Old 03-28-2015, 07:14 PM   #225
Boofneenee
Go-Kart Enthusiast
Boofneenee's Avatar
Drives: Toyota Scion FRS
Originally Posted by Chad86 View Post
I am looking at exhaust options for the 335. Should I be running a 3" exhaust setup like one would for a turbo setup for better performance?
you should think about a built motor instead
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels
Boofneenee is offline
Old 03-28-2015, 08:42 PM   #226
sam69
Drives: GT 86
3" would be good (with headers) but as has been discussed above I think one would need to look at the intake side of things as well.
sam69 is offline
The Following User Says Thank You to sam69 For This Useful Post:
Chad86 (03-28-2015)
Old 03-28-2015, 09:03 PM   #227
Chad86
DrivinginDreams...Cloud86
Chad86's Avatar
Drives: Toyota GT86
Thumbs up
I've already got this covered with the Perrin BigMAF 3" CAI
Chad86 is offline
Old 03-28-2015, 09:21 PM   #228
sam69
Drives: GT 86
What about the TB are you using the stock one or an oversize after market ?
sam69 is offline
Old 03-28-2015, 09:51 PM   #229
Chad86
Chad86's Avatar
Drives: Toyota GT86
Was planning to use the stock TB.
Chad86 is offline
Old 03-29-2015, 11:36 AM   #230
smudge
Drives: Supercharged GT86
Only TB I've come across is the Cusco one which is 67mm rather than the 65mm stock TB
smudge is offline
Old 03-29-2015, 01:54 PM   #231
Subzero
Old...
Subzero's Avatar
Drives: Subaru
$1,500 for that thing is no bueno.
Twins would be more worth that kind of money. Poke them bad boys out of the hood. Wear it proud!
Subzero is offline
Old 03-29-2015, 08:42 PM   #232
blown
Drives: ft86
maybe one off a DBW V8?
blown is offline
Old 03-30-2015, 03:22 AM   #233
sam69
Drives: GT 86
Could a TB like this one be used off a LS2 motor
It has 6 pinouts like the 86 but I have no idea if they are the same re voltage etc as I cannot find a pinout diagram for the 86 .
Has anyone got the pinouts for the 86 ?
Being an old bloke I'm just throwing this out there to see if it's possible so maybe Ron or someone with more knowledge could respond.
I can easily make up a bigger Maf tube and piping to the TB etc .
sam69 is offline
Old 03-30-2015, 04:07 AM   #234
midnight23
dying bird under the hood
Drives: 2013 SWP Limited BRZ
JUN also does throttle bodies
Toyota86 / BRZ about 67mm 2022M-T001 JPY45,360 USD378.88
http://www.junauto.co.jp/products/th.../index.en.html
Build Thread
Instagram
midnight23 is offline
Old 03-30-2015, 05:37 AM   #235
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Ok so, here's the deal. The TB isn't small for this car, at all. If it was restrictive beyond 300whp don't you think there would be more options other than JUN and Cusco? Others who have torn this motor apart and critiquing it, not once by FBM, MAP, Full-Race, JDL, or any of the tuners have said anything about the TB.
cdrazic93 is offline
Old 03-30-2015, 05:45 AM   #236
sam69
Drives: GT 86
I would say if you are going turbo like most are then the factory TB is more than adequate as you are forcing the air though it not sucking as a PD supercharger does.
When you suck air the less restriction you have the better .
sam69 is offline
Old 04-01-2015, 08:21 AM   #237
Ron
Drives: Mr2
Originally Posted by 350matt View Post
there's some good points raised here, and I believe its worth trying
but only once you're up over 300Bhp
My thoughts are possible power increases across the board on power levels below 300rwhp. Doesn't the 210 spin at close to full tilt on stock boost?
and yes ECUtek allows you offset / rescale the MAF so you can fit a larger MAF tube with the stock plug in part
Wow, this ECUTEK appears to be very flexible, all while using the stock ecu.
and you can get a larger TB from Cusco and MAP performance - but I've yet to seee any gains published for these
Probably wouldn't see much of a difference from 65mm to 67mm, and you would see no difference if the sc inlet opening is 65mm with a 67 mm TB attached.
I'm not sure about compatibility between different fly by wire TB. If I had to guess, I don't see why ECUTEK wouldn't be able to sync with this TB but perhaps someone more knowledgeable can chime in. Curious to know what size TB this is and what size is the inlet the TB mates to?
I didn't realize these companies build twinscrew compressor kits. If they do, they are doing so missing the most critical element.
Ron
Ron is offline
Old 04-01-2015, 08:31 AM   #238
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
There's something else. We have something cooking here that looks to be quite a nice alternative.
Xero-Limit is offline
The Following User Says Thank You to Xero-Limit For This Useful Post:
brianhj (04-02-2015)
500whp or bust, sprintex, sprintex 335
The new sprintex 335 supercharger jet86 Forced Induction 39 11-01-2014 11:27 AM
Innovate/sprintex SC rudysaliby Scion FR-S / Toyota 86 GT86 General Forum 3 10-28-2014 03:14 PM
Innovate/ Sprintex vs vortech GeeTee86 AFRICA 24 04-04-2014 02:38 PM
Innovate/ Sprintex vs vortech GeeTee86 AFRICA 5 03-05-2014 07:26 AM
TyperRspec789's Full Blown Stage 1 Base Turbo & e85 Progress and Testing TyperRspec789 Forced Induction 63 12-31-2013 07:39 PM
