Old 03-16-2015, 04:51 PM   #1
Felix7007
Drives: Scion FR-S Black
Clanking Noise
Hello,
I get a clanking noise when I reverse after the E-Brake has been let out. I drive an awesomatic transmission.
So the process again:
Car in park and on
Put in reverse
E-Brake let out
Applying gas and moving backwards CLANK
I assume It's one of three things. Transmission, E-Brake not releasing all the way, Differential. I do autocross and HPDE and hoping its not gears poping in place. The car doesn't jutter or anything just the noise. Anyone else have this issue?
Felix7007 is offline   Reply With Quote
Old 03-16-2015, 05:32 PM   #2
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
It's just the parking brake assembly resetting.
-alex
Old 03-16-2015, 05:47 PM   #3
1GiantTurtle
Space for Rent
1GiantTurtle's Avatar
Drives: 2014 6MT ToyoBaru86ScionMonogram?
Originally Posted by Felix7007 View Post
Hello,
ToyoBaruScionGT86hachiRokuBRZMonogram
Instagram: 86turtle
Instagram: 86turtle
1GiantTurtle is offline   Reply With Quote
Old 03-16-2015, 07:47 PM   #4
richardM
Drives: scion frs, 2012 Mustang
Check to make sure you didn't close the seat belt outside the door?
richardM is offline   Reply With Quote
Old 03-16-2015, 07:51 PM   #5
congee
congee's Avatar
Drives: SSM BRZ
I have the same issue. Except mine sounds more like a slush clanking. Also, I only hear the sound the first time I fire it up after having it sit for a long period of time.
congee is offline   Reply With Quote
Old 03-16-2015, 08:13 PM   #6
CambakerFt8677
CambakerFt8677's Avatar
Drives: 2013 Fr-s hot lava (rip) 2016 frs
100% its the brake assembly resetting, some people say it will only if there is a lot of strain (weight) when parked, my car is always parked on the flat in the garage and does the same thing every morning
CambakerFt8677 is offline   Reply With Quote
Old 03-16-2015, 08:47 PM   #7
Parking brake does this in most cars but generally the sound proofing prevents you from hearing it. We of course gave up sound proofing so we can hear noises that we normally would not.
Clanking metal sound from rear!!!! 808Raven Issues | Warranty | Recalls / TSB 7 09-21-2017 11:09 AM
Clanking from Rear Suspension After Alignment(w/ KW V3, Cusco LCA, Whiteline Toe Arm) Figo Issues | Warranty | Recalls / TSB 29 10-29-2013 07:09 PM
clanking sound after Eibach pro install Bailey239 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 46 07-11-2013 01:22 PM
clanking sound with idle wallace03 Issues | Warranty | Recalls / TSB 4 05-08-2013 06:19 PM
Clanking Metal on the Engine Bay! Help :( 86 FRS Issues | Warranty | Recalls / TSB 9 10-08-2012 12:24 AM
