Old 03-24-2015, 02:03 PM   #1
Cjs_
Cjs_'s Avatar
Aluminum 1-piece Driveshaft
Hey guys has anyone gone out and bought the aluminum driveshaft from driveshaft shop?
Any feed back? Any issues?
Done some research but all I could find for feed back is that the bolts arent long enough and only catch about 2 threads.
Just want to get some feed back before I go and buy one.
Thanks!
Cjs_ is offline   Reply With Quote
Old 03-24-2015, 02:08 PM   #2
Koa
refer:
http://www.ft86club.com/forums/showthread.php?p=2134213
also peep my sig for how to search this site very easily! It's a handy little tip
The Following 3 Users Say Thank You to Koa For This Useful Post:
Dimman (03-25-2015), Hyper4mance2k (03-25-2015), tennisfreak (03-25-2015)
Old 03-24-2015, 10:48 PM   #3
Ashikabi
Ashikabi's Avatar
I have one. Shifting and acceleration from stop is so much smoother. I dunno that the "light weight" helped much but the 1 piece shaft feels much better. My bolts were long enough
Old 03-25-2015, 12:16 AM   #4
Xinshadow
Drives: 2013 Scion FR-S Ultramarine
Yeah as was stated in the other thread, the lighter weight is nice, will smooth out the acceleration somewhat. Biggest draws for me were the weather resistance (my stock shaft was already surface rusting after 2 winters) and significantly lighter weight. Is it a huge difference? No, but it would be silly to do the clutch and flywheel without touching the driveshaft.
As far as issues you will notice a somewhat sharp vibration in your gas pedal when the diff engages and you're really hammering into a corner, but that's not a problem with the unit so much as its a consequence of the higher NVH with an aluminum driveshaft. It's something I only really see at the track.
Current mods: OFT Stage 2 (w/93 oct), OFH, Perrin Resonated catback, DSS Aluminum Driveshaft, Perrin drop-in filter, Avo silicone inlet, Mishimoto catch can, Grimmspeed MCB, Perrin crank pulley, Nameless overpipe/downpipe combo, DBA slotted rotors, Ferrodo brake pads, goodrich SS brake lines, DOT5 synthetic brake fluid.
Xinshadow is offline   Reply With Quote
Old 03-25-2015, 12:18 PM   #5
wparsons
wparsons's Avatar
Another benefit is one less connection to wear over time.
flickr
Old 03-25-2015, 12:38 PM   #6
Koa
Why would it be silly?
The driveshaft can be done in 20 minutes... the clutch and FW, however...
I could understand if somehow, one only had ability to remove the driveshaft with the tranny separated from engine, but really its something easily independently of any other mod
since @stugray so eloquently put out the reality of performance gains, what are you really sacrificing when you touch the clutch/FW to make the driveshaft a must-do if one was replacing the former?
The Following User Says Thank You to Koa For This Useful Post:
Xinshadow (03-25-2015)
Old 03-25-2015, 12:49 PM   #7
Thorpedo
The SquadWhisperer
Yeah... No. That's just bad information. Also, it literally makes NO difference if your stock driveshaft has surface rust on it. A ladybug taking a shit on your driver side mirror is a bigger issue.
2013+14+15 Atlantic Region Motor Sports Autocross STX Champion
2013+14+15 Atlantic Region Motor Sports Overall Autocross Champion
2017 Bluenose Autosport Club Overall Rallycross Champion
Powered by Great North Performance, Jani-King Canada, and OK Tire.
Thorpedo is offline   Reply With Quote
The Following 2 Users Say Thank You to Thorpedo For This Useful Post:
Koa (03-25-2015), TheVoiceOfReason (03-25-2015)
Old 03-25-2015, 12:54 PM   #8
Ashikabi
Ashikabi's Avatar
Damn lady bugs
The Following User Says Thank You to Ashikabi For This Useful Post:
Thorpedo (03-25-2015)
Old 03-25-2015, 01:05 PM   #9
zooki
Drives: waiting on a 2021...
Wait, you guys don't Opti Coat your driveshafts?
2016 4Runner Tail edition
2020 Camry 2020 RAV4
2013 Chevy 3500 4x4 Duramax
1999 Ford F250 Powerstroke, the tow rig
1969 Mustang, the fast car....(:
zooki is offline   Reply With Quote
The Following 2 Users Say Thank You to zooki For This Useful Post:
continuecrushing (03-25-2015), Thorpedo (03-25-2015)
Old 03-25-2015, 01:11 PM   #10
Thorpedo
The SquadWhisperer
Squadrogue's next thread.
"Guys should I Opti Coat my driveshaft?"
Captain Snooze (03-25-2015), Koa (03-25-2015)
Old 03-25-2015, 01:33 PM   #11
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
"Guys should I Plasti Dip my driveshaft?"
Fixed that for ya
The Following 3 Users Say Thank You to cdrazic93 For This Useful Post:
Koa (03-25-2015), Thorpedo (03-25-2015), Xinshadow (03-25-2015)
Old 03-25-2015, 02:26 PM   #12
Xinshadow
Like I said in the prior post, if you have the JDM underpannels and go through all the work to unbutton the bottom of the car to get access to the trasmission, you might as well change the driveshaft while you're in there, if you're after the weight savings. You could do them seperate of course, but using basic tools you add another hour or so of busywork just to get back to the area you need.
As far as the rust, of course surface rust doesn't matter, but it turns into actual concerning rust fairly quickly; my stock exhaust flanges were starting rust severely to the point of effecting function after just two winters. I hadn't originally planned to do the driveshaft at all, but going down there for the flywheel and clutch and seeing it with spots all over, I figured I might as well gain corrosion resistance and drop 10 lbs for relatively cheap.
Old 03-25-2015, 02:36 PM   #13
Koa
I can see why you'd want to do it, but why do you make the assertion that while doing the clutch and flywheel, NOT doing the driveshaft would be an error... given the dismal actual realized performance gains, and non-exclusiveness of the clutch and flywheel relative to the driveshaft?
Let's be real it takes 10 minutes to take off underbody panels.
Add another 10 for driveshaft assembly if you're half decent with wrenching.
It takes a whole day or more for most people to do a clutch and flywheel job.
Old 03-25-2015, 02:38 PM   #14
Xinshadow
Fair point, but it takes me a lot longer to take off those underpannels with the car up on jackstands for some reason (those FING POP WASHERS) so it was a pita enough to justify adding a few more minutes onto a lengthy clutch swap to do it all haha
The Following User Says Thank You to Xinshadow For This Useful Post:
Koa (03-25-2015)
Axle-Exchange One-piece Aluminum Driveshaft ~ impressions slates74 Engine, Exhaust, Transmission 152 08-07-2021 08:39 PM
Axle Exchange Aluminum driveshaft jack43 Transmission and Driveline 5 08-23-2014 01:02 PM
FS: Driveshaft Shop (DSS) aluminum driveshaft (for AT only) $350 dp1 Transmission and Driveline 8 06-18-2014 05:16 PM
New The Driveshaft Shop Carbon Fiber 1-Piece Driveshaft Evasive Motorsports Engine, Exhaust, Transmission 1 09-24-2013 03:27 PM
