Old 04-13-2015, 08:34 PM   #1
Maxwell
Maxwell's Avatar
Drives: 2015 Subaru BRZ Limited 6MT
Question 2015 Suspension Differences (BRZ and FR-S)
Is it true that the 2015 BRZ and 2015 FR-S now have the same suspension? I've found threads on how they've changed. I have not been able to find particular details on the specifications.
Maxwell is offline   Reply With Quote
Old 04-13-2015, 10:48 PM   #2
wparsons
wparsons's Avatar
I don't think anyone has 100% confirmed, but the consensus is that both cars got new shocks but the spring rates are unchanged.
flickr
Old 04-13-2015, 10:52 PM   #3
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
What shocks did they switch to? I think the old ones were made by Showa.
smg1138 is offline   Reply With Quote
Old 04-13-2015, 11:28 PM   #4
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
The rumors were that they were switched with Sachs dampers. Although i havent heard anything to either prove or deny that.
Old 04-14-2015, 01:07 AM   #5
Maxwell
Maxwell's Avatar
Are you able to confirm that the spring rates have remained unchanged?
Old 04-14-2015, 11:41 AM   #6
wparsons
wparsons's Avatar
Not to be an ass, but did you read the post you quoted? That has your answer already.
You could try calling Subaru to see what part numbers are on 2014 and 2015 springs. If they changed them, there will be a new part number.
flickr
Old 04-15-2015, 11:55 AM   #7
fasteddy
http://www.ft86club.com/forums/showt...015+suspension
fasteddy is offline   Reply With Quote
Old 04-15-2015, 04:14 PM   #8
shellslinger
Drives: Whiteout FRS
if you already have a frs just buy coil overs
shellslinger is offline   Reply With Quote
Old 04-15-2015, 04:38 PM   #9
wparsons
wparsons's Avatar
Based on his profile, he has a 2015 BRZ (it shows up right under his avatar).
Also, jumping straight to coilovers without reasoning is terrible advice. Coilovers aren't automatically better, and if you don't know what you're doing with adjustments you can make the car handle much worse than stock (even with high quality coilovers).
flickr
Old 04-15-2015, 05:57 PM   #10
Poodles
Drives: 2015 Series.Blue
This. Most cheap coilovers are just that, and ride like garbage. But if you just want to dump your car and become part of the stance crowd they're fine...
My car rides quite nice for being so light, doubt I'd mess with it unless I went to $2K+ coilovers or the tS setup.
Old 04-17-2015, 06:21 PM   #11
Maxwell
Maxwell's Avatar
I read your post. I cannot assume what you said is correct without proof.
Old 04-17-2015, 07:51 PM   #12
Maxwell
Maxwell's Avatar
I would like to swap my factory springs with TRD lowering springs. I have one concern. The TRD lowering springs are described to work on the factory struts of the FR-S. I'm worried that there could be a compatability issue in regards to performance if installed on my BRZ. What do you think?
TRD Lowering Springs
http://www.trdusa.com/parts-detail.h...categories=all
Old 04-17-2015, 08:30 PM   #13
swarb
I think you are worrying to much. There isn't really much difference. Trd springs are really nothing special.
C'mon Takumi! a Tach doesn't give you hp!!
Old 04-17-2015, 08:51 PM   #14
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Almost every single part can be used interchangeably with these two cars, they are that alike.
suspension springs struts
2013 VS 2015 BRZ Suspension changes fasteddy Suspension | Chassis | Brakes -- Sponsored by 949 Racing 28 03-30-2017 04:07 PM
2015 Engine differences nikitopo Engine, Exhaust, Transmission 112 02-15-2016 06:27 PM
Anyone have specs on differences btw 2014 and 2015 FR-S jeepmor Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-25-2014 04:54 AM
Two reviews of the 2015 up - handling differences noted Sport-Tech Scion FR-S / Toyota 86 GT86 General Forum 56 08-13-2014 01:22 PM
Quantitative report of BRZ/GT86 suspension differences Sport-Tech BRZ First-Gen (2012+) — General Topics 48 05-19-2013 01:00 PM
