| View Poll Results: which one is the best? | |||
| 1 |
2 | 4.55% |
| 2 |
4 | 9.09% |
| 3 |
4 | 9.09% |
| 4 |
9 | 20.45% |
| 5 |
6 | 13.64% |
| 6 |
2 | 4.55% |
| other: please list |
17 | 38.64% |
| Voters: 44. You may not vote on this poll | |||
#29 |
Granny Shifter
Drives: 2014 FR-S
My d*ck is the best strut bar.
| The Following 2 Users Say Thank You to MokSpeed For This Useful Post: | continuecrushing (03-25-2015), FR-S_ATL (03-26-2015) |
#30 | ||
uhh there's a ton of worthwhile mods to help with a weekend warrior/dd setup that will crush the OEM if selecting (a) quality part(s).... - Clutch & FW - Bushings - Shifter - Shift Knob - Oil Cooler - Slave cylinder retrofit - HIDs/LEDs - tires - struts - springs - sways (fine tuning) - LCAs - a good alignment - audio/stereo stuff - those sweet jdm clear sidemarkers - A tune - E85 - exhaust - Upgraded brake pads need I go on sir just ask rear strut brace shouldn't be one of them |
#31 |
| The Following User Says Thank You to Tcoat For This Useful Post: | continuecrushing (03-25-2015) |
#33 | |
Drives: '13 Raven FR-S, MT
. ck |
| The Following User Says Thank You to ck-GT86 For This Useful Post: | Koa (03-25-2015) |
#36 |
Are there any bars that aren't hollow? Im a proponent on all things solid, especially if its steel. Weight doesn't matter much to me
. ck |
#37 |
Turning is for Nerds
Drives: 35 characters is not enough
Lots. Perrin, Whiteline, in fact, I think most sway-bars available are solid.
#38 | |
. ck |
#39 | |
Bilge monkey
Drives: '13 BRZ, 82 starlet
the "strut" has a pivot point at the bottom. therefore, virtually zero lateral load is transmitted into the housing at all. a brace at the top does nothing. |
#40 |
Drives: drift cars
on my volvo station wagon i just used a rachet strap from side to side it made a difference but i also filled the sides with tuff stuff
| FS: Rear strut Bar | 86design | Brakes, Suspension, Chassis | 9 | 07-27-2013 01:51 AM |
| FS: Rear strut bar! | 86design | Brakes, Suspension, Chassis | 3 | 07-08-2013 02:57 PM |
| eliminate rear deck popping with rear strut bar? | chenshuo | Issues | Warranty | Recalls / TSB | 11 | 07-03-2013 06:44 PM |
| FS: front and rear strut bar!! | 86design | Engine, Exhaust, Bolt-Ons | 7 | 05-21-2013 05:45 PM |
| Rear Strut Tower? | swift996 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 2 | 11-25-2012 11:14 PM |
