steve99
Old 04-12-2015, 05:37 AM   #309
Kodename47
Kodename47's Avatar
Drives: UK GT86
Originally Posted by DocWalt View Post
Neat, I just ran through the process on that. Thanks! That should let me kill the AFR dip and spike after I get some fresh logs with the tweaked scaling. Hopefully I see some good results from that. Not sure what it is in my setup causing the dip and spike, but ok.
To make sure you're getting good results I would ensure adjusting after multiple logs rather than by each log. Delete out the run data (error and count) I left in there, I only used that to test it. You may need to correct your table load axis of you're having specific issues as reducing the range to 20% will Remove data too far away from the axis values to ensure the table is accurate.
.: Stealth 86 :.
Kodename 47 DJ:
DocWalt (04-12-2015)
Old 04-12-2015, 11:47 AM   #310
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Yeah, I'm going to red a lot more data, from four logs yesterday I got about ten cells with over 5 counts. Thanks again for the help!
Old 04-29-2015, 11:40 PM   #311
PugetSounds
Drives: Ultramarine GT86 (Scion)
Probably a dumb question, but I cant seem to find the answer in this thread. once I download the Takeda Scale file, how do you open/use it to edit your rom in Romraider?
Example: running the Greddy momentum/takeda intake with a OFT trying to make a MAF scaled 91 Octane tune as well as a MAF scaled stock tune
PS- First time working on an engine without a carburetor...
PugetSounds is offline   Reply With Quote
Old 04-30-2015, 02:22 AM   #312
steve99
Drives: FT86
this stuff is easier than carburettors :-)
have a read of romraider tip link below , romraider site has info on howxto install and use romraider.
romraider allows you to edit your rom using a definition file, which is an index into the hundreds of tables in the rom.
you need to edit the MAF scale table.
Old 05-01-2015, 12:21 AM   #313
PugetSounds
Thanks. I've read up on romraider, installed it, familiarized myself with it somewhat, loaded the correct OFT definition for their v1.59 91 octane tune for the US 6MT, loaded the stated rom, and am just trying to use the scaling for the takeda afe intake that your provided earlier in the thread, I just dont know how to open the scaling file or use it to edit the MAF scale in romraider. I plan on doing some data logging and further fine tuning due to being at sea level after I get the initial scaling (using steve99's file) done as a good starting point.
Any help is appreciated, as I'm stumped on what program to even open the scaling file with.
Old 05-01-2015, 12:53 AM   #314
steve99
Drives: FT86
its a zipped excel file, unzip with winzip or similar then use microsoft excel for scaling file, then just copy/paste into romraider maf scale table
your using old oft tunes the latest tunes V2.06 have many good updates
base takeda scale here.
Volts Flow [Table2D]
0.90 0.85
0.94 1.14
0.98 1.32
1.02 1.63
1.05 1.81
1.09 2.07
1.13 2.30
1.17 2.59
1.21 2.91
1.25 3.28
1.29 3.57
1.33 3.92
1.37 4.25
1.41 4.60
1.45 5.02
1.48 5.53
1.52 6.22
1.56 6.56
1.60 7.30
1.64 8.04
1.68 8.46
1.72 9.21
1.76 9.96
1.80 10.67
1.84 11.53
1.88 12.51
1.91 13.43
1.95 14.28
1.99 15.19
2.03 16.34
2.07 17.13
2.11 18.03
2.15 19.25
2.19 20.99
2.23 21.96
2.27 23.61
2.30 25.00
2.34 26.01
2.38 27.77
2.42 29.28
2.46 30.51
2.50 32.44
2.58 35.83
2.77 44.93
2.97 52.63
3.20 67.31
3.44 84.04
3.71 107.81
3.91 129.06
4.06 141.59
4.30 169.31
4.49 197.00
4.73 234.25
5.00 290.26
Old 05-01-2015, 01:07 AM   #315
PugetSounds
Thanks so much man.
Old 05-01-2015, 01:13 AM   #316
steve99
Drives: FT86
Thanks so much man.
If you change tunes from V1.5x to V2.06x then make sure you use the definitions for the V2.06x tunes not the old ones from V1.5x.
Al also remove the old defs from romraider else it may use the old defs.
Old 05-01-2015, 01:54 AM   #317
PugetSounds
Will do. good looking out bro.
Old 05-07-2015, 12:05 PM   #318
Silver Ignition
APEXHNTR
Silver Ignition's Avatar
Drives: 10 Series FR-S #1867
this thread is TL;DR so if someone can answer this quick question for me...
Using Grimmspeed intake, have the GS Stage 1 93oct tune.
I'm assuming I can't just copy the MAF table to my Stage 2 e85 tune correct? Would I have to do the scaling manually for e85?
2013 Sc10n FR-S 10 Series
#1867 of 2500
in the garage...2001 Toyota 4Runner [Solid Axle Rock Toy], 1987 Pontiac Fiero GT [Shitwagon], 2004 Honda Interceptor VFR800 [daily rider], 1978 Suzuki GS750 [Café Racer]
Silver Ignition is offline   Reply With Quote
Old 05-07-2015, 12:17 PM   #319
Koa
Don't let your laziness or inability to research a pretty plain jane topic blow your engine up. The Stage 1 G/S maf scale is for fucking petrol.
Use the stock Stage 2 E85 tune with your G/S intake. The maf position and scale is 1:1.
I can send you my Grimmspeed Intake + OFH e85 tune, which addresses a little bit of tip in and fuel trim variance to PNW E85. Use this at your own risk, however, as E85 can be wildly varied between regions, carriers, even same-carrier different-day environments. This precipitates the want for a flexfuel setup if one is running corn juice competitively or with any long-term, high spirited driving use. GL
Old 05-07-2015, 12:24 PM   #320
Silver Ignition
APEXHNTR
Jesus chillax brother, I never said thats what I intended to do, just asking for some clarification.
I will use the GS tune for 93 and the OTS Stage 2 e85 for e85.
#1867 of 2500
Old 05-07-2015, 12:34 PM   #321
Koa
I'm not screaming at you, am I? I'm perfectly calm. Just asinine you expect people to spoon feed you while you toy with very serious parts of your engine that you apparently don't have the time or want to learn about. Consider yourself fed!
Old 05-11-2015, 09:12 PM   #322
drift86
Drives: GT86, 22 BRZ
I have a Takeda intake and I tried to do MAF scaling using the CSV file from the first post.
My LTFT was way off after doing this. (-16%)
http://www.datazap.me/u/drift86/maf-...log=0&data=1-6
LTFT was much more stable when using the standard stage 1 OTS v2.06 tune. (-4%)
http://www.datazap.me/u/drift86/stag...log=0&data=1-5
Maybe there are different versions of the Takeda intake and they scale differently? Mine is the newer version with the longer snout and I was running without the snorkel.
Old version:
http://www.tr3performance.com/wp-con...afe-intake.jpg
Newer version:
http://cdn.shopify.com/s/files/1/019...x1024.jpg?1279
drift86 is offline   Reply With Quote
AFR in Closed Loop Toyota John Software Tuning 39 07-07-2019 09:26 AM
BRZedit Fuel Trims, Closed to Open loop transiton mad_sb Engine, Exhaust, Transmission 32 08-06-2015 04:14 AM
Notes on injector / maf scalining using full time open loop mad_sb Software Tuning 40 03-03-2014 06:49 PM
Screencast: closed loop boost control with RaceRom jamesm Software Tuning 2 02-10-2014 03:23 PM
Screencast: experimenting with full-time closed loop fueling jamesm Software Tuning 2 12-27-2013 11:19 AM
