Old 03-06-2015, 01:24 PM   #1
slyphen
Drives: Man
Send a message via AIM to slyphen Send a message via Yahoo to slyphen
Which jack should I get?
Hello!
I'm a newbie when it comes to working on cars. but I want to finally change my own oil. I got my BRZ last May and so far it only has 4000 miles on it. I know i'm overdue on the 6 month period but i am still under the 7400 miles that was recommended. I got my fumoto valve and royal purple filter/0W20 ready.
I wanted to change my oil 2 months ago, but it was too cold and I didn't have a proper jack. I went to a shop but their jack was too high, and the only other place was jiffylube which had a pit. but I don't trust them to work on my car...
Now i have 2 options... which jack should I get?
http://www.harborfreight.com/3-ton-l...ump-62326.html
http://www.harborfreight.com/2-ton-l...ump-60678.html
THANKS GUYS!
slyphen is offline   Reply With Quote
Old 03-06-2015, 01:40 PM   #2
DAEMANO
Time Traveller
At Harbor Freight,
The 2 ton low profile with long neck jack is awesome but HEAVY - 90-100 lbs. This is great for a garage but horrible to take anyplace. http://www.harborfreight.com/2-ton-l...ump-60678.html
There's a 2 ton 'racing" jack made of aluminum that isn't as low profile or as long as the one above that weighs about 45lbs and is better if you have to take the jack to the track or someplace else. http://www.harborfreight.com/2-ton-a...ump-61406.html
The 3 ton is just overkill for our cars.
Old 03-06-2015, 02:01 PM   #3
swarb
^exactly what he said. I've used both, the aluminum one is much easier to move while the steel is easier to use and feels more secure. Since the length is shorter on the aluminum one, it doesn't go as high and it moves/rolls a little towards the top of the range. The 3 ton ones sit higher and are harder to get under the car if you are lowered much.
The Following User Says Thank You to swarb For This Useful Post:
DAEMANO (03-06-2015)
Old 03-06-2015, 03:38 PM   #4
Cockatoo
TALLY FT86
Cockatoo's Avatar
Drives: 2014 FR-S Monogram -- SBD Turbo --
I have the 2 ton low profile one and it works great!
Cockatoo is offline   Reply With Quote
The Following User Says Thank You to Cockatoo For This Useful Post:
Old 03-06-2015, 04:03 PM   #5
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Get the low profile for the track, the full-sized one for the home, and a couple of ramps for getting the car high enough to use the full sized-one. I made mine out of 2x12 pieces. When you're doing real work, you absolutely want as much lift as you can to max out the jackstands. A low-profile jack won't do the job as well. Even as it is, I need to jack the front, put up stands, jack the back, put up rear stands, then rejack the front to get the stands maxed out.
The Following User Says Thank You to EAGLE5 For This Useful Post:
Old 03-06-2015, 04:26 PM   #6
Kimsey47
Kimsey47's Avatar
Drives: 2016 STI DGM
Not aimed at OP... Just posting where my mind went with the topic...
Subaru STI :
Old 03-06-2015, 05:58 PM   #7
slyphen
Drives: Man
Originally Posted by DAEMANO View Post
At Harbor Freight,
the 2 ton aluminum jack, do you have clearance issues with it?
Old 03-06-2015, 06:21 PM   #8
wheelhaus
wheelhaus's Avatar
I'd recommend the 68050 (or 60678 @DAEMANO mentioned above, they seem identical) because it's nice and low and extremely long. It's a 2-ton steel jack, but unless you're hauling it around everywhere it's a non issue. It can rarely be found on sale for $99-109, but its typical "on sale" price is 129-139. Still a great jack.
I prefer to jack the front of the car first at the front crossmember. Raise the front, set jack stands in place behind front wheels, set her down. Go behind the car and jack the rear end up at the diff housing, set jack stands in place in front of rear wheels, set her down. Up in the air in less than 2 minutes.
Doing this method, the jack is just low and long enough to reach under the rear bumper to the diff, the handle will still hit the bumper when it's straight up, so I couldn't imagine doing this with any other jack that might be shorter or taller, especially with a lowered car (mine is at stock height). The problem is that the front end being high teeters the rear bumper down to the ground, so muffler and bumper clearance are substantially less. Doing the rear end first would place the front bumper way too close to the ground. The 68050/60678 jack works perfectly.
The Following User Says Thank You to wheelhaus For This Useful Post:
Old 03-06-2015, 06:25 PM   #9
wheelhaus
wheelhaus's Avatar
even if the low profile jack mentioned above has a 24" jacking height?
Old 03-06-2015, 06:34 PM   #10
gramicci101
Off Topic
Agreed.
Op,
The 62326 jack has a lift height of 19.5 inches. Plus it's pretty short front to back; I'd be worried about hitting my bumper with it. Also, you don't need 3 ton capacity.
The 60678 goes higher (23.5 in), but the overall length of the jack is only 34.5 inches, which may prove to be an issue with clearing your bumpers while reaching for the jack point.
I have a 68050. It's effectively the same as the 60678 except that it's 39.5 inches long instead of 34.5. I don't have to worry about touching the bumpers at all; the entire front bumper is located above the low profile portion of the jack.
Combine one of the 2 ton jacks with Harbor Freight's 23.5" jack stands, and you've got plenty of room to crawl around under the car.
My car is on RCE Yellows, for reference.
The Following 2 Users Say Thank You to gramicci101 For This Useful Post:
DAEMANO (03-06-2015), wheelhaus (03-06-2015)
Old 03-06-2015, 06:37 PM   #11
wheelhaus
wheelhaus's Avatar
ahh good catch, I didn't realize the 60678 was a bit shorter.
Old 03-06-2015, 06:39 PM   #12
gramicci101
Off Topic
Yep. When I get home I can take a picture of the 68050 under the front bumper so everyone here can see the clearance those extra 5 inches gives you. (that's what she said.)
The Following 3 Users Say Thank You to gramicci101 For This Useful Post:
DAEMANO (03-06-2015), slyphen (03-06-2015), wheelhaus (03-06-2015)
Old 03-06-2015, 06:44 PM   #13
wheelhaus
wheelhaus's Avatar
I made a black mark on mine where to stop at the leading edge of the front bumper. Give a quick visual check and pop it up. At the rear end the jack is about as deep as it can go just to reach the diff. I'd be a little doubtful the 60678 would be able to reach the diff...
The Following 2 Users Say Thank You to wheelhaus For This Useful Post:
DAEMANO (03-06-2015), gramicci101 (03-06-2015)
Old 03-06-2015, 06:46 PM   #14
gramicci101
Off Topic
That is an excellent idea and I will be doing that shortly. I feel kind of dumb that I never thought of it.
$10 Jack Buddies blalor DIY (Do-It-Yourself) Guides 24 10-20-2017 08:16 PM
FRS tire jack mafrs1 Issues | Warranty | Recalls / TSB 23 12-16-2015 03:03 PM
Jack @ UNICHIP Bullnettles User/Vendor/Sponsor Reviews, Feedback, Comments 6 08-16-2013 06:26 PM
JACK's BRZ! Mr. Jack Member's Car Journals 10 07-05-2013 10:19 AM
Where ti jack car up at? skatery1989 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 2 08-13-2012 02:53 AM
