| Software Tuning Discuss all software tuning topics. |
#29 | |
Drives: Scion FR-S/Toyota Yaris
No a lot of people were lied to about ECUtek. Its not scaremongering, its simply answering a question (OP.) All it takes is one more revision to Techstream with an Ecutek identifier and your warranty is gone, no forensics, been done many times by many OEM's. Do a little homework and try to help people.
2013 FRS Argento Silver 6MT
Mods: Clear fender side lights Tactrix ZA1JB01C 2014 Calib |
#30 | |
Grip>Slip
You're talking in could be, might be and maybes over there. That hasn't happened yet and there are no indications that it will happen. So, yeah, scaremongering. |
| The Following User Says Thank You to xjohnx For This Useful Post: | cuddefred (09-13-2013) |
#31 | |
PhoneFlash by EcuTeK
When the BRZ/FRS ECU is reflashed back to stock. It is as stock as it is going to be with the EcuTeK License built into the ECU ROM. You can even reflash it with other systems and this goes for all makes and models EcuTeK offers their tuning system for. So when the dealer reflashes the ECU all they are doing is writing over the current map in the ECU and of course this wipes the EcuTeK License within the ECU. Currently there is no way for the dealer to determine if the ECU has been reflashed if you have a stock EcuTeK map on the ECU. Cheers, William Knose |
#32 |
#33 |
to expand on this... anyone who says that you can't tell whether a file is stock or not simply doesn't understand computer science. if you have two chunks of information and you need to tell if one == the other, this is always possible. it would be incredibly easy for anyone with the motivation to pull your rom, grab a block of data they suspect you may have changed (a fuel table or something), hash it, diff it, and see if the two are the same. it's really not rocket science, and anyone who suggests that ecutek or any other flashing mechanism somehow protects users from this is just wrong.
if you can get data, and you have some other data you need to diff it against, this can be done, bar none. implementing a tool to allow dealers to do this would be trivial. so yes, if they want to know, they can. whether or not they'll go through the trouble is another question, but it absolutely can be done. |
| The Following User Says Thank You to jamesm For This Useful Post: | juliog (09-16-2013) |
#34 | |
SLO NO MO
Subaru/Toyota can tell, and everyone has agreed on that. Dealers with techstream cannot. Sent from my Nexus 4 using Tapatalk 4 |
#35 |
They can't as far as we know, today. The point is just that for them to implement such a thing would be trivial, and if they suspect they're losing money paying out warranty claims they shouldn't be, they'll have every reason to do so. So, long term, your not really 'safe' unless the stock rom you flash back on is exactly, bit for bit, the stock rom that came on the car. With ecutek and possibly brzedit, this is never the case.
#36 |
Drives: 2013 GBS BRZ Limited
Correct me if I am wrong, but I imagine that the ECUtek license data is stored in a portion of the ECU memory that is not normally accessed by techstream.
If you were to dump ALL of non-volatile memory and compare it to a stock dump of ALL memory, you would clearly be able to see the difference and identify the region used by the ecutek license. |
#37 |
Drives: Scion FRS Firestorm
Can someone direct me to the "Stock ECUTek Reflash" file? I have a CEL that requires a dealership reflash. My dealership is very mod friendly and is willing to flash my ECU under warranty if their scanners can gain access to the ECU (currently, they cannot due to ECUTek being locked). Any help would be appreciated.
Please PM me, this is urgent. |
#38 | |
Drives: FT86
http://www.ft86club.com/forums/showthread.php?t=62332 I think ECUTEK will write these stock roms but you may loose your licence or it may re-embed the licence in the ROM. however I believe you should be able to access Ecuteck "stock" roms if you have the licence However if you write the stock roms there with Tactrix its byte for byte stock no difference at all. Last edited by steve99; 06-16-2014 at 11:35 PM. |
#39 | |
Drives: FT86
any freeware hex editor comparator such as FRED attached will do it |
#40 |
Drives:
Sorry to revive an old thread, but how do I flash back to stock with EcuTek ???
My STX build thread
http://www.ft86club.com/forums/showthread.php?t=55616 |
#41 |
Calle Atun
Drives: 13 FRS, 93 Mr2, 85 ae86
Flash one of ECUTEK's stock files back to your ecu with ECUTEK.
| FA20CLUB ecutek flash | mach330 | Software Tuning | 19 | 08-09-2013 11:35 AM |
| ecu flash? | jybrd | Engine, Exhaust, Transmission | 69 | 07-15-2013 04:36 PM |
| DynoComp EcuTek Flash | JRollar | Engine, Exhaust, Transmission | 8 | 01-16-2013 07:16 PM |
| FA20 Stg 2 Ecutek flash or no? | DC-FRS | Engine, Exhaust, Transmission | 25 | 12-25-2012 08:13 AM |
| Why no ECU Flash? | ngabdala | Engine, Exhaust, Transmission | 26 | 09-03-2012 08:27 PM |
