Old 10-06-2013, 10:30 AM   #15
Migero86
Migero86's Avatar
Drives: 2015 Trailhawk
From my previous post a while ago, I made my OEM shift knob solid by filling it with resin, this reduced a lot of the rattle I was experiencing... Friday night I put in a modified intake that has no resonators on it, my shifter seems to no longer rattle under acceleration at any RPM range.
This leads me to believe that this rattle is due to harmonic resonant frequencies since mine would only rattle between 4000 - 6000 rpm under certain loads. Brought me back to memories of my old mustang, it was the king of all my cars for rattling at certain frequencies coming from the exhaust and intake.
It could be a fluke of nature that both these items stopped my issue, however, still unacceptable that a manufacturer cant figure it out properly based on all these posts. It could also be that slight manufacturing variances within the min-max acceptable quality levels changes which car rattles and which does not.
Migero86 is offline   Reply With Quote
Old 10-06-2013, 12:50 PM   #16
RevoG
RevoG's Avatar
Drives: Hot Lava 86 MT
I'm hoping that my next mod (read UEL header) will solve this. I have the same thoughts that this rattle is frequency dependent.
Certain rpm and load sets it off. Let's see.
JR Supercharger, JR RS Pulley, JR Oil cooler, JDL UEL header, Dual resonated 3" JDL Overpipe Front pipe, Perrin 3" resonated cat back exhaust, Upgraded Koyorad radiator, ECUTek tune, Enkei RS05RR 18x9.5, Bridgestone RE003 265/35/18, KW V3 Coilovers, Valenti sequential taillights, Kartboy short shifter kit
RevoG is offline   Reply With Quote
Old 01-28-2015, 05:21 PM   #17
ckim
Drives: '15 DGM STi Limited
Reviving a dead thread... but did the UEL header solve the problem?
ckim is offline   Reply With Quote
Old 01-28-2015, 05:33 PM   #18
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
Well harmonics do cause vibrations, but dampening the sound is not fixing anything.
The rattle is from loose parts or parts just not fitting together properly. It could even be a damaged part such as my case where my shifter was actually made with a defect.
Sorry for not updating the thread. I wonder if I responded somewhere else...?
Old 02-01-2015, 05:18 AM   #19
ckim
Originally Posted by Brett View Post
Had mine replaced. Now it's louder.
So the TSB made things worse?
Old 04-27-2015, 05:29 PM   #20
Brett
First 86
Brett's Avatar
Drives: Whiteout MT FR-S
Sure did. They eventually replace the transmission and then they replaced the clutch assembly for a rattle there. It still rattles pretty badly.
Don't shop, adopt!
Brett is offline   Reply With Quote
Audible shifter rattle Hanzo Issues | Warranty | Recalls / TSB 134 08-17-2022 03:34 AM
kartboy short shifter and rear shifter bushing install and review. FR-S UMB FR-S DIY (Do-It-Yourself) Guides 21 10-18-2014 02:41 AM
Loud rattle, lots of shaking from shifter...not the knob...its the trans linkage continuecrushing Issues | Warranty | Recalls / TSB 8 05-18-2013 12:56 PM
Paddle shifter replacement? BRZPDX Cosmetic Modification (Interior/Exterior/Lighting) 4 03-08-2013 07:41 PM
