#2633 | |
-mike |
| The Following User Says Thank You to AZP Installs For This Useful Post: | CSG Mike (04-22-2015) |
#2634 |
A physical splitter cable (ie one that doesn't have a CAN bus hub in it) will only stand a chance of working if one device is using CAN bus protocol and the other is using the OBDII protocol (so then they are using different pins). I don't know much about the P3, but the Solo DL can be configured to read the car as a generic OBDII device. The data rate and fields kind of suck, but you might give that a try if you really really want to use both. At the same time, if the P3 can be configured to run as a generic OBDII device then you might be able to use the Solo DL with the normal 86 configuration.
Fun car leads to autocross, autocross leads to track days, track days lead to lemons, lemons leads to racing school, racing school leads to spec Miata...
No idea where it leads next! |
#2635 | |
#2636 | |
As I said: "The data rate and fields kind of suck" Really, if you want gauges and such from the ECU while getting data logging, you are looking at a higher product line than the Solo DL (or trying out a CAN bus hub).
#2637 | |
![]() Mike |
#2638 | |
I do wish the AIM had a screen like the V3 AP, which shows peaks and valleys, as well as current. |
#2639 |
Drives: 2014 FR-S 6MT Monogram Series
just picked up a set of enkei rpf1's. want to get some lugs for these wheels. can anyone suggest what is good and tested on track that i can pick up since i will be tracking beginning of next month and need to get them soon. I want to get the CSG lugs but they are all sold out so any suggestion would help please.
Also do you guys recommend using hub rings for racing or not? I was thinking of picking up aluminum hub rings for racing? |
#2640 | |
Do you have any alternate choices for lug nuts? -Mike |
#2641 | |
I was thinking of either EVS Tuning "Super Lap" Racing Lug Nuts, WedsSport Competition Lug Nuts, or Muteki SR35 Lug Nuts but from what I read they say Muteki is no good for track. Can you suggest something that would be good for racing and reliable. |
#2642 | |
The WedsSport lugs are great, and we have them in stock. I've heard good things about the EVS lugs as well. |
#2643 |
#2644 |
Drives: 2013 Subaru BRZ Limited (WRB)
Question on DBA T3 rotors. Installed them a week ago and it's been fine, but I've noticed some pretty serious discoloration all of a sudden today. Might be surface rust, not sure yet. But man...it's pretty bad. I drive the car daily, and took it to work and back. Pulled the wheels off to start my JR Oil Cooler install and saw this. Seems odd. This is with the OEM pads, I keep the Carbotechs for track only. These babies were super bright and shiny yesterday.
Your thoughts? ![]() ![]() I'll get better photos with my DSLR if necessary. Thanks! |
#2645 | |
Just keep driving and they'll eventually mate themselves. -Mike |
#2646 | |
The pads not mated to the surface of the rotors yet accelerates surface rust? Sorry if this is pretty basic. Road america in a week and a half and in a scramble to get everything done in time.
| Simple question, hard to find answer... | Mango22 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 05-16-2013 06:23 PM |
| Silly question about protecting track rims | sw20kosh | Tracking / Autocross / HPDE / Drifting | 16 | 04-25-2013 12:34 PM |
| Asking the question that I already know the answer to. Are the engines the same? | Bigmaxy | Engine, Exhaust, Transmission | 10 | 01-19-2013 07:47 PM |
| Random dog-related question for those who have their BRZ | GMU-BRZ | BRZ First-Gen (2012+) — General Topics | 11 | 05-31-2012 07:48 AM |
| Got my answer - BRZ comes with HID headlights as STD | Z_Rocks | BRZ First-Gen (2012+) — General Topics | 20 | 01-10-2012 09:54 AM |
