#127 | |
Drives: FRS 10 Series
I have 20mm spacers that came with no studs up front. Any larger and they only come with studs, trust me I made many phone calls to find that out. I just used the 25mm with studs and pressed out the studs that came in the spacer. Works great and no issues after the 8k miles I have driven since install. |
#128 | |
Drives: 13 BRZ Limited WRB
http://www.motorsport-tech.com/wheel_spacers.html I am using ARP studs with these.
I plan to live forever. So far, so good.
My Build - http://www.ft86club.com/forums/showthread.php?t=31925 |
#130 | |
i had good success with just pounding them back in with a hammer and extension (hammer head is too big to pound them in directly, will hit the hub almost assuredly) Something like this would work too. They are just using a long socket over the stud. This is kinda how i got mine out and in (reverse the process)
#131 |
Who has ever had a bearing fail because they hammered out wheel studs?
#132 | |
but, who knows in 20k or more how much quicker they will fail. I guess i'd rather not deal with that.
#133 | |
Drives: white subaru brz
you stated earlier that you hammered them out yourselves but are now stating that you are not going to risk bearing failure by hammering them out? |
#134 | |
See the above images i posted, if you do that and support the hub by the plate that holds the studs, you will not risk damaging the bearing.
| The Following User Says Thank You to Gopherboy6956 For This Useful Post: | jdmblood (04-08-2015) |
#135 | |
ohh ok thank you for clearing that up. One last question. What are you supposed to attach the blue thing to? The floor? |
#136 |
The vice? A workbench, typically. Or anything solid you can bolt it to.
#137 |
Drives: 1992 Isuzu PuP, 2014 FR-S
Used this tool to remove the studs:
http://www.harborfreight.com/3-4-qua...tor-99849.html Works great, no complaints. Used this tool to install the studs: [ame="http://www.amazon.com/gp/product/B000ETUD22/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1"]Amazon.com: Lisle 22800 Wheel Stud Installer: Automotive[/ame] It's cheaper and more portable than a shop press and safer than a stack of washers. It has a bearing on the side that faces the hub so that it rotates during install. I did notice that a small area of the gold coating on the ARP studs was worn off after install, but the threads look good. |
#138 |
Is it possible to get the brakes off without a power tool? Trying to get them off by hand but the socket doesn't want to buldge
#139 |
Absolutely. Use a breaker bar
#140 | |
Site Moderator
Drives: Stuff
The hub is just a hole, it's not "threaded" so can't be stripped. The knurl holds it in. Too small and it will spin simply because it's too small.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
| The Following User Says Thank You to Dave-ROR For This Useful Post: | Hyper4mance2k (05-12-2015) |
| flush with stock wheels. with Stud installation. | adamturbo | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 43 | 12-10-2012 04:30 AM |
| Wheel stud | Guaruja | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 7 | 10-11-2012 02:42 AM |
| Lug Nut Stud | feldy | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 09-22-2012 10:26 PM |
| Scion FRS center wheel caps replacement? | Silverback | Cosmetic Modification (Interior/Exterior/Lighting) | 10 | 09-03-2012 02:16 AM |
| Are there any RWYB Wheel to Wheel road races? | LexusFman | Other Vehicles & General Automotive Discussions | 1 | 11-05-2011 12:28 PM |
