#113 |
I have realized that without a wideband o2 sensor, I realistically cannot fine tune the MAF scale.
Also, I just noticed that I have a small leak at the axleback portion of my CBE. It's a FT86SF V2 single exit with a Vband clamp that connects the midpipe to the muffler portion. The Vband got crushed apparently on a nasty hit. Got a new clamp on the way and I'll monitor how that changes things I don't know how that's going to affect the tune. @steve99 , @Shiv@Openflash , does a small leak affect things significantly? |
#114 | |
Drives: FT86
Its generally only leaks at header gaskets or 02 sensors or cracked header that will effect readings or the connection to overpipe. Anything past overpipe is unlikely to effect reading. The front 02 sensor is good enough for NA boosted you would definitely need wide-band due much richer afr under boost. The oft tunes have rescaled the front 02 sensor to about 11.3 afr from memory. stock scaling is 12.1 i think. |
| The Following User Says Thank You to steve99 For This Useful Post: | Koa (02-19-2015) |
#115 |
Drives: Asphalt FR-S
Got my answer back from OF: No custom tune for the GS intake is available for stage 2. So, just use the OTS Stage 2 map if you have a header or wait for this custom made one here
| The Following 2 Users Say Thank You to Mad1723 For This Useful Post: | FrostedFlakes (02-20-2015), Koa (02-19-2015) |
#116 | |
Drives:
#117 | |
Drives: FRS-Raven-MT
This is a log after I rescaled off of your maf scale. This was around 80F though, which isn't bad for around here. Days like this are rare in Florida. |
| The Following User Says Thank You to TruRace For This Useful Post: | Koa (02-19-2015) |
#118 | |
#119 | |
Drives: FT86
All stage 2 petrol maps have same maf scaling regardless of calid but the maf scaling between stage 1 & 2 maps and E85 maps is different. ie you can take scaling from a stage 1 700G and put it in a stage 1 B01D |
#120 | |
Drives: 2013 Raven FRS
#121 | |
This is most of the work that needs to be done to have the v2.06 tune play nicely with the intake and header combo. A side note, off-the-shelf tunes are often needing a rescale or tweak to get to work with your system, even with identical parts setups. This has many variables to it, but main variables are fuel quality and environmental conditions. Just some food for thought, hope you try it out. Let me know if you need any help
| The Following User Says Thank You to Koa For This Useful Post: | FrostedFlakes (02-21-2015) |
#122 |
Drives: 2014 FR-S 6MT Whiteout
It's been a while since I've flashed with my OFT so can someone refresh my memory?
When I go to install the tunefile for the Grimmspeed CAI, do I need to reflash to stock first and then install the file for the GS CAI, or will the OFT allow me to flash the GS CAI file over the tune I already have installed?
#123 | |
Drives: FT86
| The Following User Says Thank You to steve99 For This Useful Post: | phobos512 (02-20-2015) |
#124 |
Ok awesome thanks!
#125 | |
I'll take a log tonight but after 3 days with the fix, IAM has not dropped to .88 once. It would do that every day coming home w/ traffic. Mixed weather conditions as well past few days so there's that |
#126 | |
Drives: FT86
| DIY - GrimmSpeed Intake Installation Guide | GrimmSpeed | DIY (Do-It-Yourself) Guides | 60 | 09-08-2017 10:12 AM |
| ** GrimmSpeed BRZ/FR-S Air Intake - GROUP BUY ** | GrimmSpeed | Engine, Exhaust, Bolt-Ons | 1902 | 08-29-2017 07:47 PM |
| GrimmSpeed Intake Before and After OFT Tune + Review | F1fletch | Engine, Exhaust, Transmission | 76 | 06-30-2016 02:40 PM |
| For Sale: GrimmSpeed Intake *newish* | xDanger_208x | Engine, Exhaust, Bolt-Ons | 13 | 11-30-2014 10:16 AM |
| WTB GrimmSpeed intake | VakaGT | Want-To-Buy Requests | 0 | 11-18-2014 12:19 PM |
