#2941 | |
Drives: 2013 BRZ Premium Dark Gray Metallic
Oh, no... not the same feeling at all. Just like I said normal City driving, so no pedal to the metal or high RPM's. So at low RPM's and just doing my regular in City routine it's fine. Of course if I try spirited driving then I do feel that I'm not boosted. What my point is that I have a normal working non-boosted car without a belt. If that makes sense. Limp could mean a lot of things. But yes it's not as much fun driving not boosted. If you mean limp by not having that much WHP then I agree with you.
KraftWerks SuperCharger C30=HB-Waterless Coolant-(Mishi)Racing Thermostat & Oil Can
Tomei EL-PLM Overpipe-HKS Dual Resonated Front Pipe-Invidia N1 DR31 18x9+38 Square w/ 255/40r18 PT-722, TRD Quickshifter, ACT Streetlite Kit Moto-East Flex-Fuel Kit (Almost running 100% E85 all the time) DW 700 cc Injectors-Tune by (Moto-East)-KW Oil Cooler |
#2942 |
Boosted Noob
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
I had a belt problem as well, but not the Kraftwerks S/C belt. My accessory belt fell off after a hard shift into third. See my other post here. http://www.ft86club.com/forums/showthread.php?t=81319
My car overheated cause the water pump stopped working. I towed my car home via AAA. The next morning I found that one of the OEM idler pulleys seized (the one to the right of the crank). I have a new part coming on Tuesday. Hopefully replacing the seized pulley will fix the problem. Hoping it won't be too much of a pain in the ass to remove the KW/Rotrex assembly to get at the idler pulley. Sent from my iPhone using Tapatalk Last edited by mit_peid; 02-08-2015 at 10:33 AM. |
#2943 | |
I will be replacing my accessory belt as well when I install the new SC belt & pulley's. Are there any better accessory belt than OEM out there?
#2944 | |
Boosted Noob
I'm only aware of one belt claiming being higher quality than OEM - Gates Racing Blue http://www.rallysportdirect.com/Gate...tine-Belt-Blue I just went with another OEM belt (the OEM one I had was a Mitsubishi) since I don't think it was a problem with the belt itself. |
| The Following User Says Thank You to mit_peid For This Useful Post: | zoth (02-08-2015) |
#2945 |
Professional Smartass
Drives: White Out FRS
I'm running the gates blue belt. It appears to be beefier than stock.
| The Following User Says Thank You to post_break For This Useful Post: | zoth (02-08-2015) |
#2946 |
I wonder if any one have a good guide in replacing both belts? @KraftWerks
| The Following User Says Thank You to zoth For This Useful Post: | mit_peid (02-09-2015) |
#2947 | |
| The Following User Says Thank You to post_break For This Useful Post: | zoth (02-09-2015) |
#2948 |
Drives: 2013 whiteout Frs
To clamp the evap hoses under the intake manifold which route did you guys take? Remove intake manifold or remove the ac compressor.
#2950 | |
WRX -> BRZ. (TX)
Drives: 2015 Series.Blue WRB
If you're just now installing the kit, I'd go the a/c compressor route
KraftWerks c3094 SC Kit ARK GRiP w/ test pipe KW V3 OEM Audio + Reference 400CF |
#2951 |
Quote from CJ about being able to drive the car without the SC belt.
"Yeah, just stay below 4000 or so to be safe." Regards, CJ Weidl
#2952 |
I already have it installed so we can't take the ac compressor off.
#2953 |
Drives: 2013 Ultramarine FR-S
#2954 |
| Innovate (Sprintex) Supercharger Owners Topic | DarrenDriven | Forced Induction | 9139 | 12-29-2023 11:58 PM |
| Kraftwerks Rotrex Supercharger Discussion | nelsmar | Forced Induction | 697 | 01-18-2022 01:06 PM |
| All SUPERCHARGER kits compilation thread | subatoy | Forced Induction | 76 | 03-10-2016 01:38 PM |
| Kraftwerks Supercharger?? | umpadupa | Forced Induction | 1 | 08-05-2013 06:27 PM |
