Old 05-02-2015, 08:51 PM   #43
Albaro08
Albaro08's Avatar
Drives: Frs asphalt Grey
Idk if they removed the header becuase I don't think they had to change anything there but what I belive it that the impact made the header move o so slightly becuase I grabbed it and shook it forcefully and I imagined to myself if I can shake it and it move what would the impact had done so that where the leak I belive was started hopefully they can oder and and I'll be ok becuase I'm not changing headers until I turbo and that won't be till next year and inspection should be next year in January
Albaro08 is offline   Reply With Quote
Old 05-02-2015, 08:52 PM   #44
Albaro08
Albaro08's Avatar
Any leaks at header connections or 02 sensors will cause problems, the shop probably re used the old gaskets when they removed exhaust, reused gaskets always leak
Old 05-04-2015, 06:48 PM   #45
Albaro08
Albaro08's Avatar
Found the real culprit it's the fuel air ratio sensor wasn't sending a signal it's bad so my dealer is replacing it under warranty they are keeping her overnight
Old 05-04-2015, 10:58 PM   #46
86Tony
Drives: 2015 AOZORA EDITION
That's ok then hope all goes well for you.
86Tony is offline   Reply With Quote
Old 05-04-2015, 11:08 PM   #47
Albaro08
Albaro08's Avatar
traction light, engine light = cam sprocket , ecu nivek111070 Issues | Warranty | Recalls / TSB 27 03-13-2016 10:28 AM
Abs and Traction Light nabil_frs Issues | Warranty | Recalls / TSB 14 07-09-2015 10:39 AM
Check engine light on but no codes!?!? midnight23 Engine, Exhaust, Transmission 9 08-01-2014 12:20 PM
CEL ABS and Traction Light DieselxIndustry Issues | Warranty | Recalls / TSB 3 01-31-2013 02:04 PM
ECU & Slip light p0015 ~ p0019 error v3rgil AFRICA 48 11-09-2012 05:09 PM
