Old 03-23-2015, 04:02 AM   #15
ohnoitsthefuzz
Drives: 2013 Scion FRS 6 Speed Raven Black
I bought the TWM short shifter and guess what. It started rattling to! FML. How in the hell do you produce a vehicle that you can't even get rid of a shifter rattle!? A $300 short shifter even rattles, check mate, you are still f+%ked.
ohnoitsthefuzz is offline   Reply With Quote
The Following User Says Thank You to ohnoitsthefuzz For This Useful Post:
XtremeMaC (10-12-2016)
Old 05-11-2015, 01:25 AM   #16
Wyattkb
Drives: 2014 Whiteout FRS
Originally Posted by Wyattkb View Post
Just an update. Removed Whiteline transmission bushing insert. Rattle is gone.
It also stopped making a high pitched soft whine in 6th gear while under 65 MPH.
So the rattle came back the next day after I posted this.
I had some time this weekend to mess around with the shifter and I believe I have found a definitive solution (at least for me).
The reverse lockout plate was bolted too closely to the reverse lockout lever, so when the car was in 1st or 2nd the reverse lockout would still be in contact with the plate that prevents it from going into reverse.
I moved the plate out further and now it only rattles for a moment once I hit redline. I plan to put some rubber mat in between a few of the pieces to completely eliminate the issue.
Wyattkb is offline   Reply With Quote
Audible shifter rattle Hanzo Issues | Warranty | Recalls / TSB 134 08-17-2022 03:34 AM
Manual MT Shifter Boot Swap Onto Automatic AT Shifter Assembly? soulstice Cosmetic Modification (Interior/Exterior/Lighting) 52 01-24-2016 09:20 PM
Shifter Rattle and Replacement boredom.is.me Issues | Warranty | Recalls / TSB 19 04-27-2015 05:29 PM
2014 Shifter Rattle becauseracecar1 Issues | Warranty | Recalls / TSB 1 05-24-2014 07:06 PM
BRZ Shifter Rattle TSB sc0urge BRZ First-Gen (2012+) — General Topics 2 08-26-2013 09:53 PM
