#8555 |
Drives: 2013 FRS
The Procede output is 0v until a certain throttle threshold (~under 50% pedal input). So driving "normally" is all this required for the first 10 seconds.
#8556 |
Drives: 2014 GT86
I wonder if it's not worth it to progam in tune for first 10sec to not open throttle > 50%? Or better limit throttle position reporting to SC in other ways, if doing that in first 10sec is bad. Humans make mistakes. Imho simpler to automate not letting them commit mistakes. I can imagine not that often but possible situation of stalling in crossroad on doing left turn/waiting for oncoming traffic to clear, and needing to quickly start engine and leave stationary position at WOT as soon as possible.
#8557 | |
Lightning McQueen Driver
Drives: Limited Red 6MT BRZ
For any of those situations just shut off the esc. Not a big deal.
Installed Mods: Phantom Electric Super Charger | Open Flash Tune | Perrin OP/ HFC Front pipe | Invidia Q300 catback | ST Suspension | JDL Header | Flex Fuel |
#8558 |
Some Dumb Guy
Drives: wanting an Acabian
Still wish to catch a ride in a twin so equipped. The closest that I knew of (Milwaukee) sold his and went full time FI.
She said it was her or the car. Longest
she had ever seen. |
#8559 |
I would like to see the rev 2 kit with the Procede controller
#8560 |
Time Traveller
#8561 |
Drives: Hot Lava
So I'm started on installing the kit I just received. I'm not sure if I got the alignment correct for the ESC. It looks off center and pointing a bit down. It felt like the silicon tube provided for the throttle body was a little bit short or maybe I installed it wrong.
Also is the fuse suppose to stick out higher than the others, am I not suppose to be able to put the fuse box cover back on? ![]()
#8562 |
Full throttle Electric Supercharger Build Thread
Looks off to me too, and I'm not able to easily access my car at the moment to check the differences. Can you take a picture of your air box? Also on the fuse. You can close the cover just have the wire side stick out towards the edge.
#8563 |
Figured it out. You have the tube for the throttle body covered on both sides. You need about .5 inches of aluminum showing. It should fix everything. Between the two clamps. As seen here: Attachment 106952
#8564 | |
Drives: Hot Lava
![]() Do I need to push the fuse in more or does it stick out like this:
#8565 | |
Drives: Hot Lava
#8566 | |
Time Traveller
I cant see your pics, but the fuse does stick out a bit more than the others. You'll know its in all the way when it wont go in any further and if the ESC turns on when the car is turned on. |
#8567 | |
Drives: '16 WRX, CBR1000RR
Phantom ESC'd Build Thread (Retired):http://www.ft86club.com/forums/showthread.php?t=75293
#8568 |
Drives: DGM BRZ 6MT
Does the procede controller only tap into the ESC system or does it tap into other wires in the car as well? How easy would it be to uninstall the ESC kit with the procede controller tapped into the car?
| Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras | Circuit Motorsports | Member's Car Journals | 4 | 03-21-2013 04:45 PM |
| Subaru BRZ : Full Throttle, powerslide, hard revving & ride | ESBjiujitsu | BRZ Photos, Videos, Wallpapers, Gallery Forum | 20 | 05-30-2012 06:43 PM |
| 86 Full Throttle Video + another. | Aus86 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 2 | 04-02-2012 07:07 AM |
