Old 03-31-2015, 06:50 PM   #15
Albaro08
Albaro08's Avatar
Drives: Frs asphalt Grey
do you have standard intake, aftermarket intakes upset maf scaling and ecu cannot compensate accuratly
can you log your tune ?
log fuel trims STFT LTFT
AFR
Commanded AFR
load
rpm
knock correction
FLKC
IAM
hesitation sounds like afr is incorrect or high fuel trims or you getting knock causing ECU to pull timing causing hesitation.
No mods at all all stock got into a accident they put everything together nicely got that like after I drove off the shop took it back no leaks and it hesitates just a tad 3500 to 4200 Rpm I'm putting premium 93 in it all happend after I got it fixed I reset the battery after maybe 20 miles the engine and code comes back on and I get the air to fuel ratio unbalance Sucks bro
Albaro08 is offline   Reply With Quote
Old 03-31-2015, 06:59 PM   #16
steve99
Drives: FT86
Well their is something wrong, maybe an 02 sensor is damaged or hairline crack in exhaust manifold or a leak like damaged hose in intake, but on stock car you should not get those codes.
Take it back or get dealer to check it, the accident repair should cover costs under insurance.
Old 03-31-2015, 07:03 PM   #17
Albaro08
Albaro08's Avatar
Yes but they can't find the problem so I don't know really whats going on I belive they damaged the o2 sensor sense they took the front end up and maybe hit the 02 sensor or something I just feel like waiting until I change headers and all sense on that topic I want to get a tomei uel header but don't know if I would be to use it in the future when I'm ready to go turbo but thanks man appreciate the help I'll dig into it for the last time this weekend
Old 03-31-2015, 08:27 PM   #18
V_86
V_86's Avatar
Drives: 2015 Asphalt FR-S
So your saying it will fix on its own?? Becuase this fucking is driving me nuts especially when I'm in the 4000rpm range the car hesitates a tad
Depends, in this situation if you are having CEL codes, probably not. But in normal circumstances, if you experience hesitation (after mods, changing battery, ect) the ECU will right itself after ~50 miles (that is, learn your driving style).
V_86 is offline   Reply With Quote
Old 03-31-2015, 09:02 PM   #19
Albaro08
Albaro08's Avatar
No mods here yet I was just outside and this little plastic box under the intake tubing after the maf sensor sprayed it with joke and the car almost cut off then I messed around with it apart the little box doesn't have any leaks when I blew un it maybe the Clamp was badly placed put back on then started her back up sprayed it again it didn't act funny disconnected the battery hopefully that fixes it if not I'm done fuck it
Old 04-04-2015, 08:27 PM   #20
Albaro08
Albaro08's Avatar
So no one have any fixes for any of this still getting the air fuel ratio unbalance and hesitation at 3800 to 4200 Rpm and no cruise control
Old 04-06-2015, 11:10 AM   #21
Albaro08
Albaro08's Avatar
P2096-(normal code I get from the header)
You should not get that code after installing header unless you have a leak near o2 sensor / intake leak or damaged 02 sensor.
Code you get for catless header is P0402 (cat efficiency)
Those other two code you had point to intake/exhaust leak or problems with post cat 02 sensor.
If the second 02 sensor is crook or disconnected it will generally cause cruise control to be inoperative but im not sure if it triggers traction light.
Check the plugs on the front/rear 02 sensors are seated correctly they are near alternator at front of motor. They are grey and black coded and the plug and socket colors should match.
Did you get your issue fixed I'm having the same issue but just the air to fuel ratio unbalance and no cruise control
Old 04-06-2015, 06:36 PM   #22
steve99
Drives: FT86
I did not have any problem was just helping the other guy
If you getting air fuel imbalance codes check for intake or exhaust leaks or leaks at O2 sensor dirty maf sensors or damaged O2 or maf sensors
Old 04-06-2015, 06:38 PM   #23
Albaro08
Albaro08's Avatar
If checked for leaks none at all I use choke cleaner and won't see a Flux in the rpms well roughing out. But I'm not sure if that sensor would be messed up I also hesitate at 3500 to 4200 rpms
Old 04-06-2015, 07:33 PM   #24
steve99
Drives: FT86
do you have stock intake ?
if you have aftermaket intake, most will require maf rescale to avoid hesitation and sometimes cel codes due rich/lean conditions.
Old 04-06-2015, 07:36 PM   #25
Albaro08
Albaro08's Avatar
I'm stock everything this all started after the car was at the body shop and that one code popped up I reset but comes back on after 30 miles or so
Old 04-06-2015, 07:58 PM   #26
steve99
Drives: FT86
ok, you will have to keep looking
Old 04-06-2015, 07:59 PM   #27
Albaro08
Albaro08's Avatar
What's the best way to see if it's a vacum leak and then go on from there it's driving nuts becuase my shifts get ugly when at 4k rpm
Old 04-06-2015, 11:13 PM   #28
steve99
Drives: FT86
check connections and hoses on intake carefully. check the maf sensor gasket is not missing or torn or creased.
you could try spraying small amounts of engine start spray near intake connections and see if rpm rises from idle. Just be carefull to to get it on hot exhaust else flash fire.
should rearly be covered by repair shop under insurance or a warantee claim especially since your car is stock
traction light, engine light = cam sprocket , ecu nivek111070 Issues | Warranty | Recalls / TSB 27 03-13-2016 10:28 AM
Abs and Traction Light nabil_frs Issues | Warranty | Recalls / TSB 14 07-09-2015 10:39 AM
Check engine light on but no codes!?!? midnight23 Engine, Exhaust, Transmission 9 08-01-2014 12:20 PM
CEL ABS and Traction Light DieselxIndustry Issues | Warranty | Recalls / TSB 3 01-31-2013 02:04 PM
ECU & Slip light p0015 ~ p0019 error v3rgil AFRICA 48 11-09-2012 05:09 PM
