#183 | |
Kuruma Otaku
I also redid Stu's formulas comparing stock vs a 15 lbs reduction of driveshaft (and total car) mass and came up with a difference of 99 milliseconds, which is over an entire car length at 100 mph. Very, very noticeable. So far none of you have corrected any math failings on my part (which could very easily exist), so you look like you are taking Stu's numbers on pure faith and don't actually know what your talking about yourselves beyond math=good. Alternatively my math is correct and it's too hard to argue that a car length difference on a 0-100 pull isn't noticeable.
Because titanium. |
| The Following 3 Users Say Thank You to Dimman For This Useful Post: |
#184 |
Drives: 2013 GBS BRZ Limited
Now we are arguing what the definition of "noticeable" actually is......
| The Following User Says Thank You to stugray For This Useful Post: | Koa (02-18-2015) |
#185 |
I would 100% claim that a lightweight driveshaft is noticeable.
That's why CSG sells them. |
| The Following 3 Users Say Thank You to CSG Mike For This Useful Post: |
#186 |
Drives: 2012 WRX, 2003 RSX Type S
I like Freschetta brick oven pizzas.
#187 | |
Happy to hear you're satisfied with your purchase. I would throw $400 at a well designed aluminum one piece if I felt it warranted the expense. For now, that $400 could buy me a track day and increase my times exponentially. I'm that novice of a tracker and not afraid to admit it. A race team is definitely going to want every millisecond and increased safety and will not bat an eye to spend that on an alu shaft. Glad we can agree on something <3 |
#188 | |
#189 |
Fuck. Check and mate. You're the only guy who's butt dyno I believe.
#190 | |
)That's what it is all about. Pushing it forward. Sorry if I detracted any meaning from this discussion with unwarranted or crass responses or digs. Not the intent.. |
| The Following 4 Users Say Thank You to Koa For This Useful Post: |
#191 |
Dismember
Drives: 2013 Red Scion FR-S
Regarding critical speed...
Assuming top speed of 143mph in 4th gear... Driveshaft RPM = (MPH)(1056)(Differential Ratio) / (Tire Diameter)(Pi)(gear ratio) So... Driveshaft RPM = (143MPH)(1056)(4.1) / (24.1)(3.14159)(1.213) 619132.8/91.839042947 = 6741.5rpm at 143mph in 4th gear, everything stock. That means, at most, a stock car needs a drive shaft that can handle a bit over 6741.5rpm. So what is the critical speed of the AL drive shaft? I don't know how long the tubing is. ~6700rpm+ is my best guess for 52".If it's 50", more like ~7250rpm.
#192 | |
Just out of curiosity: WHO has tested this with JUST the driveshaft upgrade? Most of the anecdotal evidence came from people who did multiple upgrades (some including the FW) all at once. And I'll bet Mike can tell the difference between driving with all of the electrical accessories on vs off too! (not joking there, and not counting AC pump). And I have absolutely zero problem with this upgrade - when done for the right reasons. The lighter driveshaft: supports hp above stock, reduces NVH, is not susceptible to corrosion, probably safer in a rear-end collision, and WILL make some difference in performance. However unless you intend to do all the other upgrades to reduce rotational inertia, there is very little ROI. If you want to make reductions in rotational inertia, here are the places to make the change in order of "noticeable"effect: 1 - Tires (lighter, shaved, near end of life) also reduces unsprung weight 2 - Wheels (lighter) reduces unsprung weight 3 - Brake rotors reduces unsprung weight 4 - Flywheel, Pressure plate 5 - Pistons & Rods 6 - crank 7 - belt driven accessories 8 - pulley drive belt (edit - sorry meant cam drive/timing chains) 9 - Cams 10 - crank pulley 11 - driveshaft & axles ... 99 - Crank pulley bolt. Disclaimer (you apparently NEED this on this forum): the above is My SWAG (scientific wild ass guess), but chances are that I am close. So if you want to "feel" a difference on an otherwise stock vehicle, put the $400 towards some better wheels and have your tires shaved. Last edited by stugray; 02-18-2015 at 01:46 PM. |
| The Following 2 Users Say Thank You to stugray For This Useful Post: | Koa (02-18-2015), Ultramaroon (02-18-2015) |
#193 | |
You can use better software and perform a more detailed analysis including friction and all those other variables, and you will STILL be somewhere in the 1/300 range for difference in stored energy of the system vs the driveshaft. No way around that. I KNEW this before I even did any calculations because it is OBVIOUS. Consider it another way: If I stood back and clocked someone over the head with a 30 lb driveshaft that had 3800 joules stored in it, that person would likely get up and kick my ass. If I hit that same person with a 2800 lb car that had 1272176 joules stored in it,it would separate all their appendages, then fly through the person and knock down the building behind them. Just a simple visualization of the problem is all that is required to "see the forest through all the trees". ![]()
| The Following 4 Users Say Thank You to stugray For This Useful Post: |
#194 |
Junior
Drives: a car
Stu idk why youre still wasting your energy.
#196 |
Junior
Drives: a car
This thread is hilarious.
I dont care if anyone thinks this mod is noticable or not. My physics professor and textbook prove that the math behind the process of lighter weight materials used as a substitute for a driveshaft are most definitely below the threshold of human sensation. I would be more invested in this argument, as i love a good debate (without name calling and harsh words and blatant, '@$!# you' comments lol). But i have studying to do. I will keep track of this thread though. It provides me with some comical relief
| Lightweight aluminum drive shaft installed. | stockysnail | Northwest | 18 | 02-04-2020 11:18 PM |
| Driveshaft Shop Aluminum Drive Shaft. | FT-86 SpeedFactory | Engine, Exhaust, Transmission | 40 | 10-15-2015 09:11 PM |
| Invidia N1 interference with Driveshaft Shop aluminum shaft. | xkalelx | Engine, Exhaust, Transmission | 6 | 03-03-2015 09:43 AM |
| Scion FR-S / Subaru BRZ Drive Shaft Shop Carbon Fiber Drive Shafts In Stock | Anthony@RWHP | Transmission and Driveline | 4 | 12-25-2013 08:09 PM |
