Old 02-04-2015, 10:05 PM   #57
renfield90
The Stig's German cousin
Originally Posted by PowderfaceTr. View Post
Anybody who has a trophy at an SCCA National Event?
Yup. Any questions?
The Following User Says Thank You to renfield90 For This Useful Post:
CSG Mike (02-04-2015)
Old 02-04-2015, 10:09 PM   #58
CSG Mike
CSG Mike's Avatar
Several, but I think they wish to remain anonymous.
Old 02-04-2015, 10:27 PM   #59
ddeflyer
The lack of skid marks on corner entry tell me that the proportioning brake controller works. VSA is off I lay big patches late braking. Somebody is not smooth enough with their inputs if they are getting injector cut. my point all along is if you drove like a pro the ecu wouldn't have a reason to interrupt. Those Hot Version drivers are just having fun with this sporty car. Please adjust your driving style if you cant be fast unless they are off.
First off, most of the time the VSC/TC on these cars is only actuating the brakes, it very rarely cuts engine output (I don't think I have ever had it cut power on me, just actuate the brakes).
Second, your laying skid marks with VSC/TC off speaks to your threshold braking skills, not what is the fastest way around the track in one of these cars (I'm assuming you don't think you are the fastest person in the world in one of these cars).
Third, the VSC will cut in under steady state cornering conditions if there is a filled crack in the track surface. It doesn't matter how good/smooth you are, this is a fact of the nature of the VSC/TC unit in these cars, not the driver.
Fourth, I can be almost as fast with VSC on or off, the difference is that the VSC doesn't permit certain techniques which I can use to improve my time in certain specific corners (it just gets unhappy with that level of slip angle+gforce, though I think there is a sealed crack there that also messes with it).
Fifth: Turning off VSC/TC also permits me to make choices to save the car that I may not be able to make with it on; too many cooks in the kitchen can just make a bigger mess.
Fun car leads to autocross, autocross leads to track days, track days lead to lemons, lemons leads to racing school, racing school leads to spec Miata...
No idea where it leads next!
ddeflyer is offline   Reply With Quote
The Following 3 Users Say Thank You to ddeflyer For This Useful Post:
Akari (02-12-2015), CSG Mike (02-04-2015), PowderfaceTr. (02-04-2015)
Old 02-04-2015, 11:08 PM   #60
stugray
Drives: 2013 GBS BRZ Limited
the e-lsd will try to "fix" inside rear wheel spin, and instead make the car try to kill you.
I have personally witnessed this in the snow with nannies supposedly "off".(I am sure you have read my account)
The Following User Says Thank You to stugray For This Useful Post:
Old 02-04-2015, 11:50 PM   #61
PowderfaceTr.
PowderfaceTr.'s Avatar
Drives: stock
Originally Posted by renfield90 View Post
Yup. Any questions?
Tire questions,
How many laps do you find you get before your comps go hard? Do you find that the Pedal dance shorten the life of your slicks?
Advice On Proper Fundamentals of Japanese Motor Vehicle Feel free to ask.
PowderfaceTr. is offline   Reply With Quote
Old 02-04-2015, 11:55 PM   #62
ddeflyer
Tire questions,
Generally, the lifespan is counted in heat cycles, not laps. Unless use of the pedal dance changes your driving style enough to affect heat input to your tires (which it frankly shouldn't), the lifespan of your tires won't be affected.
Old 02-05-2015, 01:05 AM   #63
raul
Lap time enthusiast
raul's Avatar
Drives: Asphalt '13 FR-S 6MT
To put it simply: you're wrong. Tires need some slip to achieve optimum grip. The nannies intervene before that point, so therefore, you cannot achieve maximum grip with them on. Either you're a massive troll or you haven't driven on track.
Also, a national trophy is indicative of nothing lacking reference. You can walk away with a trophy by simply running a class that doesn't have fully prepped cars or great drivers. For that trophy to matter, you have to reference what event, class and who your competition was.
raul is offline   Reply With Quote
The Following User Says Thank You to raul For This Useful Post:
zdr93523 (02-05-2015)
Old 02-05-2015, 02:06 AM   #64
killboy
killboy's Avatar
Drives: 1FRS, 1 BRZ, 2S2000s, Evo8, Dak.R/T
Originally Posted by AZP Installs View Post
Completely off and pedal dance are 2 different things.
We run it "completely off" (Hold both buttons for 5 seconds) but some folks feel they need to run it in the pedal-dance mode.
-mike
You only have to hold the left button for 5 seconds, FYI.
killboy is offline   Reply With Quote
The Following User Says Thank You to killboy For This Useful Post:
Koa (02-11-2015)
Old 02-05-2015, 03:38 AM   #65
justint5387
Drives: 4 wheels
Tire questions,
I trophied and stayed at the holiday inn express.
The answer depends on what tires you are running.
justint5387 is offline   Reply With Quote
Old 02-05-2015, 03:40 AM   #66
zdr93523
zdr93523's Avatar
Drives: 2013 BRZ Limited
Originally Posted by ddeflyer View Post
I would NEVER want a beginner to go out without traction control enabled.
