go_a_way1
Old 01-29-2015, 12:42 AM   #2633
Slick
Slick's Avatar
Drives: FR-S Firestorm 6MT
Originally Posted by revolutioN21 View Post
wanted to get the rpf1 for tracking my car. i was thinking of getting a 17x9 and running either a 235/35 or 245/35 tire and plan on getting a BBK in the future. I currently have kw v3 coilovers and camber plates.
Go with a +35 offset in a 17x9, should have no issues with a BBK.
Run a 245/40R17 tire.
You won't find tires in the sizes you quoted above anyway.
Slick is offline   Reply With Quote
Old 01-29-2015, 01:30 AM   #2634
ExxelDistributions
ExxelDistributions's Avatar
Drives: 2014 FR-S 6MT Monogram Series
ok kool thanks for the input
ExxelDistributions is offline   Reply With Quote
Old 01-31-2015, 11:36 PM   #2635
PollosHermanos
PollosHermanos's Avatar
Drives: 2014 SWP BRZ Limited 6SP
OK, I've changed my plans and now I'm looking at a square set-up 18x8 +45 running a 235/45/18.
Should I be looking at a wider tire or mabe a smaller sidewall? I think either 40 or 45 will be fine rubbing wise but Im curous what others think.
1990 Laser RS - Lights go up, lights go down ||1992 MX-6 Coupe - Hah ... no || 2001 Integra GSR - Almost rice. Risotto || 2003 IS300 - A nice car but no fun. || 2011 Stage I GTI - Lots of fun. Would buy another
2014 BRZ - That BRZ. So hot right now.
PollosHermanos is offline   Reply With Quote
Old 02-01-2015, 07:28 AM   #2636
Slick
Slick's Avatar
Too tall of a tire, plus I don't even think you'll find that tire size in any performance tire or many brands except for Continental.
Choose from one of the following:
  • 225/40R18
  • 245/35R18
Even a 235/40R18 is a bit tall but doable but is not as common a tire size.
For the wheel size, I would go with a 225 unless you need extra width, then a 245/35 would work.
The Following User Says Thank You to Slick For This Useful Post:
PollosHermanos (02-01-2015)
Old 02-01-2015, 08:11 AM   #2637
PollosHermanos
Great - appreciate the help.
  • 225/40R18
  • 245/35R18
Old 02-03-2015, 06:26 PM   #2638
hayden55
Drives: 2013 FRS
Does it fit?
17x9 et52mm rim
255/40/17 dunlop direzza zii star specs.
Aiming for basically no camber to be flush.
Im okay with getting full suspension and trimming wheel wells, im just not okay with excessive camber and the tires sticking out of the wheel well.
So with a set of AST 4150's and the full alignment array of parts you think it will fit? Its not that far off what i've seen others run still a beefy setup though.
Let me know! All help appreciated!
hayden55 is offline   Reply With Quote
Old 02-04-2015, 12:47 AM   #2639
SkyBRZ
SkyBRZ's Avatar
Drives: 2015 Subaru BRZ
Hey there,
New Brz owner here, 2015 Limited.
I am currently looking at buying ROTA D2-Ex wheels 18x9.5 +38mm 73
with the sumitomo tires 265/35ZR18
I currently have Tein S-tech lowering springs on the car
Im unsure if the wheels will fit in the front just because of the width?
Thanks for any help!
SkyBRZ is offline   Reply With Quote
Old 02-04-2015, 10:26 AM   #2640
Slick
Slick's Avatar
Originally Posted by hayden55 View Post
Does it fit?
17x9 et52mm rim
The +52 offset is too high. Some are running 17x9 +45 and still have issues once they lower and then they need to add spacers. For flush look, look for an offset closer to +38-42.
And why no camber?
Understand not wanting excessive camber, but getting some negative camber helps with handling and fitment too.
Old 02-04-2015, 10:53 AM   #2641
FRZ-BRS
I'm really in love with the look of the flat black MB Battle wheels. I am lowered 3-3.5 inches on BC Racing coilovers.
Unfortunately they only come in 18 X9.5 5x114.30 23 offset.
As our cars are 5x100 I would have to purchase 15mm conversion spacers.
I also plan on purchasing the GT Spec toe kit & Powered by Max rear lower control arms.
How can I make these fit without having it super cambered out & without rubbing at the same time? & what kind of tire specs should I go for?
Here is an idea of how low my car is:
FRZ-BRS is offline   Reply With Quote
Old 02-04-2015, 11:06 AM   #2642
Slick
Slick's Avatar
They won't fit unless you go crazy nuts with camber (see Aggressive Wheels thread = Stanced crowd)
Starting with a +23 and adding a 15mm spacer will give you an effective offset of +8. That's not even close to what you need especially when trying to fit a 9.5" wheel.
Old 02-04-2015, 11:18 AM   #2643
FRZ-BRS
Thanks for the speedy reply!
Here's another alternative then.
The Gunmetal Grey MB Battles come in: 18 X8 5-114.30 43 offset
Adding the 15mm adapters would make it come out to +28
That should be able to fit & sit flush correct? What kind of tire specs should I go for? I was thinking 215/35/18.
Old 02-04-2015, 12:06 PM   #2644
FrSnake
Resident Noob
FrSnake's Avatar
Drives: Satin White BRZ Limited
Looks like I am going to go a diff direction.. how about 245/35/18's with 18x8 +45? will it run fine on stock without rubbing?
USAF2013 SWP BRZ Limited- CAI, Borla Cat-Back Exhaust
“Speed has never killed anyone, suddenly becoming stationary… That’s what gets you.” -Jeremy Clarkson
FrSnake is offline   Reply With Quote
Old 02-04-2015, 12:42 PM   #2645
Slick
Slick's Avatar
Yes, much better for stock, gives you a bit more leeway.
You could go with the 245/35 (meatier), or 225/40 (smaller) but more ideal for the 8" wheel size. You should have no issues if you want to run the 245's and both tire sizes are perfect OEM diameter.
No rubbing either way.
Old 02-04-2015, 05:16 PM   #2646
hayden55
Drives: 2013 FRS
And why no camber?
* looking for a 52 offset for the rear and 45mm offset in the front. Then i can change up wheel studs and spacers to get what i need since rims for this car arent very common.
Mostly i want a rear tire that is straight up and down and has the largest contact patch in a straight line for boost, and up front i wouldnt mind a 1-1.8 ish degrees of camber for fitment and a little bit of grip in the corners.
Still kinda thinking about everything
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 10:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 03:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 03:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-13-2012 12:21 AM
