Old 01-13-2015, 07:04 PM   #1
kbogarto
Drives: 2013 BRZ limited WRB
Water dripping under car
So I installed an AVO base turbo kit last month. Never noticed before(never cared to look though) but when I park water drips down off the engine somewhere around the transmission area. I haven't been running the AC so I wouldn't think its ac condensation. Any ideas what this is? Thanks
92 240sx (sold), 03 350z (sold), 13 BRZ (AVO turbo)
kbogarto is offline   Reply With Quote
Old 01-13-2015, 07:44 PM   #2
mad_sb
Drives: 2013 Asphalt FR-S
exhaust leak and condensation. When you first fire up from cold start you will see a lot of water.
The Following User Says Thank You to mad_sb For This Useful Post:
kbogarto (01-13-2015)
Old 01-13-2015, 10:29 PM   #3
Mikeez
Engineering Student
Drives: Scion FR-S 2015
That's it? How would you explain an exhaust leak (curious)...
There’s no time to stop for gas, we’re already late
Mikeez is offline   Reply With Quote
Old 01-13-2015, 11:31 PM   #4
Whatabouteggs
[Citation Needed]
Drives: 2014 WR Blue Subaru BRZ Premium
Water condenses in the exhaust from the combustion process (water is a byproduct of combustion), as well as water vapor entering from the ambient air due to temperature and pressure changes, etc. In a boxer engine the exhaust manifolds are a low point, as opposed to normal engines where the manifolds are higher than most of the exhaust system. Therefore even in a stock car, water is bound to gather in some quantity in the manifolds. If the manifold gaskets aren't sealing properly, this can leak out.
Whatabouteggs is offline   Reply With Quote
The Following User Says Thank You to Whatabouteggs For This Useful Post:
kbogarto (01-14-2015)
Old 01-14-2015, 07:13 AM   #5
Calum
That Guy
Drives: 2013 asphalt FRS MT
It could also be the ac. If you're running with the heat on and the vents to defrost the car will cycle the ac to remove moisture from the incoming air.
The Following User Says Thank You to Calum For This Useful Post:
kbogarto (01-15-2015)
Old 01-15-2015, 06:20 PM   #6
Mikeez
Engineering Student
That is very well written and explained. Thank you
Old 01-16-2015, 11:57 AM   #7
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Is it clear water, or coolant water? Because one of the AVO turbo coolant hoses connects towards the firewall, by the transmission but if it's coolant from that line, it can't be clear water.
Weird sounds and liquid dripping from car kam Issues | Warranty | Recalls / TSB 21 05-07-2014 08:01 PM
water temp driver01 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 30 04-11-2013 03:57 AM
Water in trunk Spencer BRZ First-Gen (2012+) — General Topics 14 03-15-2013 11:17 PM
ROCKET BUNNY FR-S VIDEO DRIPPING WITH STYYYYLE :D switchlanez FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 9 10-12-2012 01:13 AM
