Old 03-23-2015, 12:39 AM   #1
Aztec
Lost in the twisties
Aztec's Avatar
Drives: 2014 BRZ Dark Gray Metallic
Best RPM to set OFT Launch Control to?
Currently running the stage 2 E85 tune from the OFT, loving the Launch Control, but hoping to lower the RPM limiter to 4k or so. (I believe it's set at 5,500)
I was hoping to get some feedback from people that have it set to a lower rate and are happy with the results
Aztec is offline   Reply With Quote
Old 03-23-2015, 12:59 AM   #2
steve99
Drives: FT86
It going to depend on heaps of factors like
tyres width compound pressure ect
road surface
engine torque ie runnung e85 or stage1\2 tune ect
your tollerance for drivetrain abuse
do you want to just drop or slip\ manage clutch release ect
but arround 4000 seem a reasnoble compromise ie delta = 3600 for redline of 7600
Old 03-23-2015, 01:15 AM   #3
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
also, for those posting up let us know if you just dump the clutch or slip it a bit.
I found I need to slip mine just a bit to prevent bogging. If I launch at too high an rpm I just end up with wheelspin!
Old 03-23-2015, 02:22 AM   #4
Aztec
Aztec's Avatar
I definitely slip the clutch just a little, but with the RPM so high I end up spinning all the way up to redline haha. I'm still on 17s with stock width. (Not stock Michelin, but close enough)
-Stage 2 E85
-Open Flash Header
-Summer tires on Dry normal pavement
Thanks for the reply steve, I will go ahead and modify the delta to 3600 in romraider (haven't used romraider yet, but I'm sure I'll figure it out)
Old 03-23-2015, 09:20 AM   #5
was385
Drives: MT WRB BRZ Limited, 2007 911s
Way too many factors to give you an answer online. Start in the 3500 range and test it out on the type of surface you'll use it on the most. Personally, I use it for autox and the starting line in my lot has very little grip so I'm in the low 3000 range with 245 ZII tires.
was385 is offline   Reply With Quote
Old 03-23-2015, 01:31 PM   #6
itsjustdavep
itsjustdavep's Avatar
Drives: Asphalt Scion FR-S
I'm stock on stg2 e85 map with a drop in filter. At 5500 at the strip I spun so much I almost ate the wall. I set it to 4500. And go around the waterpit.
2013 Asphalt HRI Tuned-K&N DropIn-Tomei UEL-Tomei OP-Invidia FP-Nameless Muffled Trackpipe...and corn
itsjustdavep is offline   Reply With Quote
Old 03-23-2015, 01:31 PM   #7
itsjustdavep
Consistent 60 foots all day
Old 03-23-2015, 01:48 PM   #8
itsjustdavep
Oh! Last step. Set TC to like half off? Just push button once. Step it at 45 and go. It'll slip just enough to get up n go. Even on dry pavement.
Old 03-23-2015, 02:01 PM   #9
duke_FRS
duke_FRS's Avatar
Drives: 2015 FRS Hot Lava 2014 CT200H
All Stock on E85? Hows it running I'm interesting in trying it out?
Open Flash Tablet Stage 1 93 | Borla Cat-Back | VOSSEN VFS1 | Eibach Sportline
duke_FRS is offline   Reply With Quote
Old 03-23-2015, 04:29 PM   #10
kch
Senior Misanthrope
kch's Avatar
It's not going to be a HUGE difference, but it's a nice kick in the pants over stock. If you have an OFT already and live near a station with E85, you absolutely should give it a try. I'm stock and have been on E85 with OFT stg2 EL tune for several thousand miles and it's been perfect.
Edit: it may be related to throttle mapping more than anything, but i feel the E85 the most during highway passing. it's just so effortless going from 75-85 in 6th.
Old 03-23-2015, 04:42 PM   #11
itsjustdavep
100% accurate.
Also satisfying to blow the doors off of certain folks who wanna get cute on the highway on my way home from work at 3 am...
Old 03-23-2015, 07:10 PM   #12
Aztec
Aztec's Avatar
I was under the impression that TC had to be fully off? I'll have to mess with settings.
I'll probably set it 3600-3800, the 5500 is just way too high.
I'm currently running E85 on stage 2 tune with only K/N drop in and Inlet tube as well. But my UEL Header is coming in a week which will definitely help quite a bit
Old 03-23-2015, 08:56 PM   #13
steve99
Drives: FT86
Their is no software lockout between Launch Control and Traction Control.
Launch Control is simply an rpm limit when car is doing less than the LC disengage speed.
You can have the Traction Control Fully on ,Sport mode or fully off. TC will just limit the amount of wheel spin depending on mode.
OFT launch control inop. shifter907 Software Tuning 34 06-17-2017 12:08 AM
OFT Launch Control Install bunches7399 Software Tuning 7 09-04-2014 07:42 AM
How bad is launch control Bg8780 Engine, Exhaust, Transmission 23 07-09-2014 01:47 PM
Launch Control is back! m.wood0213 Other Vehicles & General Automotive Discussions 0 04-16-2014 12:00 PM
Unichip Launch control SCharged Software Tuning 11 01-22-2014 01:13 PM
