Old 03-04-2015, 06:35 PM   #1
Churg
Churg's Avatar
Drives: 2014 WRB BRZ
Issues with getting camber to -3 in front?
Hey guys,
I bought some Tein SRC's, installed them, and went to a local alignment shop to get my car taken care of. However, the shop had some serious issues working on getting my camber to -3 like I wanted. Now, I don't know much about setting camber. I know that moving around the little bolts in the camber plate adjusts the camber, but that's about it.
Here's before their adjustment, at -1.7 camber:
And here's after their adjustment at -2.0:
I am 99% sure that I've installed the coilovers correctly, and I'm guessing that the guy aligning my car doesn't know how to adjust this properly, and because of my lack of knowledge on adjusting camber, I had to basically stick with -2.0, and for a competitive car in STX, I'd like to be sitting at -3.2 or so.
I also wanted to give a shout out to @CSG David for being so helpful and responding to my emails so fast while I was at the shop, I was really impressed.
Churg is offline   Reply With Quote
Old 03-04-2015, 06:42 PM   #2
wparsons
wparsons's Avatar
Doesn't look like you can get any more camber from the upper mount, if you want more you'll need to adjust at the knuckle.
flickr
Churg (03-04-2015)
Old 03-04-2015, 06:46 PM   #3
Churg
Churg's Avatar
I'm guessing that's where you'd pop a camber bolt and the like? The most confusing bit to me, is how the CSG guys were able to get to the -3 mark with ease with the same coilover setup. That's why I'm confused, mostly.
Old 03-04-2015, 06:59 PM   #4
CSG David
CSG David's Avatar
Alan was getting way more than -3.x of camber. You may want to check on install and make sure you're using the right bolts. It's definitely a mistake from the installation side (which can possibly happen if you're tired). All the SRC guys are able to hit their intended alignment spec.
The Following User Says Thank You to CSG David For This Useful Post:
Churg (03-04-2015)
Old 03-04-2015, 07:06 PM   #5
kster1
kster1's Avatar
Just an FYI here with some random thoughts. The first time I installed the Ohlins R&T, I reused the lower two strut bolts. The second time I installed them, I used new bolts. And on the second install, I was able get a significantly higher amount of negative camber. Maybe the amount of stretch in these bolts impacts camber?
kster1 is offline   Reply With Quote
The Following User Says Thank You to kster1 For This Useful Post:
Churg (03-04-2015)
Old 03-04-2015, 07:08 PM   #6
Churg
Churg's Avatar
I'll check to make sure I'm using the right bolts, I could've swore I did. You re-use one of the bolts from the factory, and they come with an additional one, correct? Maybe I misunderstood Alan when he explained which bolt to reuse and which hole the included bolt went in.
Old 03-04-2015, 07:12 PM   #7
Churg
Churg's Avatar
I only had one new bolt for each side, not two. I was told by the previous owner to reuse one of the bolts from the stock setup. I might've mixed up which bolt went on top and which went on bottom. It's allllll starting to come together now.
Unfortunately, I won't have access to a jack until Friday.
Old 03-04-2015, 07:23 PM   #8
CSG David
CSG David's Avatar
I haven't installed the SRCs in awhile (Mike has been doing the work...hehehehe). The top hole should be slotted and I believe TEIN provides a "bushing" that fills in that slot when you install the bolt. Either way, -3.x should not be an issue. If there's still an issue, West End has done a few alignments with the SRC installed BRZ/FRS so they can help diagnose that issue for you. Might cost a little extra, but they are fast and efficient. All their measurements have been dead-on every time so when you can, make that appointment!
Churg (03-04-2015)
Old 03-04-2015, 07:36 PM   #9
Churg
Churg's Avatar
I've been dying to go to go to West End. Unfortunately, I'm in Bakersfield and my available days to get all the way down there is very limited. Once I get my LCA's I'd love to go to them to get my car worked on.
@CSG Mike, just to make sure when I check and make sure I did this install right, the bolt with that bushing goes in the top hole that is TEIN provided, and the bottom is the stock bolt, correct?
Old 03-04-2015, 08:10 PM   #10
kster1
kster1's Avatar
As someone that has just ordered a set of TEIN SRCs, I'm also interested in this. So the SRCs come with the upper strut bolt? Does this need to be replaced after each install? If so, how is this done?
Old 03-04-2015, 08:25 PM   #11
CSG David
CSG David's Avatar
No it doesn't. The install is super straight forward so bolts don't need to be replaced. Always refer to the pictures in the Japanese manual.
I have this odd feeling that the camber plates might have been set incorrectly. While caster is not exactly easily changed, it's possible because there are sufficient amount of holes available to use and you can also spin the camber plate around to incorporate a little extra caster change.
kster1 (03-04-2015)
Old 03-04-2015, 09:02 PM   #12
swarb
How low are you? Lower creates more natural camber also.
Old 03-04-2015, 09:03 PM   #13
Churg
Churg's Avatar
Unfortunately, the bits of the manual that Alan gave me didn't have pictures. So I just kinda went with it, hahaha.
And I assumed the SRC's came with a bolt, because Alan left one on with the washer bit attached to the strut. So David, you have any idea where I can get my hands on some of those pictures?
Old 03-04-2015, 09:03 PM   #14
Churg
Churg's Avatar
I'm low. A lot lower than I thought I'd be. 1.4-1.6" from stock, give or take.
*FREE alignment* with Purchase and install of Front Camber / SPL Rear Camber Arms! Corner3garage Southern California 188 04-24-2015 02:10 PM
front camber help smg1138 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 03-04-2015 08:03 PM
Rear camber assymmetry and alignment issues ofuts Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 02-02-2015 01:46 PM
*FREE alignment* When you get Front Camber Bolts and Rear Camber Arms Installed! Corner3garage Mechanical Maintenance and Tools 6 10-31-2013 04:40 PM