So you would have never taken anyone on a track prior to the implementation of traction control in modern cars? Ayrton Senna is rolling over in his grave.
Pedal dance is the only way to go.
As far as the beginner TC philosophy...
My wife started from Day 1 with the pedal dance for 3 reasons:
1. With proper instruction and some common sense, a new driver will not over drive the car or their skills.
2. The benefits of learning how to actually control a car without intervention far outweighs the risk of a relatively slower speed incident in a controlled environment. If a driver is unable or unfamiliar with recovering a vehicle from a drift or slide at lower speeds, they're going to be in real trouble once they do get fast and decide to disable the nannies. Remember, loose is fast.
3. The adverse affects of the VSC Sport mode, or 5 sec off are much worse than the dance, such as the tendency for the E-diff to lock a wheel and spin the car when coming off of curbing at high speed. i.e... it tries to kill you, and not in the good Jeremy Clarkson C63 AMG kind of way.
A properly set up 86 has MUCH more grip than the OEM traction program was designed to deal with. I get traction control intervention during smooth left-right weight transfers on curvy off ramps driving at 4/10ths in VSC Sport mode... so much intervention that it can be downright scary and we have completely stopped using that mode.
Instagram: @zdr_93523
Youtube: https://www.youtube.com/user/zdr93523
Pink Ribbon Racing 2013 BRZ Limited NASA ST2 and TT2 race car
www.makesmodels.com
www.camautomag.com
zdr93523 is offline   Reply With Quote
The Following 3 Users Say Thank You to zdr93523 For This Useful Post:
acro (02-05-2015), CSG Mike (02-05-2015), raul (02-05-2015)
Old 02-05-2015, 04:58 AM   #67
ddeflyer
Yeah, I was being a bit over the top with that. At the same time, I am a firm believer in traction control as a safety net for beginners if at all possible. The argument about how to start out has been well fleshed out before so I won't try to rehash it. I think we both know what the conversation would entail/we could probably both do both sides of the debate
The Following User Says Thank You to ddeflyer For This Useful Post:
Old 02-05-2015, 05:01 AM   #68
Doozer
Doozer's Avatar
Drives: gt86...among others
Tire questions,
I find tire wear is the same VSC on or off. However pad life is increased with VSC off due to the brakes kicking in.
I'm always one to try and learn a faster way to drive, so would you mind posting a video of you doing a lap both with and without VSC?
I feel I'm quicker in the 86 with everything turned off (and so do my lap times), but I'm happy to be proven wrong if it means going faster.
We turn off for time attacks, GP sprint races and enduro's.
racing gods live deep in corners
Doozer is offline   Reply With Quote
The Following User Says Thank You to Doozer For This Useful Post:
PowderfaceTr. (02-05-2015)
Old 02-05-2015, 10:11 PM   #69
PowderfaceTr.
Drives: stock
You realize Its ice race season.
Ill check the archives of ancient BRZ videos.
I bought this car for its traction control. Driving the line I would in a 700lbs ground effects car or any car other than a shifter kart. I net the no traction control interruptions. A spec miata is multiple second slower than a VSA on BRZ.
Old 02-05-2015, 10:57 PM   #70
ddeflyer
Given the variations within spec Miata and the strengths and weaknesses of such different platforms, a blanket statement that a stock BRZ/FRS is always faster than a spec Miata (or the other way around) is provably wrong. There are places that a spec Miata will easily spank a stock BRZ/FRS. There are also places where a stock BRZ/FRS will annihilate a spec Miata.
Also, seriously, you bought one of THESE cars for its traction control? If you were going to buy a car for excellent traction control you should have looked at some of the others out there. There are alot of cars with much more fine tuned / track oriented VSC/TC systems out of the box. Frankly, the BRZ/FRS has kind of ham fisted traction control (at least compared to other modern cars).
Additionally, one of the most important skills a driver is the ability to adapt to the strengths and weaknesses of their vehicle. The fastest line in a aero vs. non aero car really should be different. Even within your general street car type vehicles, variations in setup can change traction properties in ways that will vary your line some. For example, a car with soft sway bars might eat an inside curb in a corner while one with crazy stiff sway bars would end up hopping its traction wheels if the same thing is done. Always driving an identical line between cars means you are, by necessity, leaving time on the table.
How to disable Traction Control (TC) and Vehicle Stability Control (VSC) Completely Sigh-on-Rice DIY (Do-It-Yourself) Guides 58 03-02-2015 02:48 PM
Traction Control vs. Stabilization Control vs. Sport Question MurderRider Scion FR-S / Toyota 86 GT86 General Forum 26 08-07-2014 01:56 PM
Why does my BRZ have LESS traction with traction control on??? BRZnut BRZ First-Gen (2012+) — General Topics 19 12-16-2013 04:28 PM
First time traction control off experience Nate219BRZ BRZ First-Gen (2012+) — General Topics 6 08-13-2012 04:35 PM
Disabling Traction Control (TC) and Vehicle Stability Control (VSC) Completely BabyGodzillaGTi-R BRZ First-Gen (2012+) — General Topics 40 04-25-2012 12:20 PM
