Old 01-30-2015, 05:16 AM   #15
Marco_86
Drives: 14' Frs Raven
Just try Chevron it has definitely helped mine out. The idle in these cars are fairly rough so I wouldn't worry too much on that.
Marco_86 is offline   Reply With Quote
The Following User Says Thank You to Marco_86 For This Useful Post:
Jake_86 (01-30-2015)
Old 01-30-2015, 10:15 AM   #16
TheVoiceOfReason
TheVoiceOfReason's Avatar
Drives: BRZ Limited
Originally Posted by Jake_86 View Post
I have aftermarket intake and exhaust which i also heard can cause a problem.
I think an aftermarket intake can affect MAF scaling, which may affect your idle. I wouldn't be the one to ask if that is 100% the case. One more reason to get a tune though. An exhaust shouldn't affect this at all.
TheVoiceOfReason is offline   Reply With Quote
The Following User Says Thank You to TheVoiceOfReason For This Useful Post:
Old 01-30-2015, 01:02 PM   #17
BRZnut
Drives: BRZ DGM Limited
Some have found that adding 2-cycle oil to the gas can make the chirps much less of an issue, supposedly but adding lubrication to the high pressure fuel pump:
http://www.ft86club.com/forums/showthread.php?t=21980
Old 01-30-2015, 01:24 PM   #18
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
Chirps:
Just stop. They are not harmful, but with the rate of their discussion on this forum you would think it gonna kill the last known bison.
Dont try switching between 900 different gas stations, don't add bs/garbage/additives to the fuel, dont participate in voodoo, do drugs or replace every part trying to make it go away.
Just live with them. They are here to stay.
Low Idle:
Common issue. If they dealer will flash the computer to see if that helps. If they won't /it doesnt help, pickup an openflash tablet. They have "canned" tunes that you can choose based on your mods, and should help the idle issue.
Final note: Intakes don't seem to play real well with the car since most of them mess with the MAF readings, so that could contribute to hesitation/running issues. Catback won't effect anything, other than making you sound cool (good thing).
The Following 5 Users Say Thank You to continuecrushing For This Useful Post:
billyk (01-30-2015), Jake_86 (01-30-2015), kch (01-30-2015), TheVoiceOfReason (01-30-2015), Ultramaroon (01-30-2015)
Old 01-30-2015, 02:30 PM   #19
Tromatic
My car idles like, uhm, a car that idles perfectly. I do have the OFT, and my current tune is based of the latest ROM (B01D) IIRC. The rough idle issue was addressed several ROM editions ago.
OP, go to the dealer, tell them you have the rough idle issue and would like the latest tune. If they won't do it, ask around and see if any of your fellow owners have ROMRaider or an OFT. They can flash the latest stock tune for you.
ROMRaider
The Following User Says Thank You to Tromatic For This Useful Post:
Old 01-30-2015, 02:38 PM   #20
TheVoiceOfReason
Drives: BRZ Limited
ROMRaider
Someone else with an OFT can't use it to just flash a tune to another car.
Old 01-30-2015, 03:03 PM   #21
Tromatic
Unmarry, flash. Can be done.
Old 01-30-2015, 03:05 PM   #22
Koa
He meant to say OFT cannot flash multiple cars
The Following User Says Thank You to Koa For This Useful Post:
Old 01-30-2015, 03:09 PM   #23
Chanpion
Drives: 13 FRS Satin
Ignore the chirps, it's harmless, and many new pumps squeak as well. Octane seems to have little to do with it. Chevron seems to be the "best" for my chirps, but I also use a fuel lube. When running E85 they vanish.
Idle, dunno. DO you have any sort of software tune in your car? If not, asking for the latest ROM might be helpful.
I don't know if it's harmful but Toyota specifically does not recommend high ethanol percentage fuels. Just saying.
Unless yours has been modded, then drive on son.
EDIT: Whhops, didn't read the other comments/ Ignore this one.
Chanpion is offline   Reply With Quote
Old 01-30-2015, 03:32 PM   #24
Tromatic
Opps, yeah, I meant ROMRaider.
'14 BRZ Ltd. - Rough Idle leicaboss BRZ First-Gen (2012+) — General Topics 20 05-22-2014 07:40 PM
CEL, Skid Light, Rough Idle ... SherbFrs Issues | Warranty | Recalls / TSB 8 07-18-2013 07:43 PM
Looks like CEL/Rough Idle is getting a lot more attention. wawro569 Scion FR-S / Toyota 86 GT86 General Forum 11 10-06-2012 01:24 AM
Rough Idle & CEL *video JiB Issues | Warranty | Recalls / TSB 5 10-04-2012 11:28 PM
