#3193 | |
Drives: 2013 Ultramarine FR-S
#3194 |
Drives: 2013 Scion FRS in white out
I'm on the moto East tune... Runs like factory.
2013 Scion Frs AT in Whiteout, Borla UEL header, Greddy SP Elite AxleBack. Kraftwerks C38 Supercharger tuned by Moto East and 2 kid seats in the back.
#3195 |
Drives: 2013 WRB BRZ Sport Tech
does anyone know the thread type on the skunk2 sandwich plate?
#3196 | |
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor |
#3197 |
Drives: '13 FRS
Called Kraftwerks and they said it's because I'm on the base tune and not really "tuned" so who do I go to to tune for central Washington? Lol
#3198 | |
WRX -> BRZ. (TX)
Drives: 2015 Series.Blue WRB
KraftWerks c3094 SC Kit ARK GRiP w/ test pipe KW V3 OEM Audio + Reference 400CF Last edited by Rulin; 04-06-2015 at 07:47 PM. |
#3199 | |
Drives: JDL Turbo FRS, 335SC BRZ (ret)
#3200 |
I have the Radium dual can setup - this was all from the driver's side (crank case vent). The passenger side (PCV) is still bone dry.
Complete Part Out: http://www.ft86club.com/forums/showthread.php?t=125688
#3201 | |
What kind do you typically recommend?
#3202 |
#3203 | |
BoostedBRZ
Drives: Turbo BRZ
With that being said, anyone on here do e85 with the c38??? |
#3204 |
Drives: '13 FRS
I'm in Yakima. I just got the Isis cat back installed last night. So the supercharger and the exhaust is all I've done. With plans for headers and back
#3205 | |
Drives: The silvertrooper 10 series
We have just been testing the car until it does pop, then ill have Skunk rods, valve train and other engine components installed, But I've had no issues other then replacing a belt within the first 1k miles because i was running pulleys way to small and was warned before hand that they would cause the belt not to last, the last 11k miles have been trouble free. On Shawn Church Dynapak it put 417 to the hub. it was rich enough to burn the cat out of the front pipe, and Bill did some more adjustments after that dyno session to add quite a bit more power enough that it would spin the 245 toyo poxes 1 in 4th at over 120mph (mines a auto) I just spent the past weekend on 91 (Moto-East flex fuel kit) and driving back and forth to SoCal and again no issues, 34mpg on the way back. So far I have had nothing but a good experience with my C38 on flex fuel with the higher higher boost pulley. (normal is 95mm, high boost is 90mm, then i asked if they had any other option and they sent me the 85mm pulley) |
#3206 |
Drives: 2013 Subaru BRZ
starting with test fitting of IC, supercharger oil cooler and intake tube with filter tomorrow.
I have to make sure that everything fits combined with a thick ultra skunk2 radiator. What do you guys think of my idea to use jiffy tite couplers on the hoses for the supercharger cooling system? Where I live, tuning cars legally is difficult. So the kit has to come off to pass EU vehicle inspection every second year. I just found out the insane price on the rotrex oil. Quick couplers would avoid loss of oil if I remove the kit. The car will probably be modded more as well. (disassemble kit because of other mods.) It would also possibly not let air in to the system, then I wont have to bleed out air from the system every time. According to the info I can find on jiffy tite couplers, they should not affect oil flow much. Any toughts? Bad idea? Good idea?
English is my 2. language. Typos might occur.
![]() 2013 BRZ, kraftwerks supercharged. Skunk2 Ultra radiator with oilcooler KW v3 - enkei 17x9 with PSS |
| Innovate (Sprintex) Supercharger Owners Topic | DarrenDriven | Forced Induction | 9139 | 12-29-2023 10:58 PM |
| Kraftwerks Rotrex Supercharger Discussion | nelsmar | Forced Induction | 697 | 01-18-2022 12:06 PM |
| All SUPERCHARGER kits compilation thread | subatoy | Forced Induction | 76 | 03-10-2016 12:38 PM |
| Kraftwerks Supercharger?? | umpadupa | Forced Induction | 1 | 08-05-2013 05:27 PM |
