#15 | |
Drives: 2014 BRZ MT (Sold); 2006 V70R
Stock setup is as follows: Dash speakers - mid/high run off stock HU Door speakers - woofers ONLY run through an amp in the trunk that FILTERS mid/high frequencies. The guy who recommended it had an aftermarket HU, likely running these through the aftermarket HU directly. From what I understand about the stock audio system, your best bet on your budget is to get a set of components that will fit the dash and not touch doors, or a set of components w/ woofer/midrange in door and tweeter in dash and all stock front speakers. Both will likely need to be run off a small amp, but can be done in your budget if you're doing all the labor. Last option would be to locate and remove stock amp, replace with regular 2ch amp, use that to drive full range door speakers.
'14 BRZ LTD MT DGM
| The Following User Says Thank You to aznatama For This Useful Post: | 86geek (02-04-2015) |
#16 | |
Drives: '16 BRZ Limited
#17 |
Time Traveller
Do this with ~$100.00 - $150.00 and keep your stock components. You'll be amazed
http://sounddeadenershowdown.com |
#18 | |
The Stig's African Cousin
Drives: 2014 wrb brz
#19 | |
![]() Also, from Crutchfield website: "The factory woofer(s) in [the doors] receive only bass frequencies from the amplifier. Replacement aftermarket speakers will only reproduce bass."
'14 BRZ LTD MT DGM
#20 |
Looking at those speakers it looks like it has something that might require you stripping one side of the metra connector. But yea either way using the connector you unplug the speakers and plug in the new connector then plug that into the speakers. Its really simple when you see it.
| The Following User Says Thank You to brandonblt2 For This Useful Post: | meWant (02-03-2015) |
#21 | |
#22 | |
Drives: 2015 FRS Asphalt
#23 | |
Although I haven't explored the possibility, it *may* be possible to utilize the stock amp wiring and location instead of running new wires for power and speakers.
'14 BRZ LTD MT DGM
| The Following User Says Thank You to aznatama For This Useful Post: | 86geek (02-05-2015) |
#24 |
It would work, but would likely be woofer frequencies only, tweeters would not be outputting any sound. I'd check to make sure by playing a high pitched test tone to see if you get sound from the doors.
'14 BRZ LTD MT DGM
#25 | |
#26 |
That's weird. If that's the case, makes things easier. I'll have to look into this some more.
You have all stock wiring? Nothing changed from using the aftermarket Hu?
'14 BRZ LTD MT DGM
#27 | |
Heres my headunit I have nothing special in terms of audio http://www.eonon.com/Car-DVD-Players...ta/GA5167.html |
#28 | |
Drives: 2013 FR-S, Hot Lava; 2012 Z1000 CBO
| Door speakers upgrade / replacement | mike_ekim1024 | DIY (Do-It-Yourself) Guides | 13 | 02-17-2015 07:29 PM |
| New speakers all around! | EightSix93 | Cosmetic Modification (Interior/Exterior/Lighting) | 14 | 01-28-2015 12:20 AM |
| Door speakers don't work after HU upgrade | BigJyoungblood | Electronics | Audio | NAV | Infotainment | 18 | 05-30-2013 11:46 PM |
| Dash Top Speakers / Rear seat speakers | Laurie | Electronics | Audio | NAV | Infotainment | 9 | 03-01-2013 06:31 PM |
| Thoughts on the BRZ radio/gps/speakers - Should we upgrade? | dorkymork | Electronics | Audio | NAV | Infotainment | 21 | 01-30-2013 11:04 AM |
