#127 |
Drives: Toyota 86 GTS (MT)
#128 |
#129 |
Drives: 86
will 235/45/17 with eibach pro kit experience any issues?
#130 |
Drives: 2013 Firestorm FRS
who is running spacers?
I know the 17x8 +35 works great, so I was thinking of running a 10mm spacers on my +45, so I end up at +35. However, is there any room to go a touch more? 12mm possibly? |
#131 | |
Grip>Drift
Drives: FRS
Do you have extended studs?
#132 |
#133 |
Grip>Drift
Drives: FRS
You can run 10-12mm spacers just fine then.
#134 |
nice! I figured the 10mm spacer would work since that makes the wheel a 17x8 +35, and those fit just fine. And another 2mm isn't much.
Think I'll have any issues with rubbing? Eventually I'll bump up to a 245/40/17. I'm lowered about 1.25" inches, with -2 camber on all corners. Just trying to go as flush as possible without rubbing. I just came from an 18x9 +40, so the +45 looks pretty funny/sunk in right now. People at work are giving me crap haha. |
#135 |
driving smoother faster
Drives: Sold
I'm running rpf1 17x8 +45 on track/ax with AP Racing Sprint BBK, -3f/-2.5r camber, 235/40-17 Toyo RA-1, arp extended studs, Ohlins R&T dampers. They fit both without spacers and with 12mm spacers, no rubbing.
| The Following User Says Thank You to dp1 For This Useful Post: | dsc_pat (12-12-2021) |
#136 | |
You have any photos of your setup? |
#137 |
Drives: Sold
I think that this was with the spacers
#138 |
Drives: Sold
I have a new set of 17x9 +45 rpf1 with 235/40-17 Nitto NT01 that I will try this season, with 12mm spacers to fit BBK.
#139 |
| The Following User Says Thank You to continuecrushing For This Useful Post: | dsc_pat (12-12-2021) |
#140 |
Drives: 2014 BRZ Limited
Just ordered a set of these with star spec tires for my upcoming track day on COTA. Will post pics when I receive them and install them.
| Tags |
| 17x8 +45 with 235/45/17, full lock, whatwasthatfrigginsound, wheel pop, wheel rub |
| Wheel Directory: Enkei RPF1 17x9.0 +35 | D1cker | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 801 | 06-18-2024 06:31 AM |
| Wheel Directory: Enkei RPF1 17x9.0 +45 | LevinPhan | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 265 | 06-04-2024 11:13 AM |
| Wheel Directory: Enkei RPF1 18x9.5 +38 | FRS8SIX | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 297 | 02-15-2018 03:50 PM |
| Wheel Directory: Enkei RSM9 17x8.0 +48 | AsianStyle | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 13 | 02-17-2014 06:50 AM |
| Wheel Directory: Enkei RS+M 17x8.0 +35 | FT-86 SpeedFactory | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 37 | 02-12-2014 04:26 PM |
