Drives: 4-Runner Sport - 13' BRZ SportTech
Occupant sensor
I've done some searching about this but haven't found a definitive answer.
I'm installing a pair of seats in my BRZ and want to retain the stock passenger occupancy sensor. I've disassembled the stock seat and removed the pad but I can't get it to trigger the airbag on in the new seat. Has anyone done this successfully? Or is there some kind of bypass type of switch that allows me to manually select on or off? Help would be greatly appreciated. Thanks
Top Tier Imports - Check out my build journal HERE
#2 |
Drives: FRS
my iphone seems to have magical powers to trigger the airbag sensor when i place it on the passenger seat. so annoying.
| The Following 3 Users Say Thank You to 8R6 For This Useful Post: |
#3 |
Drives: 2013 Firestorm
#4 |
I'm starting to think that no one running aftermarket seats has a working passenger side airbag lol.
I read one guys writeup about folding it up and stuffing it under the seat, but that's not how these sensors work. If you fold it in on itself, it throws an airbag light. Does ANYONE have a working passenger side airbag with aftermarket seats?
#5 | |
This is what you are looking for.
#6 | |
Does your passenger airbag go to ON status?
#7 |
#8 |
Drives: 2JZ FRS
I put it under the seat bottom foam in my recaro pole positions. Worked just fine.
#9 | |
How did you remove it from the factory seat? Just pulled that grey foamy stuff off of the cushion?
#10 |
Drives: 2JZ FRS
Lifted the fabric and worked it out from under there. Some of that thin grey foam came with it so I guess that's what it's glued to
#11 | |
#12 | |
I can make my Droid Maxx do it at will. Insert the charging plug, lay on seat, I have a phantom passenger. Unplug, no passenger. Plug back in, lay the phone so that the charging plug is lifted off the seat and on the bolster, no passenger. Things that are wet, or liquid can also set it off. Its similar to a touchscreen or biometric reader that uses a very low current charge to make a connection.
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
#13 | |
| The Following User Says Thank You to Jrryjms07 For This Useful Post: | Dadhawk (03-23-2015) |
#14 |
Drives: 2013 Toyota 86 GT
Mine does work. Whilst I didn't do the install myself I had a chat with the guys that did, and that's how it goes.
| Greddy informeter, boost sensor, boost sensor harness, info touch sensor apaptor | Supra2k | Audio/Visual, Electronics, Infotainment, NAV | 1 | 02-26-2014 09:11 PM |
| Stock FA20 Crankshaft Angle Sensor - Anyone know what type of sensor and output? | Acree | Engine, Exhaust, Transmission | 2 | 08-26-2013 07:39 PM |
| Defeating Occupant Detection Sensor | TuxedoCartman | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 11-16-2012 01:48 AM |
| Understanding the BRZ/FR-S/86 Occupant Detection Sensor | Turbowned | Issues | Warranty | Recalls / TSB | 13 | 08-27-2012 11:58 PM |
