#29 |
Drives: 2017 Subaru BRZ PP
Good stuff. So in simpleton terms, is our stock front suspension setup good enough for aggressive street driving with only grippier tires? Would it be entirely beneficial to add more camber via the OEM camber bolts? Are there any adverse effects of doing that (aside from potentially a little less braking traction)?
Also, do you think there is any advantage to this McPherson strut design (aside from less/lower down unsprung weight) compared to other McPherson and double wishbone designs?
Toyota + Subaru =
#30 | |
Drives: '13 BRZ Ltd
I don't think there is anything novel about the BRZ strut design - it's pretty straightforward, simple - definitely not as complex as some other front strut arrangements I've seen (BMW, Ford, ...). I think the handling ability of the BRZ is more due to being low weight, light weight, low polar moment, etc, rather than suspension wizardry. |
| The Following User Says Thank You to Wepeel For This Useful Post: | Bristecom (02-04-2014) |
#31 |
Drives: 2013 Premium White, 2006 TL
I'm still a little confused on Caster. Is this what we need? .5 more degrees?
I'm trying to read and figure it out, but this stuff is a little over my head right now. http://www.whiteline.com.au/product_..._number=KCA434 |
#32 |
Pegasus White
Drives: 86
This thread hurts my head and I don't know how I should have the car setup :'(
Driving: Pegasus White Manual GTS 86.
| The Following User Says Thank You to DriftEightSix For This Useful Post: | DrDuquette (03-03-2014) |
#33 |
#34 | |
Drives: '13 BRZ Ltd
| The Following User Says Thank You to Wepeel For This Useful Post: | DrDuquette (03-04-2014) |
#35 |
Toyotas don't have boxers
Drives: GTV86, ISF, TE27
Interesting read, thanks.
It would be great if someone with coding experience could put together a SAI and scrub radius calculator, with variables being wheel/tyre size, wheel offset, camber adjustment at tophat, hub, and LCA. Similar to the wheel fitment program that was written. I've changed my wheel offset from +48 to +16, and I'm interested in knowing how much I should be increasing SAI to counter the offset change and subsequent increase in scrub radius. I'm thinking that I'll then need to run a positive camber setting at the hub, to offset the excessive neg camber from increasing the SAI. |
#36 |
Drives: Lava 2014 Scion FRS
That's only because of how much grip comes from the downforce. The basic suspension geometry rules still apply.
#37 | |
-1 to -2 degress of camber all the way around add a little bit of caster correct roll center proportionally for any drop in ride height. |
#38 |
#39 |
Junior
Drives: a car
Its hard to limit what changing caster will do to just camber, there is an almost infinite amount of stiffness you can increase or decrease from the chassis along with spring rates, LCA's and toe.
It would be interesting to see if anyone could stick in some alternate caster settings into the proper suspension model sticky.
#40 |
Junior
Drives: a car
| Tein Flex Z Coilovers | Evasive Motorsports | Brakes, Suspension, Chassis | 54 | 07-16-2017 01:21 AM |
| Raceseng | Billet Aluminum Caster Camber Plates | Raceseng | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 162 | 12-29-2014 10:32 AM |
| *FREE alignment* When you get Front Camber Bolts and Rear Camber Arms Installed! | Corner3garage | Mechanical Maintenance and Tools | 6 | 10-31-2013 03:40 PM |
| Rear Caster Adjustment Questions | RWDRIFT | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 12-05-2012 11:47 AM |
