Drives: 2013 Scion FRS
Worth buying joint pipe now or later?
Hey everyone. I'm going to be pulling the trigger soon on Tomei EL headers and was curious to know if it's worth shelling out the extra bit of money on getting the matching joint pipe or would I be okay with passing up on it for now? My car will be set up for street and autox and will be getting a tune hopefully by the end of the year. Thanks!
#2 |
That Guy
Drives: 2013 asphalt FRS MT
I read joint and pipe and expected a completely different post. Oh well.
| The Following 11 Users Say Thank You to Calum For This Useful Post: |
#3 |
Drives: Toyota 86 GTS
Get some of that medical overpipe. That's the shit.
#4 |
Drives: 2014 Subaru BRZ
You should totally pass it my friend. It's for sharing.
| The Following User Says Thank You to veck For This Useful Post: | Tcoat (02-20-2015) |
#5 |
Drives: 10 Series #974 6m/t
If you mean overpipe then yes as it will allow more flow which is a plus.
#6 |
Drives: 2013 FR-S, 2016 Miata Club
Hehe... I'm hungry...
Ok, anyways... if you mean overpipe, I would get it now. It will make taking it out easier with everything out of the way during the install rather than taking everything out again and installing it later. Plus the added flow is a plus. It's one of those pita installs. At least for me it was. |
| The Following User Says Thank You to JimmyMac For This Useful Post: | Bakemono858 (02-20-2015) |
#7 |
Drives: 1FRS, 1 BRZ, 2S2000s, Evo8, Dak.R/T
"Worth it" is a judgement call based on your priorities. Yes it will add power...approx. 10hp/10tq. It will remove one of the 2 catalytic converters. (Unless you get a version with Race Cat.) The other cat is in the stock header, which will also be removed when you install the Tomei EL header. Until you get a tune, this will throw a code and trigger your Check Engine Light most likely. Replacing the stock overpipe will also make the exhaust louder. (Not sure what you're running for cat-back.)
I would recommend a tune as soon as possible after replacing the stock header in lieu of getting the overpipe and waiting on the tune personally. A good tune+header will give you a nice bump in hp and remove the torque dip.
| The Following User Says Thank You to killboy For This Useful Post: | Bakemono858 (02-20-2015) |
#8 | |
#9 |
| The Following User Says Thank You to Tcoat For This Useful Post: | BRZerk (02-21-2015) |
#10 | |
10HP/10TQ for what kind of setup.. free flowing cat or non? Not knocking ya, just interested |
#11 | |
#12 |
With the stock catback, the sound won't be too bad at all. I've done full cat less on the stock cat back with my P&L EL header setup. No drone at cruising speed (65-70 mph) and only loud when you get on it. Great setup if you want the performance without your ears ringing.
#13 | |
Drives: 2013 FRS
| The Following User Says Thank You to Cop For This Useful Post: | Koa (02-20-2015) |
#14 | |
| The Following User Says Thank You to Koa For This Useful Post: | stugray (02-20-2015) |
| Buying Fr-S, this one worth checking out? | Fang | Scion FR-S / Toyota 86 GT86 General Forum | 9 | 11-07-2014 03:31 PM |
| Series 10 - Still worth buying new? | Double_Clutch | Scion FR-S / Toyota 86 GT86 General Forum | 16 | 08-14-2014 04:40 PM |
| buying salvage twin for track worth it? | WATCHMEHEAL | Tracking / Autocross / HPDE / Drifting | 15 | 09-03-2013 03:31 PM |
| Contemplating buying used BRZ with tons of mods but is it worth it? | Sebaru | BRZ First-Gen (2012+) — General Topics | 48 | 07-19-2013 11:25 AM |
