#15 | ||
Some say.....
Drives: 2007 Subaru Impreza 2.5i
I haven't driven my car since the end of October, so I can't give you my exact pressure numbers, but this all sounds perfectly normal to me. |
| The Following 2 Users Say Thank You to BatStig For This Useful Post: | malave7567 (02-02-2015), Ultramaroon (02-02-2015) |
#16 |
Drives: (formerly) 2013 Raven FR-S
the numbers are in line with my car as well. I have the innovate MTX-D gauge and the TRD sandwich plate, and it will stay pinned at 100 when driving until the oil temperature starts to normalize (10-15 minutes, like what was said).
#17 |
#18 |
Drives: 2006 Pontiac GP (SOLD), 2014 FR-S
The innovate only reads up to 100 psi, its not uncommon to see 120+ psi on cold starts. What weight oil are you running?
Im running 5w30 and i see 36 psi @ 185F which is abnormally high.
"Project cars are like New Years Eve. Endless preparation, hype, a sleepless night of fun, followed promptly by massive headaches and regret." - Anonymous
#19 |
Drives: FRS
#20 |
[ame="https://www.youtube.com/watch?v=cDfFJ5s6IDg"]FRS - BRZ Oil Pressure and Temperature Tech FA20 - YouTube[/ame]
That should provide some good insight on oil pressure and weight @ various temperatures
| The Following User Says Thank You to #maverick# For This Useful Post: | Dezoris (02-02-2015) |
#21 |
You would have wanted a gauge that can read to 150psi.
Cold starts can put pressures up to 120-130psi depending on oil grade and oil temps. For 0w20 you won't see normalized oil pressures until around 175F. For 10w30 it's around 190F. @wootwoot
| The Following User Says Thank You to Dezoris For This Useful Post: | #maverick# (02-02-2015) |
#22 | |
Dude... is that your video? Holy shit, you and that other dude (Turbowski) are hilarious LOL Where in IL are you at?
#23 |
Drives: FRS
Cool. Thanks guys. I'll likely keep the gauge I have. It will still give me the info I need once the engine is warm. I may change the location of the sender at some point but it seems all is well with my oil pressure and that is the important thing. Thanks again boys!
I'll also mention I am very happy with my liquid to liquid oil cooler at this point. |
| The Following User Says Thank You to wootwoot For This Useful Post: | Dezoris (02-03-2015) |
#24 | |
Right now I am in northern illinois, near Algonquin/Crystal Lake area.
| The Following 2 Users Say Thank You to Dezoris For This Useful Post: | #maverick# (02-02-2015), lightdir (02-03-2015) |
#25 |
Haha Sweet!, Im often staying by Schaumburg, if you guys need a test dummy for videos you can use my car :P
| The Following User Says Thank You to #maverick# For This Useful Post: | Dezoris (02-03-2015) |
#26 | |
Drives: 2013 Scion FR-S Ultramarine
Good times
Current mods: OFT Stage 2 (w/93 oct), OFH, Perrin Resonated catback, DSS Aluminum Driveshaft, Perrin drop-in filter, Avo silicone inlet, Mishimoto catch can, Grimmspeed MCB, Perrin crank pulley, Nameless overpipe/downpipe combo, DBA slotted rotors, Ferrodo brake pads, goodrich SS brake lines, DOT5 synthetic brake fluid.
| The Following User Says Thank You to Xinshadow For This Useful Post: | Dezoris (02-03-2015) |
#27 | |
#28 |
Haha I think I'm the only ultramarine with a UEL setup out here, so I'm kinda hard to miss these days! You should head up to Streamwood for for their Wednesday night Sonic meets at Mxpi when they start back up, it would be nice to have some more 86 love out there!
| Tire Pressure Sensors Question | NoFlush | Mid-Atlantic | 5 | 02-07-2014 06:03 PM |
| Stock clutch+flywheel+pressure plate+ ACT lightweight flywheel & pressure plate | PineappleFriedRice | Transmission and Driveline | 0 | 11-08-2013 04:54 PM |
| Question: TPMS Tire-pressure monitoring system installed on aftermarket wheels | Figo | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 7 | 08-05-2013 12:54 PM |
| Oil Pressure Sender Unit Fitment Question | Captain Snooze | Engine, Exhaust, Transmission | 2 | 07-06-2013 12:41 AM |
| new rim/tire. question about bolts pressure? and etc | WATCHMEHEAL | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 3 | 03-25-2013 05:59 PM |
