Old 01-22-2015, 12:00 PM   #99
Swivel
Drives: 2015 Scion FR-S ZN6
Originally Posted by Mikeez View Post
Easy, a car that pushes 400whp goes behind the FRS and drives to push it. Duh!! Joke ;D
What is N/A? What is IHE?
N/A = [ame="http://en.wikipedia.org/wiki/Naturally_aspirated_engine"]Naturally aspirated engine - Wikipedia, the free encyclopedia[/ame] (say refer to it as "Normally Aspirated"); Just means no forced induction (turbos/superchargers/etc)
IHE = Intake / Headers / Exhaust; The three most common bolt-on N/A upgrades
Swivel is offline   Reply With Quote
Old 01-22-2015, 01:28 PM   #100
Mikeez
Engineering Student
Drives: Scion FR-S 2015
Originally Posted by Swivel View Post
N/A = Naturally aspirated engine - Wikipedia, the free encyclopedia (say refer to it as "Normally Aspirated"); Just means no forced induction (turbos/superchargers/etc)
Oh yes, I understand =p. I am still new to the acronyms. Thank you so much
There’s no time to stop for gas, we’re already late
Mikeez is offline   Reply With Quote
Old 01-22-2015, 07:38 PM   #101
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
Originally Posted by hmong337 View Post
How are you needing a gearbox when you're not even turbo?
What does a turbo have to do with needing a gearbox? I've replaced a few in stock cars.
Old 01-22-2015, 07:39 PM   #102
Reaper
Reaper's Avatar
Drives: violent
@Reaper isn't having problems with syncros. He's fragging gearsets through brute force. (torque) He's definitely found the design limit.
I've gone through two sets of syncros and one gearset.
The Following User Says Thank You to Reaper For This Useful Post:
Ultramaroon (01-22-2015)
Old 01-22-2015, 07:41 PM   #103
Reaper
Reaper's Avatar
Drives: violent
Originally Posted by HaDDeS View Post
Just a thought here, comparing power number is meaningless as soon as those numbers don't come from the same Dyno, and if you don't have the stock curve. Its like comparing apples and oranges ...
Maybe that 450 hp one would read about the same as the 250 other one, on the same dyno, maybe the difference in the reality is much thinner than the number would suggest.
The engine, can take a lot, the internals ... sadly not so much, specifically the bearings.
The oiling is also an issue and can lead to major troubles.
Again comparing numbers from various tunes isn't necessarily the best read of what the engine can take, analyzing the failures is a much more pragmatic approach to determine where are the limits
Spinning 4th gear and fuel starving in long high G corners doesn't lie. Neither does the 18,000 miles on my odometer.
Old 01-22-2015, 08:46 PM   #104
Whoops. I thought you fragged 4th in all 3 of your transmissions.
Are you rebuilding them yourself?
Reaper (01-25-2015)
Old 01-23-2015, 12:41 AM   #105
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
That would be one hell of a hobby...in which case i dont think so, otherwise after the second failure he would probably take so many selfies with them and post them here with suggestions on why they're breaking so much and where.
Old 01-23-2015, 01:34 AM   #106
toyotaAlex
toyotaAlex's Avatar
Drives: 2013 Scion FR-S Auto- OFT Stage 2EL
The Stock capacity of the FA20 is 1998CC or more commonly known as 2.0L
2013 Scion FR-S Auto, OFT Stage 2 Equal length 94oct, Hollowed out Factory Manifold, Stock Overpipe, Hollowed Front Pipe, Stock Midpipe with Resonator Removed, Custom Axleback with Single Exit and a Flowmaster 50series Muffler. Stock Airbox with all resonators removed, Snorkel shortened, TRD Panel Filter.
toyotaAlex is offline   Reply With Quote
The Following 2 Users Say Thank You to toyotaAlex For This Useful Post:
civicdrivr (03-22-2015), Kronos (01-25-2015)
Old 01-23-2015, 09:40 AM   #107
Pkush
Your level of sarcasm is too advanced for this forum.
Pkush is offline   Reply With Quote
The Following User Says Thank You to Pkush For This Useful Post:
toyotaAlex (01-26-2015)
Old 01-23-2015, 01:55 PM   #108
lol
Old 01-25-2015, 06:19 PM   #109
Reaper
Reaper's Avatar
Drives: violent
I can't get the parts to rebuild them. But I've inspected every failure and I've sent off a few pieces to "transmission specialists" but so far no help from the GTR/honda sequential/drag race/ lexus community except for a tremec tko swap proven by a supra drag race guy who didn't want to waste a v160 on this inexpensive of a car. That's the only answer that's somewhat affordable.
Old 01-25-2015, 06:23 PM   #110
Reaper
Reaper's Avatar
Drives: violent
I found a guy that would make me custom carbon syncros but he wanted more money than what a new transmission costs. And if it worked it probably just shear 4th and wreck everything in there. I also have a contact with a shop that does sequential conversions for stis and Hondas but he wanted 6k and couldn't say if it would be stronger nor not. 6k is more than a tremec swap and 75% of the way into a v160swap.
And before someone says it the r154 does not fit in the tunnel and neither does the Nissan z transmission.
Old 03-21-2015, 02:26 PM   #111
Darryljr11
Sideways and Smiling!
Darryljr11's Avatar
Drives: Scion FR-S
Any success/improvement in longevity in running a transmission fluid cooler? Thats the most affordable solution I can think of.
Darryljr11 is offline   Reply With Quote
Old 03-21-2015, 03:52 PM   #112
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Is anyone making stronger gearsets for the 6sp? I only see the Cusco close-ratio, which only changes 1st and 2nd.
WTB FA20 Stock Cross Want-To-Buy Requests 22 08-19-2014 03:59 PM
WTB FA20 Stock Cross Want-To-Buy Requests 1 08-01-2014 07:47 PM
Stock FA20/trans, never modified 9k miles ATM - April/May slicktop Engine, Exhaust, Bolt-Ons 2 02-24-2014 08:44 PM
Stock FA20 Crankshaft Angle Sensor - Anyone know what type of sensor and output? Acree Engine, Exhaust, Transmission 2 08-26-2013 07:39 PM
Stock AISSIN Transmission Power Capacity Don@Accelerated Forced Induction 37 07-03-2013 11:15 PM
