Old 02-27-2015, 10:35 AM   #1
UrmyboyBLUE
UrmyboyBLUE's Avatar
Drives: 2015 Subaru BRZ "Series.Blue"
Does a Front Pipe/Overpipe Really make that much of a difference???
I'm currently running the following Mods:
-Perrin CAI w/ inlet tube
-OFT w/93 tune
-Tomei Expreme UEL Header (catless)
-Perrin 2.5" Resonated Cat back system
Does adding the Overpipe/Front pipe combo really make that much more of a difference?? Is it worth the extra $$$? I've heard that the Header is really where you make most of your gains.
UrmyboyBLUE is offline   Reply With Quote
The Following User Says Thank You to UrmyboyBLUE For This Useful Post:
cameronjones239 (02-27-2015)
Old 02-27-2015, 11:17 AM   #2
2016 Camaro SS
2016 Camaro SS's Avatar
Drives: Fast
Soundwise it does, but not so much performance wise on N/A. Maybe a few horsepower just due to better flow/pipe diameter increase, but negligible.
2016 Camaro SS is offline   Reply With Quote
Old 02-27-2015, 11:31 AM   #3
tinma
Drives: '13 BRZ
http://www.ft86club.com/forums/showthread.php?t=47361
some people say yes, some say no :P
tinma is offline   Reply With Quote
Old 02-27-2015, 12:02 PM   #4
wparsons
wparsons's Avatar
You'll likely see better gains from the front pipe than from a cat-back, but a header will give better gains than both.
flickr
The Following 2 Users Say Thank You to wparsons For This Useful Post:
Hyper4mance2k (06-16-2015), shifter907 (02-27-2015)
Old 02-27-2015, 12:24 PM   #5
Brzerker
Brzerker's Avatar
Drives: World Rally Blue BRZ
How about the overpipe alone? I have never been able to justify spending a few hundred dollars on such a small part of the exhaust.
Brzerker is offline   Reply With Quote
Old 02-27-2015, 12:25 PM   #6
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
most people just buy and feel good about it. even it helps very little, we just buy it. why? because we cannot help but modding
The Following 2 Users Say Thank You to zc06_kisstherain For This Useful Post:
themadscientist (06-16-2015), veck (02-27-2015)
Old 02-27-2015, 12:32 PM   #7
zc06_kisstherain
Drives: SWP BRZ
Me neither!
so i bought Johnmotoring's overpipe.
http://www.ft86club.com/forums/showthread.php?t=71763
Old 02-27-2015, 12:44 PM   #8
Brzerker
Brzerker's Avatar
it's a poisonous world out there.
Old 02-27-2015, 12:48 PM   #9
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
The answers to your questions are subjective. I thought the difference was
significant and worth the money. I am not saying the increase was much but every bit helps.
You are going to get different answers when asking for opinions
Old 02-27-2015, 12:49 PM   #10
Takumi788
JHerbert Racing
Takumi788's Avatar
Drives: 2013 Scion FRS
Me neither!
You, sir, just saved me $135 and for that you are the man.
To keep with the thread topic. The only reason I am buying an over pipe is bc having just one stock piece on my exhaust would kick start my OCD to the max. I do not expect a performance gain or sound difference.
- #813 2013 Scion FRS Build Thread
- JHerbert Racing Website
Takumi788 is offline   Reply With Quote
Old 02-27-2015, 01:41 PM   #11
akahenry
akahenry's Avatar
Drives: '18 STi
People have said that replacing the stock front pipe with an aftermarket front pipe usually leads to better throttle response. I highly doubt it (because placebo effect), but it could be a possibility.
akahenry is offline   Reply With Quote
Old 02-27-2015, 02:53 PM   #12
wparsons
wparsons's Avatar
All depends on the rest of the exhaust. If you have a 3" header collector and 3" front pipe, the stock part is going to be a big restriction. If you have a stock header or stock front pipe it's going to be a minimal difference.
If/when I replace the header I'll do the front pipe, but not bothering until then.
flickr
Old 02-27-2015, 03:52 PM   #13
FirestormFRS
Pretty sure there was a well respected tuner on here that said an OP was significant gain for FI engines. Not sure about NA. Front pipe maybe not so much.
FirestormFRS is offline   Reply With Quote
Old 02-27-2015, 03:53 PM   #14
mid_life_crisis
Drives: FR-S 10 #103 AT
You best not be dissing our placebo effect.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
Difference between HFC and resonated front pipe? BlackyRose Engine, Exhaust, Transmission 0 09-26-2014 12:38 PM
Video Clips: Front pipe sound difference's Vmax911 Engine, Exhaust, Transmission 6 09-08-2014 07:44 PM
Does the overpipe really make a difference? Wise Engine, Exhaust, Transmission 66 03-02-2014 05:41 AM
What is the difference between a Front pipe, a down pipe and an over pipe? liajet24 Engine, Exhaust, Transmission 5 09-19-2013 11:03 PM
Will a resonated front pipe make alot less noise than test pipe? Mike86 Engine, Exhaust, Transmission 8 01-26-2013 08:24 PM
