-Yourself) Guides 10 07-09-2013 08:38 AM
