Old 01-27-2015, 01:39 PM   #113
Defuser
Remember
Defuser's Avatar
Drives: 2015 Asphalt
Anyone have any issues with Vorshlag studs?
I am going to be using 5mm spacers up front and 12mm in the back, Vorshlag seem to be perfect for this application.
This is my 17th car. Most fun so far!
Defuser is offline   Reply With Quote
Old 01-27-2015, 02:08 PM   #114
CenCali86
CenCali86's Avatar
Drives: FRS 10 Series
I am running the ARP extended studs with a 20mm spacer up front and 25mm in the rear. Since they only sold 25mm as a bolt on option I pressed out the other set of studs and just used them as slip on spacers.
I have been running this setup for about 5-6 months now with no problems.
Originally Posted by Krovi View Post
Sorry for the thread revival, but does anyone know for sure if 25mm spacers fit on the ARP studs?
CenCali86 is offline   Reply With Quote
Old 03-20-2015, 03:00 PM   #115
bryan767
bryan767's Avatar
Drives: 13' AVO Whiteout
So I have to do the fronts this weekend. I plan to hammer the studs a bit while they are bolted to the hub (just to loosen them a tad-anyone know if that'll be possible/clearance behind??), then remove the hubs, and hammer them out the rest of the way. I also plan to use the washer method to put them back in.
I'll repost with washer size.
I have to do this for my car due to my 17x9 +45 rpf1s with 245/40 sport comps on eibach pro springs - I was told I could use 3mm spacers but that was a lie. I need 8-10mm.
I will be using ichiba as Ive had good experience in the past.
bryan767 is offline   Reply With Quote
Old 03-20-2015, 03:57 PM   #116
Gopherboy6956
Gopherboy6956's Avatar
Drives: 13 BRZ Limited WRB
Just take the whole assembly out then hammer them out. To save your bearings, use something like a vice to hold the top of the hub to keep from hammering the bearing.
Also, i'm currently running 17x8 + 48 RP01's with 245/40s on coils with no rub - for reference. No spacers or anything.
I plan to live forever. So far, so good.
My Build - http://www.ft86club.com/forums/showthread.php?t=31925
Gopherboy6956 is offline   Reply With Quote
Old 03-20-2015, 04:09 PM   #117
bryan767
bryan767's Avatar
That can scratch the hell out of the mating surface between the wheel and lugnut though, depends on how much you care I suppose
You wont know if the stud is fully mated this way.
and yea, its these eibach pro springs are stupid wide. Shoulda went with coils.
Will take your advice and save the bearing, don't wanna damage that lol.
Edit: Studs arrived, will be taking pictures of the other way of uninstalling/installing these this weekend - aka a Big C-Clamp that I use to depress calipers.
Just so we are clear, you do NOT have to remove the hubs to remove these studs (atleast for the FRONT). There IS enough room to wiggle one stud out at a time. If you're going install anything longer than 10mm+ stock however, you will have to remove the hub to install them.
The biggest issue with just hammering these out, is keeping the bearing in tact. So the DIY way around this is a C-Clamp with a socket on one end, or this style of tierod remover tool:
Old 03-28-2015, 12:11 AM   #118
Gopherboy6956
I still have to do my rears. Fronts were cake with the hubs removed. At least with the rear, you know the work going into it before you start.
BUUUUT - ARP studs = worth it.
Old 03-28-2015, 05:48 PM   #119
Agent 86
Drives: 2017 Cayman S
Where did you find that C clamp?
I removed the hub from my car today, only to discover that the studs supplied with my H&R 5mm spacers were only 2mm longer than the OEM studs!
So now I need to find studs around 5 - 10 mm longer than stock, and a method for removing the stock studs. As a test, I tried tapping the stock studs with a hammer, and they didn't budge! :eye bulge:
… and loving it! Maxwell Smart
Gone but not forgotten
2014 BRZ Limited - 2013 VW Golf R - 2010 Forester XT - 2006 Mazda 3 GT
Agent 86 is offline   Reply With Quote
Old 03-28-2015, 07:39 PM   #120
ThreeEyedCrow
ThreeEyedCrow's Avatar
Drives: Scion FRS
I just recently did one of my rears. I didn't remove the hub, just the caliper and rotor. Then grabbed a BFH and gave one good wack and out it came. Not too difficult to do.
ThreeEyedCrow is offline   Reply With Quote
The Following User Says Thank You to ThreeEyedCrow For This Useful Post:
hmong337 (11-16-2015)
Old 03-28-2015, 11:31 PM   #121
Kosmos
Kosmos
Kosmos's Avatar
Drives: Scion FR-S
Any tutorials or maybe someone from here can tell me how to remove the rear hubs
Kosmos is offline   Reply With Quote
Old 03-29-2015, 03:46 PM   #122
Agent 86
Not sure about the rear, but on the front, the bearing will "bear" the brunt of each blow delivered to each of the 5 studs. Not a good thing, IMO.
The Following User Says Thank You to Agent 86 For This Useful Post:
wheelhaus (02-10-2016)
Old 03-29-2015, 04:10 PM   #123
BatStig
Some say.....
BatStig's Avatar
Drives: 2007 Subaru Impreza 2.5i
Just did both axles with a ball joint separator. Couldn't be easier. Thanks @Dave-ROR and @bpracer
BatStig is offline   Reply With Quote
Old 03-29-2015, 04:23 PM   #124
Kosmos
Kosmos
Kosmos's Avatar
Drives: Scion FR-S
You don't have to remove the 4 14mm bolts. Just whack out the hub and grease that baby up
Old 03-29-2015, 07:05 PM   #125
bryan767
bryan767's Avatar
So now I ordered ARP extended studs, they are supposed to have a .565 (14.351mm) knurl, whereas stock is allegedly just (14.35mm? -Need to verify oem). Ichiba's have to be 14.30-14.32mm.
As for the C-Clamp (which is still doable in a pinch), I ditched the idea when I came across a really nice DIY thread on a different website, mentioning a Harbor Freight ball joint separator tool. It features a removable pin/fulcrum and higher holes to increase the range to accommodate much longer studs. It works FLAWLESSLY for removing studs without removing the hub, and no bearing damage!!
http://m.harborfreight.com/3-4-quart...tor-99849.html
The Following User Says Thank You to bryan767 For This Useful Post:
Agent 86 (03-30-2015)
Old 04-02-2015, 11:29 AM   #126
jdmblood
jdmblood's Avatar
Drives: white subaru brz
What kind of spacers are you supposed to run with extended studs? All i find are spacers with studs already built in.
jdmblood is offline   Reply With Quote
flush with stock wheels. with Stud installation. adamturbo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 43 12-10-2012 05:30 AM
Wheel stud Guaruja Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 10-11-2012 03:42 AM
Lug Nut Stud feldy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 09-22-2012 11:26 PM
Scion FRS center wheel caps replacement? Silverback Cosmetic Modification (Interior/Exterior/Lighting) 10 09-03-2012 03:16 AM
Are there any RWYB Wheel to Wheel road races? LexusFman Other Vehicles & General Automotive Discussions 1 11-05-2011 01:28 PM
