Old 02-13-2015, 12:33 AM   #1
nuccifilms
Drives: 2013
any help to get my engine light off?
i bought catless headers, and love the mod. only engine light came on after a few miles (as expected) spacer came in the mail the next for the after cat o2 sensor. installed right away, and engine light goes off a few miles later. should have been end of story, but the engine light returned following day. i thought of trying another spacer with a different apurature, but instead i went with the wiring mod with the 1 uf capacitor and 1 mega ohm resistor (wired correctly) this time engine went off immediately at start of the engine. i thought i was home free again, until engine light returned again, this time with the spacer and wiring resistance in play? i guess i'll have to get a code reading to know what's going on. anyone's educated guess if i could now be overdoing the sensor mod to a too low reading or something by employing both signal reducing methods?
nuccifilms is offline   Reply With Quote
Old 02-13-2015, 01:44 AM   #2
tyrantcf
Drives: '16 WRX, CBR1000RR
are you kidding? Why are you going so far out of your way to make a BS spacer work? GET A TUNE.
Phantom ESC'd Build Thread (Retired):http://www.ft86club.com/forums/showthread.php?t=75293
tyrantcf is offline   Reply With Quote
The Following User Says Thank You to tyrantcf For This Useful Post:
kch (02-13-2015)
Old 02-13-2015, 01:55 AM   #3
aznatama
aznatama's Avatar
Drives: 2014 BRZ MT (Sold); 2006 V70R
you're going to be running all whack afr's w/o a tune, GET A TUNE before you break more things
'14 BRZ LTD MT DGM
aznatama is offline   Reply With Quote
Old 02-13-2015, 02:00 AM   #4
kiichiro
corolla specs/GTR looks
Drives: ooh oooh pretty tail lights
disabled code=tune
SOLD THEM BOTH
Hers: 2007 987S
Mine: 2012 991S
That was fun, thanks Hachi
kiichiro is offline   Reply With Quote
Old 02-13-2015, 02:24 AM   #5
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Get a proper tune... like right away. Get the priority straight.
Old 02-13-2015, 08:13 AM   #6
BlackMonarch
Drives: Red BRZ
The code is going to read P0318: Get a fucking tune.
BlackMonarch is offline   Reply With Quote
Old 02-13-2015, 12:00 PM   #7
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
If you haven't seen it yet the answer is a proper tune! Its been proven that the spacer trick is dumb and temporary and you'll gain way more with a tune. Get an ecutek tune from say ft86speedfactory and get it over with
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post:
pinski (02-13-2015)
engine light, o2 sensor, oxygen sensor
traction light, engine light = cam sprocket , ecu nivek111070 Issues | Warranty | Recalls / TSB 27 03-13-2016 10:28 AM
Check Engine light on @5.7k miles and engine stalling at 4,000 rpms? djdrugga24 Issues | Warranty | Recalls / TSB 3 06-25-2014 07:06 AM
Will I get a check engine light on if the engine bay has a direct injection failure? Astroboy Engine, Exhaust, Transmission 7 03-29-2014 07:16 PM
Will not rev over 4000rpm and engine light on. 000 Racing Engine, Exhaust, Transmission 14 10-03-2012 08:36 AM
Engine sputtering while idling with check engine light flashing, WTF speedy racer Scion FR-S / Toyota 86 GT86 General Forum 15 08-27-2012 07:50 AM
