#127 |
They're Subarus...you can go back to a 1993 Impreza on some of these parts.
![]() But you probably shouldn't use the same damper cartridge for EVERY CAR EVER MADE like some do. Our R&D is a little bit more involved thanks to the capabilities of our partners. ![]() - Andy |
| The Following 3 Users Say Thank You to Racecomp Engineering For This Useful Post: |
#128 |
| The Following 4 Users Say Thank You to Kostamojen For This Useful Post: | CSG Mike (04-16-2015), Hyper4mance2k (04-16-2015), Racecomp Engineering (04-16-2015), wparsons (04-16-2015) |
#129 |
Thats what you would think, but if you look at specific tire specs some are lighter as 16's and others are lighter as 17's. Depends entirely on the specific tire.
#130 | |
![]() Now, carry on, I like this discussion! |
| The Following User Says Thank You to CSG Mike For This Useful Post: | wparsons (04-16-2015) |
#131 | |
That Guy
Drives: 2013 asphalt FRS MT
The sway bars are front biased, the stock spring rear biased. I'd imagine if one were to remove both sway bars they would want to change the spring bias to compensate. |
#132 |
Taking this thread to the next level.......
If no sway-bar is good, how about no springs up front. Hell why not take out the whole strut? Think of how planted the car would feel. |
#133 |
BAZINGA!
Drives: 15 FR-S
#134 | |
Hail Magnet
#136 |
Drives: Subaru BRZ 2013
| The Following 2 Users Say Thank You to BRZChix For This Useful Post: | *Hachiroku86* (04-17-2015), Koa (04-16-2015) |
#137 | |
BOXER FR
Drives: WRB BRZ Limited
Build Thread of the "STI theme BRZ"http://www.ft86club.com/forums/showthread.php?t=61522
| The Following User Says Thank You to mokinbird87 For This Useful Post: | KoolBRZ (04-17-2015) |
#138 |
Drives: Silver 2013 BRZ Ltd Auto 45,000 mi
My front sway bar is back on now, and my rear sway bar is removed. I also have my summer setup installed right now, HKS Hypermax GT IV 6K front 4k rear with 3" helpers on the rears. I'm learning the importance of preload right now, and adjusting the dampening to get the best compromise.
| The Following User Says Thank You to KoolBRZ For This Useful Post: | Koa (04-16-2015) |
#139 | |
Drives: 86
OK , suspension tuning is a huge system that the drifters or modification use it to adjustment rolling and driving feel and allowed us to get better way to control the car. as we know there are two ways the car jumps to while driving it at corner , one of it is under-steering and other one is over-steering . there are many things effect in both things like tire pressure at front and rear tires , Width of the car from the front and the rear with driver, Width of the tires ,tire Aspect Ratio , tire Section Width , tire tread depth , wider and lighter wheels , camber , toe , caster , Anti-Sway bars , Spring rates , Shock absorbers , Suspension Bushings , Brake Proportioning , Aerodynamics. check http://www.northursalia.com/techdocs...ver-under.html so to get the right balance you need a lot of time and tests . top gear fun [ame="https://www.youtube.com/watch?v=zoICf55jED8"]Top Gear Understeer and Oversteer explained - YouTube[/ame] [ame="https://www.youtube.com/watch?v=L0_w3C840uw"]Car Control: Oversteer, Understeer and Braking (What to do in emergency situations) - YouTube[/ame] |
| The Following User Says Thank You to aagun For This Useful Post: | KoolBRZ (04-17-2015) |
#140 | |
FRS 2.3k * 0.95^2 = 2.09k 3.8k * 0.75^2 = 2.14k BRZ 2.7k * 0.95^2 = 2.44k 3.5k * 0.75^2 = 1.96k Factor in the front bias from the sway bars and overall it's front biased on both cars.
| The Following User Says Thank You to wparsons For This Useful Post: | Calum (04-17-2015) |
| Say no to SWAY with our Anti-Sway Bar and Sway Bar Bushing Special. | FRSport.com | Brakes, Suspension, Chassis | 0 | 01-23-2015 12:38 PM |
| FS:NY RCE Anti-roll/Sway Bar kit $250 | snky_snky | Brakes, Suspension, Chassis | 2 | 08-19-2013 09:42 PM |
| FS: NY RCE Sway/Anti-roll bar kit $250 | snky_snky | Engine, Exhaust, Bolt-Ons | 2 | 08-18-2013 12:09 PM |
| ST Suspensions Lowering Springs & Anti-Sway Bars Now Available @ BMS! | Boston Motorsports | Brakes, Suspension, Chassis | 84 | 07-23-2013 11:42 PM |
| How to pick anti-sway bars | FastLane1000 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 19 | 07-12-2013 05:06 PM |
