Old 03-07-2015, 07:57 PM   #1
Peschi
Passenger door raddle and squeak coming from around speaker
Hey guy!
I have a 2013 BRZ Limited with 20k on it.
Since I got it I have been hearing a squeak or raddle from the door/speaker area.
When the passenger puts minimal pressure on the speaker grille the sound goes away.
Does any one have any suggestions?
Thanks!
Peschi is offline   Reply With Quote
Old 03-07-2015, 08:13 PM   #2
stevesnj
stevesnj's Avatar
Pop the grill off and tighten the spaker screws. They could just be lose or the grill itself could have an issue.
My 2016 Build thread
Old 03-07-2015, 11:42 PM   #3
navanodd
Drives: 2013 BRZ Sport-tech WRB
Its the window switches themselves. If you pop the doorcard and unscrew the switches, you can take them right out and see part of the window switch moving around from the underside. A little foam stuffed in the grooves fixes it completely.
As a side effect, you will likely notice a big improvement in sound quality.
navanodd is offline   Reply With Quote
Old 03-08-2015, 04:21 AM   #4
Turbo95eg6
Turbo95eg6's Avatar
Drives: 2014 BRZ SWP LTD
I didn't even know raddle was a word. But I'm sure you meant rattle.
Instagram: stimson
Old 03-08-2015, 04:28 AM   #5
Well played!
Subtle yet effective.
Old 03-08-2015, 10:50 AM   #6
Peschi
thanks!
I'm not sure what/where to look for window stitching.
Could you give me a quick run down as to how I could accomplish this?
Old 03-08-2015, 02:58 PM   #7
navanodd
Originally Posted by Peschi View Post
thanks!
http://www.ft86club.com/forums/showthread.php?t=12520
That post has enough info to get you to the switches. 4 screws hold the switch on. Once you have the switch out its easy to see where to put the foam.
Squeak from passenger side grgonium CANADA 11 03-14-2018 10:10 AM
FS: OEM JDM Driver and Passenger Knee pads and Speaker panels SOLD johnb831 Interior Parts (Incl. Lighting) 0 01-25-2015 10:29 PM
FRS door speaker vibration? hislargeness Electronics | Audio | NAV | Infotainment 12 08-19-2013 05:22 PM
Door speaker question BlackyRose Electronics | Audio | NAV | Infotainment 2 07-26-2013 10:45 PM
Door Speaker Vibration MattM232 Issues | Warranty | Recalls / TSB 16 03-19-2013 07:03 PM
